Old Mar 06, 2016, 11:29 AM
impmotor is offline
Find More Posts by impmotor
Horsham, PA
Joined Aug 2007
Changing CG over time
This morning I decided to change receivers while waiting for the weather to warm up. Since the new receiver is a bit smaller and lighter, I checked the CG but found it off more than I expected. Last summer I read in one of the posts a suggestion that Silly Putty mixed with a bit of lead shot would work well to achieve balance. It did. I put a bit in the nose and it formed to the exact shape and stayed in place. However, over the winter it dried out and lost over 2.5 grams. No longer pliable it was now loose in the nose and hard as a rock. I don't think I will use it again.
impmotor is offline Find More Posts by impmotor
Old Mar 06, 2016, 07:58 PM
jazz8388 is offline
Find More Posts by jazz8388
Michigan, USA
Joined Aug 2004
I am just finishing a standard Stream build and was considering this
Method to add weight in that slender nose. Guess I will have to
Think of something else. Thanks for the feedback.
jazz8388 is offline Find More Posts by jazz8388
Old Mar 06, 2016, 08:35 PM
IDOF3K is online now
Find More Posts by IDOF3K
Auger up & out, not down & in!
IDOF3K's Avatar
United States, ID, Lewiston
Joined Apr 2011
I like to use Tungsten Putty that they use in flyfishing! conforms to the nose quite well. Tom
IDOF3K is online now Find More Posts by IDOF3K
Old Mar 07, 2016, 05:01 AM
Remklep is online now
Find More Posts by Remklep
The Netherlands, NH, Haarlem
Joined Oct 2011
I use Tungsten powder from the fish-shop.
I scoop the required amount into the nose and then drip some thin CA in.
Remklep is online now Find More Posts by Remklep
Old Mar 07, 2016, 11:11 AM
jazz8388 is offline
Michigan, USA
Joined Aug 2004
I think I'm going to check this out. Didn't realize
all of these pinecar accessories are available.
Old Mar 07, 2016, 11:16 AM
davidjensen is online now
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Goop is the wonder glue/putty. I use 1/2g steel balls and glue the balls in place in the nose. Easily removable and the goop does not dry out or lighten in time.
davidjensen is online now Find More Posts by davidjensen
Old Mar 07, 2016, 11:33 AM
Thermaln2 is online now
Find More Posts by Thermaln2
Transplant Chey WY from Reno
Thermaln2's Avatar
Reno Nevada
Joined Oct 2007
Many use the sliding tungsten fishing weight. They are especially nice for the lollipop ballast sticks. They come in small sizes.
For those environmentalists, getting away from the lead sliders is best. There are many times people find dead eagles and other birds with lead shot in their stomachs. Besides, they can get more tungsten in the gullets for their own ballast.
Thermaln2 is online now Find More Posts by Thermaln2
Question Can Mesh Be Changed in Phoenix Builder Without Starting Over from the Beginning? BSquared18 Simulators 14 May 01, 2015 03:01 PM
Discussion Adjustable ballast....for slight cg changes gtrbaby Hand Launch 1 Mar 30, 2015 08:12 AM
Discussion Does CG Shift On A Plane Over Time? tonyxwing Electric Plane Talk 44 Aug 01, 2013 01:09 PM
Discussion My how many things change over time Luisfc1972 Beginner Training Area (Aircraft-Electric) 5 Oct 16, 2009 01:49 AM
Question does changing engines change cg? Caphead Beginner Training Area (Fuel) 6 Jul 18, 2006 02:32 PM
