Old Oct 22, 2008, 03:00 PM
Cut Off, LA
Joined Mar 2007
Question
Bec
I need a little help I am putting togather a twin engine twin speed controller and 2 battery set up. Should I use the BEC or should I put seperate batteries for the receiver? I already know I must disable 1 bec wire on one speed controler for this set up. Please give me all the pros and cons Thanks
TROUBLEMONSTER is offline Find More Posts by TROUBLEMONSTER
Old Oct 22, 2008, 03:06 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Look here, lots of info:
http://www.rcgroups.com/forums/showthread.php?t=783582
Kmot is offline Find More Posts by Kmot
Old Oct 22, 2008, 04:12 PM
apprentice shipwright
John Pilot's Avatar
Little Rock, AR
Joined Sep 2005
Don't know if this is mentioned anywhere in Ghost's thread, but this is something you may want to consider:
I have a two-motor / two ESC setup. Each one of the ESC's has a BEC as well. In order to protect the ESC's and motors from getting fried I have placed a 10A fuse in line with each of the ESC's.
The only drawback to doing this is that if the fuse leading to the ESC with the enabled BEC blows you lose power to your motor, but ALSO to your receiver, servos,... etc.
For safety sake, I decided to add an additional BEC connected directly, without a fuse, to the battery. This BEC (or additional small battery) is only for the receiver and servos. That way, if I do lose one of the fuses to one of the motors (and ESC), I still have a working receiver and servos to make it back to shore on one motor.
John Pilot is offline Find More Posts by John Pilot
Old Oct 22, 2008, 05:14 PM
Old wreck in Milwaukee
Prins Willem's Avatar
United States, WI, West Allis
Joined May 2007
If weight or space is an issue then use the BEC. My models all are large enough to easily accommodate a receiver pack. In a FE you might not want or be able to use a receiver pack.
I don't know if this still applies but in the olden days(early 90's) when I was involved in car racing, on BEC the battery level would drop low enough for the receiver to stop working while the motor would still run. Saw more than one car hit the wall due to that little glitch.
Prins Willem is offline Find More Posts by Prins Willem
Old Oct 22, 2008, 05:39 PM
Joined Nov 2005
I'm running a 5cell Rx pack(350mah) in my 'no step 1' Fe boat. I do have to recharge after about 10minutes runtime (should be ok for 3 heats (or about 2.5 miles))
Rex R is offline Find More Posts by Rex R
Old Oct 23, 2008, 05:33 AM
Is life for real?
pkboo's Avatar
Almere The Netherlands
Joined Sep 2006
In tweaking with my latest project I came up with these Ubec systems: http://www.elemodel.com/shopen/html/product_1139.html I've noticed that it seem to work with the steering servo. When turning it entices the ESC to give more "gas" which is excellent, in turns you loose some power and it seem to compensate for that . Boo
pkboo is offline Find More Posts by pkboo
Old Oct 23, 2008, 09:34 AM
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
on the diagrams, there are fuses marked (green spot) between motor and esc,and between esc and battery
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Oct 23, 2008, 10:40 AM
Ontario, Canada
Joined Feb 2005
Battery Eliminating Circuit
Can anyone tell me why you need a BEC. I have run twin motors with twin ESCs and never used a BEC. Am I missing something?
fatboy999 is offline Find More Posts by fatboy999
Old Oct 23, 2008, 11:18 AM
Ghost 2501's Avatar
stoke on trent
fatboy, the term BEC comes from the aeromodelers, who in the interest of saving weight, started to use just one battery pack, rather than a seperate pack for the motors and a seperate pack for the radio gear, so by going to a BEC system, you have eliminated the battery pack used for the radio.
Old Oct 23, 2008, 06:25 PM
Joined May 2007
In aircraft and racing vehicles (cars & boats) excess weight is a killer. The BEC takes the receiver pack out of the equation entirely. The downside is like front wheel drive. Everything is centralized, dead battery no anything else, fried ESC same story. I have a couple of FE boats using BEC but I never leave the house without a tug for rescue work. I have trust issues.
Old Oct 23, 2008, 10:59 PM
Cut Off, LA
Joined Mar 2007
I have enough room so I will put a seperate battery pack. Thanks
