Old Apr 16, 2014, 07:42 PM
MEGAjig is offline
Find More Posts by MEGAjig
"I landed it"
MEGAjig's Avatar
Canada, ON, Caledon
Joined Mar 2013
Glider Vertical Landing
I have been teaching my uncle how to fly his 1600mm phoenix glider. He has come a long way and has about 2.5 hours of in air flight time while tethered to me. He can fly pretty well for the most part but we never got around to practicing the landing aspect. We tried once and he would panic and I would have to take over. Well today he got impatient and decided to go out flying by himself. This is the result of impatience...
Surprisingly the plane held up pretty well. A little hot glue and she should be up in the air pretty soon.
MEGAjig is offline Find More Posts by MEGAjig
Old Apr 16, 2014, 08:11 PM
suddenstop is offline
Find More Posts by suddenstop
...one of my nicer landings
United States, WA, Walla Walla
Joined Mar 2014
Did he walk away in good health from it?
suddenstop is offline Find More Posts by suddenstop
Old Apr 16, 2014, 11:16 PM
Brynmr is offline
Find More Posts by Brynmr
Brynmr's Avatar
United States, SC, Liberty
Joined Dec 2013
That's what I call, sticking it.
Brynmr is offline Find More Posts by Brynmr
Old Apr 16, 2014, 11:54 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Or a spot landing...
A10FLYR is offline Find More Posts by A10FLYR
Old Apr 17, 2014, 02:58 AM
closedloop is offline
Find More Posts by closedloop
Fiddy Killa Voltz
United States, NM, Albuquerque
Joined Nov 2011
Well, which box did you hold? I know some trainer boxes don't use the mixes of the master, so perhaps the landing mix that was required (F-E, F-A) wasn't working on his TX. That would make things more interesting.
I'm happy things survived, needing only some TLC and CA.
closedloop is offline Find More Posts by closedloop
Old Apr 17, 2014, 09:38 AM
davidjensen is online now
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
I think he ran out of Altitude, Air speed and Ideas all at the same time.
davidjensen is online now Find More Posts by davidjensen
Old Apr 17, 2014, 09:43 AM
theghosttanker is offline
Find More Posts by theghosttanker
United States, NY, Lewiston
Joined Apr 2011
Back in the day when all we had were woodies, this kind of landing was referred to as "planting the balsa tree".
theghosttanker is offline Find More Posts by theghosttanker
Old Apr 17, 2014, 11:51 PM
cityevader is online now
Find More Posts by cityevader
IT'S NOSE HEAVY!!!!!!!
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
Straight in is often best (not counting on the belly proper).
I did the very same thing with my Passer when i "free-flighted" it tossing it off the slope with the switch off... lawn dart style with hardly a scratch.
cityevader is online now Find More Posts by cityevader
Old Apr 18, 2014, 08:53 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
That is an impressive landing. I am very surprised that you say it did not sustain much damage. I would have expected significant compression of the foam causing the fuse or the nose to be out of alignment. Don't ask me how I know.
I am sure you are doing an excellent job of teaching. Perhaps you do this and perhaps you don't. But it might help your student with his landings.
When I am teaching flight with 3 channel parkflyer electric or a glider, on the first demo flight I get it up, get it trimmed, turned into the wind then hold the radio in one hand and spread them wide to demonstrate that the plane knows how to fly, that most of what we do is disrupt its flight.
When I am teaching landing, especially landing gliders, I get them on a LONG approach and just float it in, power off. In fact when I demonstrate the landing approach I get the glider on final glide then hold my hands wide to emphasize that that most inputs are not needed. I just let it float in with no input from me.
I can do that with my Radian, my Supra and any other glider I own.
My experience is that new pilots, especially new glider pilots, want to over control and usually pull elevator at the wrong time during landing, causing a stall and a crash.
So, FWIW, once turned into the wind on final, the glider should be able to land itself. If it does not it is not properly trimmed. You may have to take a walk to get it but landing safely is more important than landing close.
Try that as a demonstration. It is VERY effective in teaching landings for a glider.
Of course that assumes your glider is well trimmed, you are landing into the wind and you are not teaching a newbie how to fly in high or gusty winds.
aeajr is offline Find More Posts by aeajr
Old Apr 18, 2014, 11:35 PM
KiwiKid is online now
Find More Posts by KiwiKid
Keep calm and don't blink
KiwiKid's Avatar
Hamilton, New Zealand
Joined Jun 2005
When you get really good you can progress to doing landings like this
KiwiKid is online now Find More Posts by KiwiKid
Old Apr 19, 2014, 12:47 AM
cityevader's Avatar
Joined Mar 2012
fin isn't square
Old Apr 19, 2014, 10:54 AM
Joined Mar 2014
What might help is if new RC pilots spent a little time landing a in a small trainer plane like a Cessna 152. Go to local airport and look for flight training. Usually for less than $100 you can take an introductory ride. You will usually get to fly the plane... takeoff and landing with assist as well as be introduced to flight theory. You will learn the value of preflight inspections. I have made up a preflight and postflight checklist as if I were about to fly a "real" plane.
Get a flight training book and learn the traffic pattern around an airport runway. The pattern accounts for wind direction leading to consistently repeatable takeoffs, approaches and landings. Learn about aerodynamics and flight. Then visualize yourself as you fly the RC as if it were a "real" flight taking care to pilot as if you were in a "real" plane. It may help prevent crashes if you determine if it were a real plane you might not have walked away.
Old Apr 19, 2014, 10:57 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Not a bad idea to get a lesson in a full scale aircraft but it is much simpler than that.
http://www.rcgroups.com/forums/showp...47&postcount=9
Old Apr 19, 2014, 05:17 PM
Joined Mar 2014
Originally Posted by cityevader View Post
fin isn't square
Old Apr 19, 2014, 05:22 PM
Joined Mar 2014
Your points are well taken and would be useful if your advice were heeded.
It is a cool thing to fly or approach to land in coordinated flight - hands off - in a real airplane. It gives you a real sense of what a plane does and wants to remain positively statically stable. And besides, fool around and stall spin at a low enough altitude and you can ask God Himself in person what happened.
Discussion Zeta Science Sky Observer Skylark vertical landing UAV FPV Plane Dogdude FPV Aircraft 47 Mar 30, 2015 11:54 AM
Build Log Octocopter Rocket / Vertical Landing Rocket - Velocity VL brandonppr Scratchbuilt Multirotors 30 Feb 05, 2014 10:22 PM
Discussion f35 vertical take off , vertical landing f35vertical Electric Ducted Fan Jet Talk 22 Oct 14, 2012 10:39 AM
Discussion f35 vertical take off , vertical landing f35vertical Electric Ducted Fan Jet Talk 13 Jun 21, 2012 03:13 PM
Discussion f35 vertical take off, vertical landing. f35vertical Electric Motor Design and Construction 6 May 30, 2012 03:20 AM
