Old Apr 16, 2015, 02:55 PM
AURORA42147 is offline
Find More Posts by AURORA42147
Joined Jul 2014
XPS Dynamax V1, V2 and V3?
Is there a V3 XPS Dynamax and if so what is the different from V1 and V2. I've had a V1 (gold motor-rear). I've seen what some have called V2 (black motor-rear). Is there a V3?
AURORA42147 is offline Find More Posts by AURORA42147
Old Apr 16, 2015, 05:16 PM
bruff is online now
Find More Posts by bruff
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Here is a picture of XPS ver3 which I had.
Bob
bruff is online now Find More Posts by bruff
Old Apr 16, 2015, 09:22 PM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
There was a Dynamax Xtreme (LS motor) which was V1. There was Dynamax Xtreme PRO and Dynamax Xtreme PRO 2. There was also a Dynamax Xtreme Lite that used the Hacker turbine motor. So, we really had 4 versions.
The difference between the PRO and PRO2 was the motor keying and wind a bit different.
JimDrew is online now Find More Posts by JimDrew
Old Apr 17, 2015, 10:03 AM
Joined Jul 2014
fan
Thanks Drew for the clarification. I haven't seen the Dynamax Lite. Are there any around and what was the performance compared to the other 3? Where did V3 stand in overall performance of the group? I have the V3 version running on 14S, Dinogy Lipos and Sunrise 180 HV ESC.
Old Apr 17, 2015, 03:07 PM
Lake Havasu, AZ
Joined Jun 2005
The lite version weighed a little over 1 pound less than the others. It was designed for 11S operation (12S with throttle management). It delivered around 14 pounds of thrust on 11S, up to 16 pounds with 12S.
I have a V3 setup running on 18S @ 16.4Kw.
Old Apr 17, 2015, 03:16 PM
Joined Jul 2014
fan
WOW, 18S - it must be a screaming machine. What batteries and ESC are you using? My 14S setup is in a Yellow Aircraft Starfire II
Old Jun 23, 2015, 01:17 PM
Oldi is offline
Find More Posts by Oldi
Joined Dec 2012
@ Bruff: As I am to understand, you know a lot of EDF's. For my glider (Yes, 20' span, 22Kg) I need an EDF for self-launch. Surging the internet I found the <Schübeler DS-94-DIA HST with DSM6745-700> with a thrust range: 100-130N on 12-14S. That will do the job and is ok for me. Then the price: not so ok. Next is the XPS Dynamax Xtreme PRO 2/3 whereof I think comes close in performance (maybe better?). My problem: wherever I surge, I cannot find ANY webstore to buy one, not even the sellingprice is known to me. Can you help me out and mail me where to buy? Or, from your experience you maybe advice a different EDF 125-130mm. Unfortunately I have only room for max 12S/6000mAh. I live in The Nethlands, so an adress in Europe would be fine although not essential. Thanks, Constant Goderoy, godefroy@planet.nl
Oldi is offline Find More Posts by Oldi
Old Jun 24, 2015, 04:32 PM
Arngeir Blakseth is offline
Find More Posts by Arngeir Blakseth
Senior Member
Arngeir Blakseth's Avatar
Molde, Norway
Joined Jan 2001
Reason you can't find any XPS fans for sale is because they have not been on the market for a few years. Out of production.
You should have a look at the Jetfan 120, it's made by Ejets in Austria so pretty close to home for you. Specifically a Jetec E-120 unit perhaps?
http://www.migflight.de/produkte/e-120/
Arngeir Blakseth is offline Find More Posts by Arngeir Blakseth
Discussion XPS Dynamax V1, V2 and V3? AURORA42147 Electric Ducted Fan Jet Talk 4 Apr 16, 2015 05:23 PM
Sold New XPS Dynamax Fan with XPS V3 Motor - up to 20kW! lumpy649 Aircraft - Electric - Jets (FS/W) 1 Oct 26, 2014 09:38 PM
Sold New XPS Dynamax Fan with XPS V3 Motor - up to 20kW! FL62 Aircraft - Electric - Jets (FS/W) 2 Oct 09, 2014 12:55 PM
Wanted XPS Dynamax fan V1 inrunner motor raventech Aircraft - Electric - Power Systems (FS/W) 0 Aug 11, 2014 05:10 PM
Sold XPS Dynamax V1 Big screamer edf delta2001 Aircraft - Electric - Jets (FS/W) 1 Mar 30, 2014 02:26 PM
