Old Apr 12, 2015, 08:02 PM
cityevader is online now
Find More Posts by cityevader
IT'S NOSE HEAVY!!!!!!!
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
1st RC car...servo issue
So...I've been into planes since 1987, but this is my first car; a Losi 1/24 SCT.
The steering servo has gone goofy, and a quick online search and servo removal shows it has a 5 wire servo.
Is the 3-pin plug (in picture below) on the other end of the board for a 3 wire servo?
I've got so many random micro servos i could throw in until they go bad, that purchasing a new 5 wire servo is silly. (Apparently I'll have to mod the output arm to match square drive of servo saver too, no biggie)
cityevader is online now Find More Posts by cityevader
Old Apr 13, 2015, 08:37 AM
bill_delong is offline
Find More Posts by bill_delong
Did I make the A Main?
bill_delong's Avatar
Austin,TX
Joined Mar 2009
The resolution is too small to see the 3 pin slot you're referencing, chances are that slot is a JST-XH port for 2S power input.
Pretty good discussion here on 3 wire and 5 wire servos:
http://www.rcgroups.com/forums/showthread.php?t=1051518
bill_delong is offline Find More Posts by bill_delong
Old Apr 13, 2015, 09:24 AM
cityevader's Avatar
Joined Mar 2012
Here's a better pic. ..it could be a lipo plug...
Nearly dead center of frame, servo plug at far left.
Old Apr 13, 2015, 10:12 AM
Austin,TX
Joined Mar 2009
that doesn't look like a JST-XH port, and yes, that sure does look like a 3 pin output for servo.... I would hook up a voltmeter to the pins and see if it's pushing out any voltage. I think the signal output is something like a variable 0.5 to 0.6V or something like that as you apply steering input where the other two pins should be a constant 5.0V or 6.0V depending on the BEC output. If your readings are in that ballpark, then it should control a 3 wire servo as you predicted.
Old Apr 13, 2015, 12:53 PM
Dialed_In is offline
Find More Posts by Dialed_In
West Virginia
Joined Apr 2010
If it's the 2.4ghz conversion esc or the newest scte or rally x esc then yes those 3 pins are for a 3 wire servo.
Number 5 in the 1st post of this tutorial shows different ways we mod a servo horn. http://www.microtforum.com/viewtopic.php?f=45&t=21711
Edit: I'm not sure which way the servo plugs into the esc so have a close look at the esc for any writing. Either that or check the manual.
Dialed_In is offline Find More Posts by Dialed_In
Old Apr 13, 2015, 06:42 PM
West Virginia
Joined Apr 2010
Here is the esc manual. For a 3 wire servo the negative wire is towards the esc's antenna wire. http://losi.com/Products/Support.aspx?ProdID=LOSB9524
Old Apr 13, 2015, 06:58 PM
cityevader's Avatar
Joined Mar 2012
Just now got home and quickly plugged in a disposible servo, and it works!
Old Apr 13, 2015, 07:03 PM
West Virginia
Joined Apr 2010
Great to hear it works . Most 3 wire servos will work way better than Losi's overpriced 5 wire servo.
Old Apr 13, 2015, 07:41 PM
cityevader's Avatar
Joined Mar 2012
Hs55 case is just a hair too big (roughly equal to the thickness of one wall of its case) ...and a wee bit too much travel, as the "drive pin" spins up and out of the groove in the linkage, hmm...
Old Apr 13, 2015, 08:14 PM
West Virginia
Joined Apr 2010
Can you adjust the servo travel on your transmitter?
You might be able to cut the chassis to make it fit. I would just get another cheap servo the same dimensions as the stock 5 wire servo. The 2nd post in the tutorial I linked to lists a few parts and servos I've seen used in builds. The HXT500 from hobbyking works with a little shimming and is dirt cheap.
Old Apr 13, 2015, 10:01 PM
cityevader's Avatar
Joined Mar 2012
Ah...didn't even think about shimming a smaller one that i have.
Cheapy included transmitter has no end point adjments...well, actually, it has a "sensitivity" knob which can be turned down. The 4 yr old likes to mess with the knob the entire time he's using it, though.
Discussion rc car issues astranger1224 Off-road Cars 15 Jul 16, 2015 05:26 AM
Help! First RC car RipMax Dingo steering issue robr_uk Electric Power Cars 2 Feb 08, 2015 12:01 PM
Discussion Building an unusual RC car.....need advice on servos grampsb29 Car Talk 2 Dec 10, 2014 10:54 AM
1st RC Car, 1st post here. I'm hooked. CooHead Off-road Cars 25 Oct 30, 2004 07:40 AM
