Old Feb 02, 2011, 12:15 PM
cap23244 is offline
Find More Posts by cap23244
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
r/c america shark LT arc pattern plane?
would this be considered a pattern plane.
I was at a swap meet today and picked up a pattern plane kit.? new in box. the guy said it was about 15 or so years old.
it was made in Mexico.by aeromodels.and distributed by RC America models.
its arc 60'" wing span ARC model kit.
have you seen any of these.? are they good flyers. is it worth anything. just wondering if I should build it or keep it in kit form
Also if i was to build it i would like to find a rear exuast eng. 61. os use to make a nice on with a pump. i cant remeber the model.
if any one know please let me know. also any suggestions for a rear exaust 61
thanks
cap23244 is offline Find More Posts by cap23244
Old Feb 03, 2011, 01:11 PM
stuntflyr is offline
Find More Posts by stuntflyr
stuntflyr's Avatar
Los Angeles
Joined Jun 2010
Looks neat, Cap.
I've never seen one before but it looks like it'll fly. It's an ARC I guess, huh? Are the wings sheeted?
You probably were thinking of the OS 61 RF P which is a rear exhaust engine with a pump.
I have one that I gave a lot of money for, but it's yours for 200 dollars shipped to your door.
Chris...
stuntflyr is offline Find More Posts by stuntflyr
Old Feb 03, 2011, 01:32 PM
cap23244 is offline
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
yea the wings are sheeted now i have to find out how to add retracts. it has the routing for the wiring under the balsa but i dont know how to add retracts to a faom wing. can anyone help
thanks
Old Feb 03, 2011, 01:57 PM
Pitstop000 is offline
Find More Posts by Pitstop000
Paul Pappas AMA 42520
Pitstop000's Avatar
CT,USA
Joined Aug 2008
thanks
Hi Cap
For RE 60/61 10cc it's Rossi, Nova Rossi, OPS and JETT.
These are all New production motors available today.
Pitstop000 is offline Find More Posts by Pitstop000
Old Feb 03, 2011, 02:06 PM
Pitstop000's Avatar
CT,USA
Joined Aug 2008
thanks
Cap, are there blocks already installed for landing gear?
Take a couple pictures of the wing so we can see what your working with.
Its not hard at all to add retracts to Foam wings.
Old Feb 03, 2011, 02:26 PM
cap23244 is offline
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
hers a few pics intructions are not that clear i might have to scan them to a pdf or word doc. to let people see so the can help me.
Old Feb 03, 2011, 02:49 PM
cap23244 is offline
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
i will try to up load a pdf
It wont let me upload the pdf its 4.5megs. so if you or anyone else need to look at it let me know i would have to email it
thanks
Old Feb 03, 2011, 04:16 PM
Pitstop000's Avatar
CT,USA
Joined Aug 2008
Cap, e-mail what you have. Id like to take a look. Your PM settings are blocked.
Old Feb 03, 2011, 04:22 PM
cap23244 is offline
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
pit i sent you a email
Old Feb 03, 2011, 05:39 PM
Pitstop000's Avatar
CT,USA
Joined Aug 2008
Installing retracts in foam wing
Cap,
This is a very commonly used method to install retracts in a Foam wing.
You first need to make a couple of plates out of ply that fit your retracts and drill holes for dowels to be inserted into the foam.
Will you be using mechanicals?
Old Feb 03, 2011, 08:13 PM
Pitstop000's Avatar
CT,USA
Joined Aug 2008
Next you need to mark the location of the plates on the wings and cut the sheeting and remove foam so you can install the plates.
Will you be using separate aileron servos in the wings?
Old Feb 03, 2011, 08:54 PM
Pitstop000's Avatar
CT,USA
Joined Aug 2008
To cut the foam you will need some type of foam cutter or a Dremel.
I use this little hand held foam cutter to do some of the little work.
This little unit heats the wire up to 250 degrees, cuts like the bigger units.
Old Feb 03, 2011, 09:11 PM
Pitstop000's Avatar
CT,USA
Joined Aug 2008
I use this larger unit with adjustable sled to cut out any lager portions of foam (retract plates, servo wells, etc) for complete and repeatable results.
The sled is micro adjustable, makes for easy work.
Old Feb 03, 2011, 09:53 PM
cap23244 is offline
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
thank you very much.
i will be using seperate servos for the alerions.
i dont have a foam cutter but i do have a dremel,
Old Feb 04, 2011, 09:52 AM
Pitstop000's Avatar
CT,USA
Joined Aug 2008
Cap, what retracts have you been able to source?
Looking at the wing plan I think you will run into some geometry issues. The reason I say this is even though the gear is mounted in the wing the wheels need to be forward of the leading edge of the wing.
The current crop of retracts that are available today will not give you this type of install.
At the time that this Kit was produced there were retracts specifically designed to extend forward instead of 90 degrees to the mounting plates. I believe one company that made such retracts was Pilot for their EZ line of Kits.
I have seen these sets of retracts come up for sale at times.
Discussion Whats the stupidest thing you ever did with an R/C Plane? 3DNater Electric Plane Talk 142 Mar 03, 2011 09:12 AM
Discussion Transporting R.C. plane on vacation realtimerecon Aerial Photography 5 Oct 28, 2010 05:03 AM
Discussion Real Plane and R/C plane collide mid-air!!! L@@K!!! FireryPhoenix Life, The Universe, and Politics 10 Oct 17, 2010 07:59 AM
Discussion RE: Sail Pattern and Hull Paint Scheme Resource for America Cup c.1980 Yachts Generic Sailboats 5 Dec 06, 2007 11:17 AM
