Old Oct 24, 2014, 10:37 PM
Mach One
captain MoMo's Avatar
Joined Apr 2011
Originally Posted by Knife Liddle View Post
Very nice work. Your radio gear installation makes my mine look like a 3rd grader did it. LOL
Thanks ! I doubt a 3rd grader could mod this jet like you did
captain MoMo is offline Find More Posts by captain MoMo
Old Oct 25, 2014, 11:24 AM
Mach One
Joined Apr 2011
Flaps to Elevator Mix?
Do you have to use elevator down when deploying flaps on this model? If so, can you please advise what you have used successfully when deploying flaps? I am using a DX8 with this model. Thanks!!
Old Oct 25, 2014, 12:02 PM
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
On mine it just needs a hint of down trim. Maybe 1/16". I'm balancing at 180mm. So slightly less sensitive to pitch movement than when balancing at 185 or 190.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Oct 25, 2014, 12:14 PM
Mach One
Joined Apr 2011
I will assume a 10% input down on elevator and correct from there..... thanks.
Old Oct 26, 2014, 11:08 PM
Mach One
Joined Apr 2011
Taxi Runs
It was very windy here today so I did not maiden. However, I did do my taxi runs. I am pretty sure this jet will need brakes! It has very minimal rolling friction, and the wind was pushing her on the runway. I have found the JP Hobbies 50mm dia ebrakes that will fit these landing gears with 4mm axle. Hopefully I can add this mod before my maiden since I worry about how many feet this jet will need to slow down after in has touched down?
Old Oct 26, 2014, 11:27 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
At your weight it will land slow enough that brakes aren't needed. Don't add the expense and complexity, ismy suggestion.
Old Oct 26, 2014, 11:56 PM
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
I find that I don't need brakes. It needs a max of 200ft to stop.
Talking about rolling friction, you need to check the wheel axles and apply loctite. Mine were loose and as the plane rolled down for take-off, tighthened - jamming the wheel against the strut.....
Landing was pretty short.......
anlucas is online now Find More Posts by anlucas
Old Oct 27, 2014, 05:07 AM
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
We have a 300 foot runway and I never felt I needed brakes to stop it.
barracudahockey is offline Find More Posts by barracudahockey
Old Oct 27, 2014, 06:32 AM
Mach One
Joined Apr 2011
Ok I will go ahead without brakes for maiden . What are the stall characteristics on this model? Do you use flaps on every landing?
Old Oct 27, 2014, 06:35 AM
Mach One
Joined Apr 2011
Thanks - I guess that's another way of slowing her. Tighten up the axle! LOL
I have checked and applied thread lock. Thanks.
Old Oct 27, 2014, 07:33 AM
Joined Sep 2004
Ever watch the Blue Angles F-18 come by nose high?
I do the same thing, get the flaps out, about 1/3 throttle, and drift it by at 3 or 4 mph.
My advice, take it up high, give it full flaps with gear down and reduce power till it drops, it will usually go nose straight. You will be shocked at how slow this thing will fly stock.
How this earlier in the thread somewhere but here you go
http://youtu.be/phBeX8Omsx4?list=UU7...tASvicGtqablMQ
About 15 degrees flaps on every take off, full flaps on every landing.
Discussion HK coming soon new fiberglass sport jet 90mm Tim Wan Electric Ducted Fan Jet Talk 91 Sep 14, 2014 10:01 PM
Build Log 90mm Sport Jet (Inspired by the JMP Firebird) JLink125 Scratchbuilt EDFs 136 Feb 11, 2014 10:03 PM
Question Where`s that new Fiberglass 90mm Sport Jet? Knife Liddle HobbyKing 1 Dec 09, 2013 01:30 AM
Sold New Jet Teng JTM 90mm Viper Jet w/TJ90 & Tamjet Retracts Alkaline Aircraft - Electric - Jets (FS/W) 4 Oct 23, 2013 01:44 PM
Sold HK F9F-8 Cougar Composite 90mm EDF Jet 1100mm (ARF) lmpbpd Aircraft - Electric - Jets (FS/W) 0 Oct 16, 2013 09:18 PM
