Old May 23, 2013, 06:41 AM
377 beeatch!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Fill up the scorcher tips too and put in the servo frames while your at it. I want closer to 400 now!
josh18 is online now Find More Posts by josh18
Old May 23, 2013, 07:02 AM
PB of 733kph
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
Lol ok, first priority in the K130 though. If I get time, I will do the Scorcher as well
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old May 23, 2013, 07:23 AM
377 beeatch!
josh18's Avatar
Joined Jan 2010
It'll make a good backup plane.
Old May 23, 2013, 08:03 AM
PB of 733kph
Joined Jul 2005
I'll get some weight in it even if it is up the hill on the day
Old Jan 06, 2015, 04:20 PM
PB of 733kph
Joined Jul 2005
So this plane still lives. Last outing required taking servos out as the pins bent for the third time, but also broke a flap half off at the hinge. Need to get the flaps away nice and early. Pins are easy to replace in the servos. Am going to split the flaps
When I put the servos back in
Have two spare servos too so next time if it happens again I can replace them up the hill to get back in the air again
Old Jan 06, 2015, 05:25 PM
sll914's Avatar
Joined Oct 2003
Hey Alex,
You ought to take some good measurements on the pins and order some higher quality hardened steel pins to replace them. The stock pins are really soft mild steel. If you send the measurements, I'll see what it would take to get some better pins sent down to you... It would only be the cost to send a small envelope. Otherwise, I assume you have a supplier similar to McMaster Carr in NZ...??
sll914 is offline Find More Posts by sll914
Old Jan 06, 2015, 05:39 PM
PB of 733kph
Joined Jul 2005
I would rather the pins bend and save the flaps. They are easy to replace. The gear teeth also bend, so have had to manipulate and work those back to mesh nicely. Made new stainless pins at work. Should be a nice strength to allow them to bend and save the servo. Am happy with my set-up
Old Jan 06, 2015, 06:46 PM
Heavy's good, heavy's reliable
BDK74's Avatar
United States, CA, Redondo Beach
Joined Sep 2012
What are the pins for?
Nice job getting the servos out. If that were me you wouldn't be able to identify what it was!!!
BDK74 is offline Find More Posts by BDK74
Old Jan 06, 2015, 07:07 PM
377 beeatch!
josh18's Avatar
Joined Jan 2010
Hey Alex, I had to replace my 9411 flap servo on mine, as even though the pin was straight it had ovalised the hole in the case, making it un usable. I too would rather the pins bend rather than wreck the case, as long as not in flight!
I did notice on mine that the pins don't insert very far into the case holes, so your ground pointy ended pins might not be getting a very good purchase in the hole, though this was on a different servo.
Cheers
Josh
Old Jan 06, 2015, 08:26 PM
PB of 733kph
Joined Jul 2005
THat pointy pin is a bit longer in hope it would jam itself up into the bottom of the hole to secure it better.
These are ATX 94820 servos
Old Jan 06, 2015, 11:27 PM
377 beeatch!
josh18's Avatar
Joined Jan 2010
Ah cool, it thought you were using 3421s so there would be a JR family resemblance.
Old Jan 06, 2015, 11:45 PM
United States, CA, Napa
Joined Dec 2010
Same question . . . what are the pins for?
Using for control linkage? Servo bracing?
Scott
curdman is offline Find More Posts by curdman
Old Jan 07, 2015, 12:25 AM
377 beeatch!
josh18's Avatar
Joined Jan 2010
Hey, they are the pins the gears spin on inside the servo.
Cheers
Old Jan 07, 2015, 12:51 AM
Joined Dec 2010
Ah servo guts . . .
holy crap that's some torque!
Thanks.
Discussion Transall C-160 build log ecworks RC Airliners (Commercial, Cargo, Troop Carrier) 109 Aug 21, 2014 11:51 AM
Discussion Evolution 3- the E Pluribus Unum DLG group build log Traian Hand Launch 913 Jul 29, 2014 11:38 PM
Discussion Gas Generator... Build Log... EddieWeeks Multirotor Talk 110 Apr 21, 2013 07:42 PM
Build Log RCtimer S800 Build log CarterDave060 Multirotor Talk 36 Jan 11, 2013 05:01 PM
