Old Apr 23, 2013, 08:32 AM
richos's Avatar
Joined Mar 2008
Hobbyking Freeflight F-18 Hornet w/Catapult Launcher 360mm Span
I've been thinking about the range of small foam-balsa HK free flight Models look quite nice
http://www.hobbyking.com/hobbyking/s...ht_Models.html
I liked the look of the Freeflight F-18 Hornet w/Catapult Launcher 360mm Span
So i got one (had some weight to use up on an order) only $3.85
http://www.hobbyking.com/hobbyking/s...60mm_Span.html
Specs:
Wingspan: 360mm
Length: 455mm
Does this sound ok to you guys
Parkzone Vapor/Ember Brick 3.30
Parkzone UM P51 Motor 5.17
Parksone Mustang Sukhoi Gearbox weigh 1.2g
GWS 5043 Prop 1.59
Power set-up will be a mid pusher prop, with elevon set-up on rear elevators
I have heard that the Parkzone Vapor/Ember Brick (green dot) has a 2A fet and can handel a Parkzone UM P51 Motor (Not sure) but can you guys conferm please?
Also heard that the Vapor/Ember Brick (green dot) can be programed to elevons with my DX6i Can you guys conferm on this also please)
Took the nose weight off and got a reading of 44.6g with the (prop motor-gearbox and brick and parts) on my Digi scales.
Do you think this is an OK weight for flight on this set-up ??
Add will it fly ok on rear elevators ? Looks OK to me on paper ! What do you think Guys ?
richos is offline Find More Posts by richos
Old Apr 23, 2013, 01:51 PM
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
great job! any videos?
chulian1819 is offline Find More Posts by chulian1819
Old Apr 23, 2013, 03:21 PM
richos's Avatar
Joined Mar 2008
No video yet Sorry.. chulian1819 .. I need some feedback on my questions yet, before i can start my build
(Question)
(Question)
Can you help me guys before i start my micro profile F-18 build Please.
Old Apr 23, 2013, 09:18 PM
CS should be in the box
Souderton Pa. USA
Joined Mar 2002
richos,
You'd be better off with a Cub or Champ brick, those have the 2 amp esc. The Vapor/Ember/green dot may only be 1 amp.
As far as elevons on a Dx6i, that maybe a problem. Some have had to flip the brick around or have one rod on top and the other on the bottom to get proper control directions. I don't recall and I no longer fly spektrum.
Looks like it'll be a cool plane, what's the wing loading and power loading?
mcross is offline Find More Posts by mcross
Old Apr 24, 2013, 08:51 PM
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
(Question)
(Question)
This might help with the elevon mix. I have your proposed Brick in my Airhogs X-Twinn Stunt Jet using the green dot brick with elevons. This is from 2009 and controlled by a DX7 TX. Important to limit throws to 50% for aileron and elevator channels, as they add together at the RX resulting in 100% throw when used together.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Apr 24, 2013, 11:07 PM
Souderton Pa. USA
Joined Mar 2002
IIRC it will be different between a Dx7 and Dx6i
Old Apr 27, 2013, 04:12 AM
richos's Avatar
Joined Mar 2008
Originally Posted by mcross View Post
richos,
Thanks mcross for that info not got a Cub or Champ brick to spare, but have a spare AR4600 .So will have to go the Spektrum AR6400 brick and AS2000 servo option (a more trickier set up than the Cub Champ or green dot brick setup) im sure that ive seen the Spektrum AR6400 brick and AS2000 servo elevon set-up on rear elevators with the DX6i and think its possible to do .
Have any of you Guys had good results with the Spektrum AR6400 brick and AS2000 servo elevon set-up on rear elevators with the DX6i ?
Thanks mcross did not want to risk blowing the FET on my green dot brick running a Parkzone UM P51 Motor.
Old Apr 27, 2013, 08:18 AM
Souderton Pa. USA
Joined Mar 2002
You can do it with the champ/cub brick you just have to pay attention when your building it.
The AR6400 w/servo will have the same requirements, it's a transmitter problem.
You need to plan brick, servo and horn orientation so your controls are in the right direction. The 6i relies on swapping servo connectors to get proper control direction, not possible with a brick.
There is also a long thread on a bug in the 6i elevon programming, but there is a workaround.
http://www.rcgroups.com/forums/showt...t=elevon+weird
For Sale NIB HET F-18 Hornet EDF ARF richardc951 Aircraft - Electric - Jets (FS/W) 0 Apr 22, 2013 09:07 PM
Discussion Exceed F-18 Hornet retracts beajer Electric Plane Talk 0 Apr 02, 2013 05:42 PM
Sold F-18 hornet airframe with servos. 18.5" wingspan jmscard Aircraft - Electric - Jets (FS/W) 5 Mar 05, 2013 04:01 PM
Discussion f/A 18 hornet by hobbyking?? mahmoodmusaddi Foamy EDFs 7 Dec 14, 2009 06:11 AM
For Sale 23" Span FFF F/A-18 Hornet tomi Aircraft - Electric - Airplanes (FS/W) 3 Dec 13, 2005 06:03 PM
