Old Aug 20, 2014, 03:40 PM
Joined Oct 2011
You Can Dye Sails
http://www.rcgroups.com/forums/showp...&postcount=502
dobydog6507 is offline Find More Posts by dobydog6507
Old Aug 20, 2014, 03:55 PM
Dick L.'s Avatar
Minnesota, USA
Joined Aug 2002
I have an article which "implies" you can decorate nylon ripstop sails using latex (water based) paint. The colors tend to stay translucent - and never really reach a solid color. Would suggest trying on some nylon ripstop first.
Dick L. is online now Find More Posts by Dick L.
Old Aug 21, 2014, 11:55 AM
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
I dyed the nylon sails of my first Seawind solid yellow with special dye made for nylon - the regular Rite dye sold in grocery stores won't do it.
It did make them yellow, but you have to soak them for several hours in the almost boiling water/dye and the bolt rope shrunk drastically as well as puckered them in several places. http://www.dharmatrading.com/dyes/dh...lnav=dyes.html
I would not do it again. If you want to dye them, first remove the bolt rope or other items that might shrink and soak them longer at a lower temperature than the directions give. As an alternative low temp method, you can extract the ink from a permanent marker by soaking the marker in solvent and then soak the sails in that.
FoamCrusher is offline Find More Posts by FoamCrusher
Old Aug 23, 2014, 04:03 AM
tbarjohn's Avatar
aurora, il.
Joined Aug 2009
I tried dye on sails with no luck at all, now I use Design master paint from Michel's, it is for painting silk flowers, after it dries you can't tell the sails have been painted, I cut stencils for the numbers, there is no bleeding of paint, the sails on my Soling where painted in 2004 and look good today
John R.
tbarjohn is online now Find More Posts by tbarjohn
Old Yesterday, 02:10 PM
Never Stop Learning
Jaguar22's Avatar
United States, GA, Atlanta
Joined Mar 2005
Painting the sail as you describe is a great idea. I will have to do some tests on samples to get it down first.
David
Jaguar22 is online now Find More Posts by Jaguar22
Discussion Can You Dye Mylar? Tail Spin1 Free Flight 3 Nov 28, 2011 04:58 PM
Discussion Can RC Sailing teach you how to sail? CptanPanic Sailboats 14 Aug 16, 2006 09:43 AM
Question Can you dye fiberglass cloth black? Phiber Optik Composites Fabrication 23 Oct 23, 2005 08:49 AM
Dye won't dye Cubber Scale Kit/Scratch Built 9 May 30, 2005 12:03 PM
Food dyes or Clothing dyes on foam? igo Foamies (Kits) 6 May 26, 2005 01:45 PM
