Old Sep 26, 2014, 05:24 PM
Joined Jul 2009
Yaw problem on big quadcopter - Naza M V2
Hi,
I have a big quadcopter with 100cm motor to motor. The motors are MT3515-400Kv, Graupner 12''6 props, PLUSH 40A ESC, 2x 6s 5000mAh battery and Naza M V2.
I'm having problems with YAW. Every time I try to change yaw the quadcopter get bad on roll and pitch.
How should I tuning it to solve the problem?
I have a video but I was able to record it after work so there is a little dark :s
Flight Test (0 min 19 sec)
metRo_ is offline Find More Posts by metRo_
Old Sep 26, 2014, 05:31 PM
Kauai
Joined Jan 2011
Are all your motors lined up straight on the frame,could they be a little off.Any offset or crookedness will result in poor yaw performance and lead to instability.That would be something you couldn't tune out.Hard to see your quad clearly but the props seemed to be at odd angles?Also was the life ring loose and moving around?
Kauaiguy is offline Find More Posts by Kauaiguy
Old Sep 26, 2014, 05:41 PM
Noob
Torque66's Avatar
Canada, ON, Toronto
Joined Dec 2011
Yeah... if setup right it's probably a motor or two not flat.... just fly it a few feet infront and see if they line up.
Torque66 is offline Find More Posts by Torque66
Old Sep 26, 2014, 06:15 PM
Joined Jul 2009
thank you for your input
The motors looks aligned and I also measure the distance from each motor to center and they are ok. The life ring is fixed and the props aren't above the life ring. I think it is easy to see my setup on the following image:
http://imgur.com/oX0fDyW
Red- life ring
blue-props
Fly it in front, back and to left and right are ok. Only yaw has a bad behavior.
Old Sep 28, 2014, 09:35 PM
Mrimstad's Avatar
Joined Feb 2014
12 inch propellers on a +1000mm frame?
You seem to be the right kind of crazy.
Now usualy this is like people explained due to uneven motor mounting.
On a frame this size even more important! Get a bubble level and go at it again.
A contributing factor may also be lack of thrust!
Mrimstad is offline Find More Posts by Mrimstad
Help! Naza M Lite - Yaw Problem to the right in all flight modes. raymondkerr Multirotor Electronics 7 Oct 07, 2014 10:58 PM
Discussion Naza V2 bad Yaw Wobble on Black Snapper foldable Quadcopter - SOLVED!!!! schim Multirotor Electronics 1 Aug 26, 2014 02:41 AM
Question Yaw adjustment on DJI Naza-M V2 hotrod5607 Multirotor Talk 14 Jun 14, 2014 02:13 AM
Help! TBS DISCOVERY dji naza m v2- Turningy 9x problem sirbevalot Multirotor Talk 17 Nov 27, 2013 02:18 AM
Discussion NAZA M Lite on big Hexa Japeeps Multirotor Electronics 3 Oct 12, 2013 06:39 PM
