Old Oct 09, 2014, 08:44 PM
brcer's Avatar
United States, CA, Santa Barbara
Joined Dec 2010
Question
fuel and motor question
Hello,
I have a nitrobike comeing, and wanted to know what fuel/oil % to run.
motor is the Picco ORANGE HEAD EVO .12 I have access to VP 20% on sale for $20 gallon , or Byrons 20% 25%? the rtr blend with 16%oil aswell. what is the factory needle setting on this motor?
brcer is online now Find More Posts by brcer
Old Oct 10, 2014, 11:55 AM
Espa˝a, CL, ┴vila
Joined Sep 2008
If you plan to run your .12 engine with 20% nitro fuel you'll need more than factory carb settings.
Most .12 engines had head clearance factory set to run 16% nitro fuel. This should be something close to 0.40/0.45mm. For 20% fuel, increase that clearance to 0.50mm adding/changing head gasket.
Wrong head clearance will lead to blown glow plugs and erratic function.
I've checked Picco official page looking for factory cab settings and they don't provide more info than this...
http://teampicco.com/index.php/tech-...-carb-settings
Hope this helps.
Cesar, from Spain.
trf_414_m2 is offline Find More Posts by trf_414_m2
Old Oct 10, 2014, 01:19 PM
DLAWW
DLAWW's Avatar
Socal
Joined Dec 2005
I used the Byron's Race fuel 30% nitro. good reading here.
http://www.rctech.net/forum/nitro-of...ns-please.html
DLAWW is offline Find More Posts by DLAWW
Old Oct 10, 2014, 08:19 PM
brcer's Avatar
Joined Dec 2010
great info thanks, Im just getting back into nitro bikes after 3 years, do you have to shim up the head for 30%? If that's the case ill go with Byrons 20% most likely 25%.
Thanks DLAWW
Old Oct 10, 2014, 08:31 PM
brcer's Avatar
Joined Dec 2010
This is the only
info I could find on the picco
Picco .12 - .15 (General Carburetor Settings: slide and rotary)
New Carb -
4.5 turns out on the high speed needle
2 turns out on the low speed needle. (adjust while carb is wide open)
I think I will just ask Dave, motor should already be factory set, but I know you cant allways trust the factory..
Old Oct 11, 2014, 11:33 AM
nuovaic's Avatar
Wetherby, UK
Joined Dec 2003
I always use Byrons race fuel 16%
Cesar is correct, any more nitro should require another head shim or 2 to get compression down. If not, expect blown plugs and possible engine damage from detonation.
That motor will be plenty powerful enough on 16%, enough to win the WC in the right bike.
Some more useful info here
http://www.rctech.net/forum/onroad-n...al-tuning.html
nuovaic is online now Find More Posts by nuovaic
Old Oct 11, 2014, 03:09 PM
Canada, BC, Surrey
Joined Mar 2012
I just left it stock from factory like Dave said to. It fired up first time with 20% nitro. It is set rich from factory, still breaking in my motor.
I'm using the byrons fuel btw
http://vid1372.photobucket.com/album...ps4720c3f9.mp4
rollin3z is offline Find More Posts by rollin3z
Old Oct 11, 2014, 05:40 PM
brcer's Avatar
Joined Dec 2010
nice man, I like the paint job to.
hope to see some more videos..
Old Oct 11, 2014, 07:44 PM
Canada, BC, Surrey
Joined Mar 2012
I wish dude, all it does is rain here....A word of advice, dont run without the rider and find a place thats really smooth and not much uneven pavement or ruts...my bike went airborn and landed on the pipe..there goes 70.00 bux and a long wait for the replacement
Old Oct 11, 2014, 08:13 PM
brcer's Avatar
Joined Dec 2010
Advice taken, sorry about your pipe.
Old Oct 12, 2014, 08:46 AM
DLAWW
DLAWW's Avatar
Socal
Joined Dec 2005
Yeah thats a race bike not a basher.
Old Oct 12, 2014, 05:27 PM
brcer's Avatar
Joined Dec 2010
I have a nice place to run out in Goleta, I run my 1/5 onroad their.
Old Oct 12, 2014, 11:00 PM
brcer's Avatar
Joined Dec 2010
just to be clear, the Byrons 20% with 16% oil is the rtr blend, their other 20% blend has 12% oil correct?
Old Oct 13, 2014, 01:19 AM
nuovaic's Avatar
Wetherby, UK
Joined Dec 2003
Correct. For racing 12% oil is ok. 16% oil is not needed for bikes (we don't stress them as much as cars) and can cause more problems with excess oil running back down the pipe into the head producing an engine lock.
I was referring to 16% nitro.
Question Questions about a fuel engine koko_ronaldo Beginner Training Area (Fuel) 3 Oct 12, 2014 09:14 AM
Discussion Another stupid fuel question Brutus1967 Engines 46 Sep 29, 2014 01:21 AM
Question Fueling question RCTodd Engines 8 Jul 20, 2014 06:55 PM
Discussion Cox TD .010 & .020 Fuel Question Nicksbbq 1/2A Planes 7 Feb 11, 2014 11:04 PM
Discussion saito 180 Fuel/carb Question metalwizard Engines 20 Nov 29, 2013 07:12 PM
