Old Jan 20, 2013, 09:14 AM
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
HK Phazer Delta Wing w. Optional Landing Gear and Steerable Nose Wheel
Released 1/19/13
Here's a new 860mm, 64mm DF model from HobbyKing that looks promising.
Available in Kit or PNF form. Includes rods and an optional Wheel Set.
Steerable nose wheel with 3rd servo.
The kit version requires a 40 amp Electronic Speed Controller (ESC), a 3s 64mm Electric Ducted Fan (EDF) system and three (2 without nosewheel) 9 gram servos to finish the model.
Best when flown 'clean' with no undercarriage, they also provide you with the parts required to fit tricycle landing gear if you fly off concrete strips.
Specification:
Wingspan : 860mm
Fuselage length : 650mm
Material : EPO
Weight: 700g
Kit
http://www.hobbyking.com/hobbyking/s...dProduct=22704
Includes:
• Phazer KX Airframe
• Hardware set
• Optional landing gear
• Decal Set
Requires:
4 Channel transmitter
64mm ducted fan unit
ESC 40 Amp
3 X 9g Servo
Li-polymer battery 11.1V-25C-2200mAh
PNF
http://www.hobbyking.com/hobbyking/s..._EPO_PNF_.html
Includes:
• Phazer Airframe
• 64mm ducted fan unit
• Brushless Motor 4800kv
• 60 Amp ESC
• 3 X 9g Servo
• Hardware set
• Decal Set
Requires:
4 Channel transmitter and Receiver
Hobbyking Phazer KX EDF Jet Flying Wing 860mm EPO (1 min 41 sec)
IFlyRCs is offline Find More Posts by IFlyRCs
Old Jan 20, 2013, 11:59 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Ordered one yesterday. Looks a like an Electrifly Synapse but this one is bigger.
Don
The Don is online now Find More Posts by The Don
Old Jan 21, 2013, 11:40 AM
ICrashRCs
Joined Jun 2011
Found another HK video.
It will be coming in other versions.
HobbyKing Daily - Phazer KX EDF Jet Flying Wing 860mm EPO (KIT) (1 min 35 sec)
Old Jan 21, 2013, 01:30 PM
OD123ify Snake
Morodie's Avatar
United States, FL, Pensacola
Joined Mar 2012
Yep I have one on the way also.......sigh
Morodie is offline Find More Posts by Morodie
Old Jan 21, 2013, 02:44 PM
ICrashRCs
Joined Jun 2011
Trying to decide what kind of power it can handle.
I have a Don's Wicked Plus 675w here and ordering a HK 10 blade 1000w now.
I have to decide which of these to put in the Phazer and my Neptune.
Leaning toward whichever is the heavier setup in the Neptune.
Old Jan 22, 2013, 05:14 AM
ICrashRCs
Joined Jun 2011
PNF released today. Added info to first post.
Includes:
• Phazer Airframe
• 60 Amp ESC
• 3 X 9g Servo
• Hardware set
• Decal Set
Requires:
Old Jan 22, 2013, 09:17 AM
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
to see if it gets to the US warehouse in the next few months
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Jan 29, 2013, 06:37 AM
Schwalbe
Junkers Jumo's Avatar
Australia, WA, Yokine
Joined Aug 2011
I've got one on the way too. I'll use the mercury 3700kv on 4S (assuming I can fit the battery).
First review is up on the kit version:
Ok, quick unboxed review, will complete after maiden. This was bad, pretty bad. Big "what you pay is what you get" moment. Lot of damages in epo. The parts are really loose and bad fit. Will require a lot of glue (Not like MPX...). The two fuse halves are already glued together (why), I'll have to cut it open to fit my fan. Fan cover missing magnet. Canopy is the worst fit, a joke. Epo seems pretty dense thou. Horns and clevis crap as usual. Decals look ok but the ones for belly side are a bit "dim" (grey&soft yellow). i will not use them anyway. CF spars are 4mm thick wall tubes. Room for li-po is 120x40x60mm. Oh well, this will require some work, but that's what we like. Room for
I'm guessing the next word is improvement
Mine should arrive in the next few days. Unfortunately the fan is out of stock so who knows how long before I can give it a go. I might give in to temptation and drop in an old plastic 64mm fan I have lying around just to get it in the air. Oh well...
Cheers,
Ingo
Junkers Jumo is offline Find More Posts by Junkers Jumo
Old Jan 29, 2013, 06:49 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
My order has still not shipped after 10 days. Getting close to cancelling the order.
Don
Old Jan 29, 2013, 12:49 PM
ICrashRCs
Joined Jun 2011
Don, mine has shipped. Processed thru Hong Kong today.
Old Jan 29, 2013, 03:54 PM
Jodde73's Avatar
Stockholm
Joined Sep 2009
Hehe, that was my quick review .
I can post pics if there is any specific part of this "bastard" you want to see.
@JunkersJ, the Mercury Fan will fit like a glove, the problem is getting it in and screw the two parts together. The fan looks and feels fantastic but surprisingly light and fragile. Will fire it up tomorrow.
Jodde73 is offline Find More Posts by Jodde73
Old Jan 29, 2013, 08:27 PM
Schwalbe
Joined Aug 2011
Don
They must have you on a black list or something Mine shipped five days after I placed the order. When Jodde reports on his maiden you'll be able to decide whether to cancel or not.
Glad to hear the fan will fit. Not surprised the fan is light and fragile, that's why I bought it! These are 160g compared with Extreme RC's modified CS in an alloy housing at 190g. Hopefully they have not gone too far in their weight reduction. Time will tell... I have a pair of older 64mm alloy fans; not sure if they're lander's or the older mercury, they are built like a brick house. Unfortunately they're just too heavy for the model I had them in. When I had to go round from an approach and then land with low (or dead, not sure) battery I ended up breaking the nose off the model. I didn't rebuild because I decided there was just too much weight for it to fly nicely with that fan.
Some photos of the battery/electronics compartments and underneath of it would be nice. Very much looking forward to the maiden report.
Cheers,
Ingo
Old Jan 29, 2013, 11:40 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
I guess so, I placed my order on the 20th and it still shows "in print queue". I have them on chat now.
chat result: supposedly they have one reserved for me since I ordered when it was in stock, but for some reason my order did not print out, but they are suppose to be shipping out ASAP. Lets see what happens.
Don
Old Jan 30, 2013, 02:14 AM
No mods no glory!
micromantis's Avatar
United States, CA, Redwood City
Joined Nov 2010
Well mine arrived but the kit came with no instructions. Does anyone know the CG?
micromantis is online now Find More Posts by micromantis
Old Jan 30, 2013, 12:17 PM
Jodde73's Avatar
Stockholm
Joined Sep 2009
Can't decide if I'm going to glue it with UHU Por or foam safe CA? CA snaps when it breaks, UHU Por gives more flexy but ugly "dust magnet" joints.
Wanted Delta Wing plane, e.g wild wing used or new littlephoenix Aircraft - Electric - Airplanes (FS/W) 3 Feb 09, 2014 01:05 PM
Article MicroDAN 2505-2900Kv Delta/Flying Wing Outrunner Motor Review DismayingObservation Power Systems 22 Apr 04, 2013 06:23 PM
Discussion Aerodynamics of flat plate delta wing kadil Modeling Science 1 Jan 15, 2013 08:44 AM
Discussion Flaps on Delta wing Teddy Ong Electric Plane Talk 2 Jan 05, 2013 08:49 AM
Discussion HK Flight Stabilizer V2 Delta wing 4touchdowns Flight Accessories 1 Jan 03, 2013 12:38 PM
