Old Jun 27, 2015, 12:26 PM
Clive66 is online now
Find More Posts by Clive66
Clive66's Avatar
United States, CA, Fontana
Joined May 2011
Originally Posted by Chascall View Post
I just bought a Tidewater and most of the servo wires were Futaba, but not the ESC wire. I just trimmed off the tab and put them into my Spektrum RX.
Since that is an extension for the ESC & not the Actual ESC connector, i can see that happening.
My ESC extension may have been that way also, but since i don't think twice about cutting that little tab off, i don't remember.
Clive66 is online now Find More Posts by Clive66
Old Jun 27, 2015, 08:41 PM
Charlie P (NY) is offline
Find More Posts by Charlie P (NY)
Gravity is weak but persistant
Charlie P (NY)'s Avatar
United States, NY, Port Crane
Joined Aug 2009
Originally Posted by Clive66 View Post
That's odd
I put my Tidewater on my DX6i DSMX TX with no problems (AR600 RX)
Plugged the Servos & ESC in with no modification at all.
Me too. The stock components plugged right in to the AR600 receiver.
Charlie P (NY) is offline Find More Posts by Charlie P (NY)
Old Jun 28, 2015, 10:25 AM
Barry Smythe is offline
Find More Posts by Barry Smythe
eagleflyer
Joined Dec 2014
In post 996 the use of a Graupner prop was mentioned. That is a good prop and runs very smoothly with the Tidewater motor. If my memory is correct it draws about 19 amps as opposed to the stock prop which draws about 24 amps.
The stock prop needs balancing, but once balanced it gives very peppy performance, almost in proportion to the difference in current draws.
The stock prop has a larger blade area than the Graupner. That is probably the reason for the better performance.
Has anyone found a prop which is even better than the stock prop? If you have, do you know the current draw?
Barry Smythe is offline Find More Posts by Barry Smythe
Sold Flyzone Beaver, Flyzone C350 Corcalis, TH P-51 JimVanLoo Aircraft - Electric - Airplanes (FS/W) 0 Jan 08, 2013 01:15 PM
For Sale Anyone in the tidewater VB area interested in a slightly crashed E-flight Edge 540. Speedfreak Aircraft - Electric - Airplanes (FS/W) 1 May 12, 2006 02:13 PM
For Sale Tidewater Pronto jimmycashley Aircraft - Electric - Airplanes (FS/W) 3 Jan 15, 2006 04:45 AM
Discussion "Hardy Souls" contest, January 1, Tidewater, VA. D_Ryan Thermal 2 Dec 28, 2005 06:35 PM
Discussion "Hardy Souls" contest, January 1, Tidewater, VA. D_Ryan Sailplane Talk 1 Dec 28, 2005 10:30 AM
