Old Mar 29, 2015, 09:29 AM
old_coastie is offline
Find More Posts by old_coastie
"Some do, some don't"
old_coastie's Avatar
United States, MI, Grand Rapids
Joined Jul 2013
Sawn Craft Paper Airplane (Not Really Paper)
Greetings All,
Just thought I would post a couple of videos of a rather "out of the ordinary" kit available from Sawn Craft...
How does a 4 ft long, 24" WS foam model of a "Paper Airplane" sound...
Finally got to maiden this plane yesterday and had a blast with it...
Pics and Videos below...
Will post more details if there is any interest...
Mark R.
old_coastie
Sawn Craft SEFF Edition Paper Airplane 2nd Flight (7 min 39 sec)
SawnCraft Paper Airplane Maiden (7 min 42 sec)
old_coastie is offline Find More Posts by old_coastie
Old Mar 29, 2015, 07:42 PM
Sawn Craft is offline
Find More Posts by Sawn Craft
AMA 415
Sawn Craft's Avatar
United States, CT, Granby
Joined Mar 2012
Thanks for posting the videos, old_coastie! Looking good!
Sawn Craft is offline Find More Posts by Sawn Craft
Old Mar 29, 2015, 07:58 PM
Joined Jul 2013
Heck I just built and flew it, Ya'll put the magic in it... Thanks for a Fun Plane..
Mark R.
old_coastie
Old Mar 30, 2015, 02:24 PM
Barry Leger is offline
Find More Posts by Barry Leger
Barry Leger's Avatar
Canada
Joined Nov 2004
Awesome, I just ordered one of these (my first foamy), looks like a lot of fun. Thanks for the videos, you really show off the flight envelope nicely. If you have any build pics, that would be great, too.
Was thinking of adding a rudder and I'll probably use an Orange stabilizing receiver too, that might help in a light breeze, especially at high alpha, low speed flight. In the video, it seems to really want to roll and lose altitude when turning, so using a rudder for more flat turns should make for an interesting experiment.
It floats so easily, at 600 square inches, I think I might be able to catch a thermal!
Barry Leger is offline Find More Posts by Barry Leger
Old Mar 30, 2015, 03:23 PM
Joined Jul 2013
Sorry no build pics, but it does come with a build manual, and it is a pretty straight forward build...
So far I have resisted the urge to install a rudder, but pretty sure that is gonna happen, but plan ahead getting the CG right on this one is important and the tail is a long way from the CG point so gonna have to shift weight forward or my favorite solution use a bigger battery ...
Mark R.
old_coastie
Old Apr 01, 2015, 05:51 AM
Joined Jul 2013
FYI
Going with a 3S batt and a APC 7 X 6E Prop adds a considerable "Holy Crap" factor to this plane...
Mark R.
old_coastie
Old Apr 02, 2015, 01:20 PM
Joined Jul 2013
Not that anybody is really reading this, but just for completeness sake...
Sawn Craft SEFF Edition Paper Airplane (2015)
Length 48"
WS 24"
Wing Surface area aprox. 600 sq in. (FYI my math makes it 588 sq in.)
Hobbymate H2827 1450 Kv Motor (44 gr 18A Max)
Batt 2S Eflite 1350 mAh
Batt 3S Glacier 1000 mAh
Prop (2S) 7.75 X 6 (Cut Down from GWS 10 X 6)
Prop (3S) APC 7 X 6E
ESC Turnigy Plush 30A
RX Lemon 6 Ch Feather Lite
Servo (2) HXT500 Elevons
AUW Original: 375 gr with 1350 mAh batt
Static Power Test:
2S = 106 Watts, 13.6 Amps 7.75 x 6 Prop
3S = 168 Watts, 12.7 Amps 7 X 6E Prop
Mods
Rudder (1) HXT900
Pending LED's
AUW post Rudder Mod (Rudder Mod added aprox. 25 gr)
2S 400 gr
3S 420 gr
Note: Original 2S config balanced perfectly with no ballast required. Post Rudder Mod 2S Config needs aprox 10 gr lead ballast forward to maintain CG, 3S config needs aprox 5 gr ballast aft to maintain CG...
Mark R.
old_coastie
Old Apr 03, 2015, 08:05 AM
Joined Jul 2013
3S With Rudder Mod
Need to get this back out to the Club field with a lot of room, WOT with 3S will let this plane move rather quickly..
Rudder Mod added weight but was worth it for enhanced yaw control (i.e. it turns easier)
Mark R.
old_coastie
Sawn Craft Paper Airplane 3S with Rudder Mod (6 min 59 sec)
Old Apr 03, 2015, 10:12 AM
AMA 415
Sawn Craft's Avatar
Joined Mar 2012
That thing looks like it really gets moving when you get into the throttle! Nice work on the rudder mod; do you think you could post a photo or two so we can see where you made the cuts and mounted the servo?
Old Apr 03, 2015, 11:30 AM
Joined Jul 2013
Roger that, should have up later this evening..
Yeah going WOT in straight and level flight was kinda surprising.. First thought was "Cool", second thought was "Gonna need a bigger field"
Old Apr 05, 2015, 11:23 AM
Joined Jul 2013
2S vs. 3S Speed Runs and Rudder Pics
Took a bit to get back to this...
Anyway, Weather was good this morning so decided to head out to the field for some extra space to open this plane up on 3S, also got some pics of the rudder mod.
Mark R.
old_coastie
Sawn Craft Paper Airplane 2S Speed Run (6 min 14 sec)
Sawn Craft Paper Airplane 3S Speed Run (7 min 6 sec)
Old Apr 07, 2015, 02:01 PM
Canada
Joined Nov 2004
I'm sold, when I start building mine, it's getting a rudder. The slow speed flight appears much, much better with rudder control. Nice job!
Old Apr 07, 2015, 02:39 PM
Joined Jul 2013
My feelings exactly, if you are running it in "Jet" mode, the rudder isn't really necessary, but in High Alpha (which is a lot of fun) the rudder really helps..
Just remembered that you mentioned an Orange Stab, have you looked at the Lemon 7 Ch Combination RX and Stab... less than $20 and has a strong following here on RCGroups...
Old Apr 08, 2015, 08:09 AM
Canada
Joined Nov 2004
Thanks for the tip, I had never heard of the Lemon products before. I'll definitely check it out!
Old Apr 08, 2015, 03:48 PM
Joined Jul 2013
In case you get bored....
Plenty of reading and testimonials here...
http://www.rcgroups.com/forums/showthread.php?t=2164243
Mark R.
old_coastie (Dedicated Lemon Head)
New Product Sawn Craft Micro F-22 Sawn Craft Scratchbuilt Indoor and Micro Models 6 Apr 04, 2015 12:55 PM
New Product Sawn Craft Mini Mana-Tee - Now Shipping! Sawn Craft Scratchbuilt Indoor and Micro Models 24 Dec 30, 2014 05:23 AM
Yippee! Sawn Craft Monthly Giveaway! Sawn Craft Vendor Talk 7 Apr 02, 2014 06:43 AM
Discussion Not your grandfather's paper airplane (or RC paper plane) caseih Parkflyers 16 Jun 02, 2007 08:53 PM
