Old Mar 08, 2015, 03:27 PM
Rogue_Pilot is offline
Find More Posts by Rogue_Pilot
Fly-Crash-Rebuild-Repeat
Rogue_Pilot's Avatar
Joined Jan 2011
Question
Can a micro linear servo be used with a normal Rx?
I am wondering if a micro linear servo, like the one pictured below, could be used with a non-micro Rx like an AR6200 or AR500? Of course an adapter would need to be used, but with an adapter in place can this micro servo plug right into a Rx and work normally?
It would be used for working bomb/drop tank pylons on my 1100mm P-51.
Here is the servo:
http://www.hobbyking.com/hobbyking/s...ght_Left_.html
Rogue_Pilot is offline Find More Posts by Rogue_Pilot
Old Mar 08, 2015, 04:08 PM
landeck is offline
Find More Posts by landeck
United States, GA, Sandy Springs
Joined Jul 2008
That servo accepts a maximum voltage of 4.2 volts. Standard Rx's require at least 4.8 volts. To use them with standard Rx's would require that you power the servos separately from the receiver.
Bruce
landeck is offline Find More Posts by landeck
Old Mar 08, 2015, 05:22 PM
Joined Jan 2011
OK, thanks!
Old Mar 10, 2015, 06:35 PM
James_S is offline
Find More Posts by James_S
United States, WA, Woodinville
Joined May 2014
In practice most receivers use a 3.3V regulator internally and will run reliably on 4.2V or less. It depends on the dropout voltage of the particular regulator used.
James_S is offline Find More Posts by James_S
Old Mar 11, 2015, 04:12 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
The BEC output from an ESC is regulated at 5V. If you place a diode in series with the power to the servo, that will drop the voltage by 0.7V. That means the servo sees 4.3V which i about the same voltage as a fully charged single cell.
epilot is offline Find More Posts by epilot
Old Mar 11, 2015, 05:58 AM
tsymonds is offline
Find More Posts by tsymonds
Snappy Title On Backorder....
tsymonds's Avatar
United States, TX, Killeen
Joined Jun 2011
Just use one of these.
http://www.horizonhobby.com/servoles...elease-efla405
tsymonds is offline Find More Posts by tsymonds
Old Mar 11, 2015, 08:34 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
I don't know about HK servos, but I have planes using genuine Spektrum A2030L servos (presumably what they cloned), controlled by an AR6300 or AR6310 receiver, using Castle ESCs with 5V BEC. No problems.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Yesterday, 01:07 PM
Cloudriderurt is offline
Find More Posts by Cloudriderurt
Cloudrider
Manchester UK
Joined Feb 2008
Linear on full range Rx
Hi Andy, whats Spektrums lightest weight full range Rx I could try the Linear servos with?
When you select Full range on the web site, the list seems to merge into various range Rx's.
Cheers Paul UK
Cloudriderurt is offline Find More Posts by Cloudriderurt
Old Yesterday, 03:46 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Ar400.
Site Sponsor
Old Yesterday, 04:45 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Pop the case from the AR400- you get an under 4 gram rx
works great .
richard hanson is offline Find More Posts by richard hanson
Discussion Best 3D micro heli that can be used with Futaba snuvet75 Micro Helis 7 Mar 09, 2015 11:41 PM
Sold orangerx openLRS rx with ftdi programmer, can be used as spectrum analyzer rudyauction509 FPV Equipment (FS/W) 3 Mar 17, 2014 02:42 AM
Discussion can I use these servos with this ESC and Rx? nelsonmay10 Electric Plane Talk 2 Sep 23, 2013 04:19 AM
Discussion can micro servos be used with regular servos metallica_rule Fuel Plane Talk 4 Jan 20, 2008 06:44 PM
Can "Smoovy" Linear actuators be adapted as micro Servos?? JonB Scratchbuilt Indoor and Micro Models 2 Apr 05, 2002 04:17 PM
