Old Sep 28, 2012, 02:25 PM
Traian is online now
Find More Posts by Traian
Traian's Avatar
United States, GA, Roswell
Joined Mar 2008
2M Glider woodie built up flaps
I am getting ready to build a 2M woodie and I will have a built up flaps. The wing platform is based on the Aegea wing platform.
What I am thinking here to increase the torsional resistance is to lay the skins at 45 bias. Is this thinking correct?
Traian is online now Find More Posts by Traian
Old Oct 01, 2012, 05:53 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Will it have ailerons too.. that would be the only reason to build flaps. Otherwise if rudder and elevator i'd go with spoilers. I woulid jus build them out and forgo the skinning and add small gussets.. much less weight
Thermalin is offline Find More Posts by Thermalin
Old Oct 02, 2012, 07:09 AM
Traian's Avatar
Joined Mar 2008
Yes Flaperons 4 servos in the wing.
Aegea 2M wing platform.
Old Oct 02, 2012, 07:38 AM
3810 is offline
Find More Posts by 3810
3810's Avatar
Australia, VIC, Delacombe
Joined Nov 2003
nice looking glider!
3810 is offline Find More Posts by 3810
Old Oct 02, 2012, 10:55 AM
Traian's Avatar
Joined Mar 2008
I don't think woodie rules allow carbon in the flaps because I would use a .5mm rod on the trailing edge.
Old Oct 02, 2012, 12:51 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
The 45 degree bias between the top and bottom skins FOR JUST THE CONTROL SURFACES seems like a not bad idea. The only issue will come from the wood being difficult to form to any curve that is part of the airfoil along that last portion of the ribs for the control surfaces. If there is much at all you may well end up producing the very twist/warp that you're attempting to avoid. To check this out it may well be worth cutting out a few ribs similar to the flap and build up a foot long section of flap. Or simply cut out some extra flap ribs and be prepared to toss the first control surface built in this manner in favour of regular span wise sheeting if the bias angle sheeting doesn't prove out in practice.
BMatthews is offline Find More Posts by BMatthews
Old Oct 02, 2012, 04:29 PM
Traian's Avatar
Joined Mar 2008
Maybe I should just make a test flap and change on the fly if it is not working.
Discussion Step-up gliders - Once you are hooked - 2M and larger aeajr Thermal 80 Oct 01, 2012 07:41 PM
Question flaps set up in 2m ? Lammergier Electric Sailplanes 3 Aug 04, 2010 05:50 PM
Sold Gabby 2M w/Flaps Pro Built curtusua Aircraft - Sailplanes (FS/W) 12 Jan 07, 2009 08:37 PM
Question Looking for kit built(ie cheaper)but still nice 2m glider. What do you suggest?? w0ace Sailplane Talk 14 Jul 10, 2005 06:51 PM
FS: Polecat WindDancer 2M Poly/Flap Glider PDX Slope Pilot Aircraft - Electric - Airplanes (FS/W) 0 Apr 07, 2004 10:27 PM
