Old Nov 07, 2014, 04:21 AM
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
My ZIGGY glider
I had an old wing off a sports flier lying around. I chopped the wing ends off and added extended tips then ripped out the ailerons and filled in the holes.
Then I drew a quick plan up for a fuse and tail.
I had a new Sk3 2826 1130kV motor so decided to use that. Fuselage took a few hours and tail and vert fin took about a day.
It is just a 'for fun' type thing and is now ready for it's maiden flight.
I named it Ziggy after my Pug.
If it goes OK I will buy it a folding prop.
It has ridiculous amounts of room in it. (unlike some foamies)
Tail feathers. Servos are mounted in the rear fuse.
Lighting in the wings causes a beautiful glow effect.
Grantham Kid is offline Find More Posts by Grantham Kid
Old Nov 07, 2014, 12:35 PM
On the Edge of Space
dLdV's Avatar
Exit 4, South Jersey, USA
Joined Dec 2007
Good luck! Looks nice.
dLdV is offline Find More Posts by dLdV
Old Nov 07, 2014, 04:00 PM
skumgummi dave
Gresham, OR.
Joined Mar 2004
Yep, good looking glider. I hope you have a blast with it!
Dave-
foamdave is offline Find More Posts by foamdave
Old Nov 07, 2014, 04:28 PM
Joined Oct 2012
Thanks guys.
I just hate having bits of planes around that are not being used. It cost me very little time and only about 4 sheets of balsa. I had everything else. We'll see how windy it is today...
Old Nov 09, 2014, 10:21 AM
builderdude's Avatar
United States, TX
Joined Jun 2011
Hey that looks really good! I'm sure it'll fly great.
builderdude is online now Find More Posts by builderdude
Old Nov 09, 2014, 04:17 PM
Joined Oct 2012
Thanks builderdude. Maybe today. I planned on flying yesterday but a friend arrived to get help covering his glider. He is just returning to building after many years and is a full size pilot too.
Old Nov 11, 2014, 09:03 AM
WJH
United States, FL, Spring Hill
Joined Aug 2005
Can't wait to hear about the results! Looks great!
WJH is online now Find More Posts by WJH
Old Nov 11, 2014, 09:23 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Powered gliders, a great way to have fun and learn about what air does.
It's not until you fly a glider, (with the power off), into the edge of a thermal that you 'see' what goes on up there, then center and circle the thermal until you realize just how small the model is getting.
Next comes near panic when you realize you need to get it back down
I still have one, 80" span with a brushed motor and a need for a 7cell Nimh pack to get the CG right.
Maybe one days.
eflightray is online now Find More Posts by eflightray
Old Nov 11, 2014, 04:09 PM
United States, TX
Joined Jun 2011
I miss my sailplane days.
Living in a high-wind area has all but completely shut down my RC soaring activity.
I'd have to move to do that again.
Old Nov 14, 2014, 03:29 AM
Joined Oct 2012
The wind was very calm here so I took my new Ziggy glider down to Grantham for its' maiden.
It was blowing a bloopin gale down there but I thought I wouldn’t waste my trip so I had a fly
It flew out of my hand like an angel…
Very happy with it. I did some tight turns and loops and it behaved perfectly, however I only used part of a battery as it was flying backwards at times the wind was so strong.
It landed nicely even so. Looks like I got the thrust angles spot on.
Looking forward to a calm day now. They are few and far between at present.
I will shout it a folding prop now (ordered) as it was freewheeling badly and I don't have the instructions to set the brake on the ESC I am using.
Old Dec 11, 2014, 04:57 AM
Joined Oct 2012
Plenty of flights up on Ziggy now. I fitted a folding prop and changed the motor and ESC to accommodate it and it is very quick. Glide has improved out of sight with the folder. I was even lucky enough to get a day with great thermal activity so had a number of extended flights. Ziggy gets small very quickly.
I was doing some low and fast circuits and forgot about the steel cattle yards and sliced the wing through just before the tip. However it is now fixed as good as new again and ready to go.
I have been experimenting with an Orange 3 Axis stabilizer. I had some that were not much chop, but I flashed them with the new firmware and wow, what a difference. Anyway I fitted it to Ziggy and it is dead smooth in wind now. Makes it easier to land in gusty conditions.
I should have fitted spoilers as it doesn't want to come down where I want it to. As I said, it is quite quick and just wants to keep going. I will try to add a video in time. Just gotta find a camera person.
Video LED on my glider BigFoot2012 Night Flying 0 Oct 28, 2014 11:15 AM
Joke Setting up my glider... Jack_LaLanne Humor 0 Oct 16, 2014 02:14 PM
Idea How I added floats/pontoons to my Radian glider BigFoot2012 The Builders Workshop 4 Oct 05, 2014 05:31 PM
Help! Choosing motor for my glider joonoh Power Systems 1 Oct 03, 2014 10:14 PM
My mini Ziggy... Thomas Manson Parkflyers 2 May 04, 2004 12:47 AM
