Old Jan 01, 2015, 08:19 PM
mchadwick63 is offline
Find More Posts by mchadwick63
Joined Sep 2011
Redwing Slick 76" all Electric Build Log
I purchased the Green Version of the Redwing Slick a few months back and just now found the time to build this bad boy.
I have heard nothing but excellent reviews on this plane.
This build will be ALL electric. Motrolfly with ZTW Gecko 155 all on 6s power.
Opening the box and looking at the components, design and craftsmanship it should not disappoint!
mchadwick63 is offline Find More Posts by mchadwick63
Old Jan 01, 2015, 08:25 PM
Joined Sep 2011
A loose test fit of the components and I get even a bit more excited to get this bird in the air. Control surface throws look great The fit of the cowl, wings and canopy are right on.
Old Jan 01, 2015, 08:45 PM
Joined Sep 2011
There were some old comments on the hinge quality an many ARFs. I had some Robarts handy so I compared the quality. The free play and the pin diameter are the same.
The new Redwing hinge points were of equal quality to the Robarts so the supplied hinges are going on this plane!
By the way, the White are Redwing and the Gray are Robart
Old Jan 01, 2015, 09:13 PM
Joined Sep 2011
The power system was noted in the first post. I am using all XQ Power servos on this build. The 4xxx series digitals have been solid on all the planes I have seen locally. The feedback on the web is positive on all the XQ-4xxx servos. Redwing sells and supports them well and I bought them as a package with the plane. XD-40xx servos are rated to 6 volt. I chose the XD-41xx series as they are good to 8.4 volts. The Gecko ESC has a BEC built in that can be programmed up to 8.4 volts so they were a perfect match.
Old Jan 02, 2015, 08:07 AM
DonQ8401 is online now
Find More Posts by DonQ8401
Why am I addicted!!!
DonQ8401's Avatar
United States, IL, Columbia
Mchad,
Do you have pictures of the motor setup yet? I would like to know how your going to build the motor stand? On my servos I like to reinforce them with epoxy all around the servo wooden box. Thanks
DonQ8401 is online now Find More Posts by DonQ8401
Old Jan 02, 2015, 05:30 PM
Joined Sep 2011
I am glad you asked about the servo box. I sometimes known as Mr. Overkill.
I made a little PDF of the servo tray mod. All you have to do is cut some wood stock as I have listed and the update only takes 15 minutes or so. Lets see if the PDF is viewable!!
Just in case it does not open I put the exact same info in the next 4 or 5 posts.
Old Jan 02, 2015, 05:34 PM
Joined Sep 2011
Cut (4) pieces 1/8 x 5/16 x 1-1/8 Ply, (4) pieces 1/8 x 3/8 x 2-3/8 ply and (4) pieces 1/4 square x 7/8 long hardwood.
First Test fit servo in servo mount. Then remove servo and set aside until the last step
Old Jan 02, 2015, 05:36 PM
Joined Sep 2011
Using ample amounts of medium CA glue the 1/8 x 5/16 x 1-1/8 ply as doublers for the servo screws on the inside as shown. Next glue the 1/4 square hardwood bocks as shown applying medium CA to the bottom, side and front surfaces. Both blocks will bump up against the ply doublers you just installed.
Old Jan 02, 2015, 05:37 PM
Joined Sep 2011
Mark 3/8 from each edge of the main panel to help with centering of the long ply parts. With just two drops of medium CA tack glue the two long ply strips parallel to the main panel and touching the servo mount upright. Test fit in actual wing panel before firmly gluing in place.
Old Jan 02, 2015, 05:38 PM
Joined Sep 2011
After test fitting hit joint with thin CA. Follow up by filleting all joints with medium CA. After CA is cured you are ready to reinstall the servo.
Old Jan 02, 2015, 05:42 PM
Joined Sep 2011
The finished product looks like this. You can do this about as fast as you can read it.
Plenty of things will break before this does!!
Old Jan 02, 2015, 05:51 PM
Joined Sep 2011
You may have seen my extra build that had a motor box extension. I mocked up the plane and found that the CG will be perfect with the battery in the stock motor box and is easily accessible through the canopy. I am using the magnetic setup for the hatch and the two lower points in the cowl.
This plane will be the smoothest e-conversion ever. There is nothing to change. No reason to mess with perfection!
Old Jan 02, 2015, 06:08 PM
Joined Sep 2011
So the XQ 4116 look like this;
•Gear Style: Futaba Arms
•Gear Type: Metal - Titanium
•Weight: 1.46oz (56g)
•Size: 40x20x39mm
•Torque: 8.5v - 234 oz/in (16.9 kg/cm), 7.2v - 205 oz/in (14.8 kg/cm)
•Speed: 8.5v - .11 sec, 7.2v - .13 sec
At $45 each these are the best value out there hands down. I typically buy Hitec and Savox but these are quick, smooth and have been holding up well.
I am using the XQ-4120 for the rudder at 291 oz/in on the 8.4 volt setup for $48 each.
Old Jan 02, 2015, 08:48 PM
DonQ8401's Avatar
Good job Mchad! Thank for the info...
Old Jan 04, 2015, 01:13 PM
Joined Sep 2011
So lets Mount the Motor. I made the extension from .063 Aluminum formed three sided box. I think this has much less flex over standoffs and about the same weight. If I remove some material with lightening holes it would be even lighter. Duh....
New Product Redwing R/C 30cc Extra 330SC unboxing and build log RC30Flyer Giant Scale Airplanes 235 Dec 26, 2014 12:23 PM
Sold Redwing Extra 76" with Hacker Electric PNP mchadwick63 Aircraft - Electric - Airplanes (FS/W) 0 Dec 13, 2014 11:52 AM
Discussion Redwing 76" Extra 330 Build/Mod Hacker mchadwick63 3D Flying 160 Nov 26, 2014 01:09 PM
Discussion *Redwing RC 50cc Slick 540 Electric Build* olezippi Giant Electric Planes 64 Oct 27, 2014 05:23 PM
Discussion Redwing Electric 76" build mchadwick63 Sport Planes 0 Aug 04, 2014 06:21 PM
