Old Jun 16, 2015, 12:19 PM
ogg2000 is offline
Find More Posts by ogg2000
Joined Jun 2013
OK thanks - I guess I'll just have to experiment, and buy a cheap laptop otherwise it will be a long process.
I have another question, please. I have Input 7 set up as the input to enable 'I Adjust Heading Lock'. The default values for all axes are 0.000 - is the Heading lock function always inactive at the default? If I set the values to 0.01 as suggested in the manual and send to the gyro, when I read it back the values are back at 0.000. Is this working correctly?
The saved text file shows these values:
RTIgainX : 0.01
RTIgainY : 0.01
RTIgainZ : 0.01
Firmware version 3.41
Dave
ogg2000 is offline Find More Posts by ogg2000
Old Jun 20, 2015, 04:42 PM
smassel is offline
Find More Posts by smassel
Joined Nov 2011
GreatPlanes F1 Rocket Maiden w/ Ice-man Gyro
Just recorded the maiden flight of the F1 Rocket with the Ice-Man gyro (and Bluelight-tech isolation switch) today. Check it out:
GreatPlanes F1 Rocket Evo Maiden Flight (9 min 56 sec)
Flies very well. I'm using the gyro really more as a controller here, but its good to have it for take-off and to switch it on as needed in windy conditions for extra stability.
It comes in very fast, but room for improvement on the landings!
Gyro gains set to:
Pitch (x): 4.3
Roll: (y): 4.7
Yaw: (z) 8.4
Steve
smassel is offline Find More Posts by smassel
Old Jun 21, 2015, 06:33 AM
IceManPro is offline
Find More Posts by IceManPro
Manufacturer
IceManPro's Avatar
Joined Sep 2012
Originally Posted by ogg2000 View Post
.. when I read it back the values are back at 0.000. Is this working correctly?
Dave
This sounds right, since you're not setting the I value as a fixed static value (as you would if you did this from the Prof1 tab page). It is only set temporarily. Note also that it will be reset back to 0 when the sticks are moved away from central, unless you use the special firmware v3.5 which removes this resetting for the yaw. (See a previous post on this forum on this subject)
IceManPro is offline Find More Posts by IceManPro
Old Jun 21, 2015, 06:47 AM
Manufacturer
IceManPro's Avatar
Joined Sep 2012
Steve
Looks good. Could try some flaperons to slow down the landing speed..
Old Jun 22, 2015, 03:07 AM
jaccies is offline
Find More Posts by jaccies
The Netherlands, LI, Venray
Joined Dec 2008
https://youtu.be/xWuu8y0YWN4
Gyro gains set to:
Pitch (x): 4.3
Roll: (y): 4.7
Yaw: (z) 8.4
Steve
Steve you coming in much to fast , slow down earlier
jaccies is offline Find More Posts by jaccies
Old Jun 23, 2015, 11:41 AM
ogg2000 is offline
Joined Jun 2013
Ok thanks for the reply
Dave
Old Jun 23, 2015, 11:43 AM
smassel is offline
Joined Nov 2011
Yes, I need to come in slower. Didn't want to come in too slow on the Maiden flight, but will try to slow it down from further out.
Discussion GPS - - Blue light off after 10 mins part141 Hoverfly Technologies 11 Aug 09, 2012 11:54 PM
Help! Optima 9 RX blue LED won't light edge_pilot Hitec/Multiplex USA 6 Jul 15, 2012 06:34 PM
Gallery Cinestar 8 Gimbal Stability Test and Canon 7D low light test with the Tokina 11-16 HeliVids Aerial Photography 0 Jun 13, 2012 07:45 AM
Discussion GPS not working (blue light only blinks once) DesertDrones FPV Talk 3 Jun 12, 2012 10:37 PM
