Old Mar 27, 2015, 05:55 AM
Back after 30 years
Canada, ON, Vaughan
Joined Mar 2015
Question
How to measure RPM on new Saito 62A
This is probably a stupid question, but I'm getting ready to break in my new Saito 62A and the instructions say to keep under 4K RPM for the first 10 minutes. Easy enough if you can measure the RPM, but how do you do that? Do I need some special piece of equipment?
This is my first 4-stroke engine ever.
TIA
Andrew
swrocket is online now Find More Posts by swrocket
Old Mar 27, 2015, 06:33 AM
I TOBOR's Avatar
Joined Feb 2007
You need a tachometer, both for the break in and tuning the high speed before you fly. That first 10 minutes is with the throttle between 1/4 and 1/3rd open. I have a procedure I follow that worked about 35 times on Saito break in. I run the engine at 10 minutes at
4,000
5,000
6,000
7,000 then top off fuel and then run at varying speeds between, your choice and full throttle. Set needle somewhere in this procedure. Lots of help available here from sperienced guys. The .62 is a sweetheart of an engine The reason I do it this way is because the Horizon instruction are non existent beyond the 4,000 rpm.
I TOBOR is offline Find More Posts by I TOBOR
Old Mar 27, 2015, 06:37 AM
I TOBOR's Avatar
Joined Feb 2007
There are some good choices here, I use this one but its 89 bucks and reads exactly the same as the GloBee.
http://www3.towerhobbies.com/cgi-bin...RCH=tachometer
Old Mar 27, 2015, 07:20 AM
United States, NY, Ithaca
Joined Sep 2007
Yeah, I've been using the Hobbico tach for at least 20 years. It checks out with the florescent lights perfectly. The figures I get for my engines are consistent with what others get. I've always trusted it and used it for Saito break-in among other things...25 bucks. You should buy one.
Jim
buzzard bait is offline Find More Posts by buzzard bait
Old Mar 27, 2015, 07:28 AM
Back after 30 years
Canada, ON, Vaughan
Joined Mar 2015
Thanks so much guys. I'll research the tachs you mentioned and order one.
Back in the day I only ran 2 stroke and never had a tach or anything. Just start it, fast idle for a few minutes, tune and fly.
Old Mar 27, 2015, 07:31 AM
Back after 30 years
Canada, ON, Vaughan
Joined Mar 2015
4,000
5,000
6,000
Thanks for the detailed instructions, it sure helps to have expert guidance. I will follow this process.
Old Mar 27, 2015, 09:12 AM
I TOBOR's Avatar
Joined Feb 2007
One thing you'll notice if you use this method, it won't stay at the rpm you set, for example usually during the 5,000 rpm run the rpm will slowly increase to about 5,500. Don't worry about, it's just loosening up, ring sealing better etc. Some engine do it at different rpm, the Saito 1.00 twin I just got did most of the increasing during the 4,000 rpm run, it only increased about 100 rpm during the 5,000 rpm run.
For Sale Power Supplies $30 12v 62A 750w $60 24v 62A 1500w $90 36v 62A 2250w icecube57 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 24, 2014 03:36 PM
Discussion How to measure IR on a lipo battery bansheerider Batteries and Chargers 23 Jul 26, 2014 05:31 PM
Discussion How to accurately measure RPM on multi blades rotor S_YORAM1@BEZEQIN 3D Fuel Heli Flying 1 Aug 18, 2010 12:05 AM
Discussion How to use Brushless Sensor to measure RPM on Spark Ignition Gas motor? ebourlet Eagle Tree Systems 2 Nov 17, 2009 10:22 PM
Alert My new test stand measures effciency by using torque and rpm measurements. simo10 Power Systems 37 Aug 05, 2007 07:01 PM
