Old May 25, 2015, 08:10 PM
Ed Crowell is offline
Find More Posts by Ed Crowell
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
The last few day I have spent some time on and off making 6 portholes for the hull. After turning them I made a jig to hold them in the vice to drill 8 small holes (.025) in each one. I used a bolt circle program to calculate the positions of the holes. Then used my milling machine and a digital readout to drill the holes. The portholes are smaller than a dime. It was very time consuming. After the hull is painted the port holes will be glued and pined to the hull.
Ed
Ed Crowell is offline Find More Posts by Ed Crowell
Old May 25, 2015, 08:20 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Half Moon Bay
Joined Aug 2009
That looks Perfect, they will compliment the hull Well ~
Tim B. is offline Find More Posts by Tim B.
Old May 26, 2015, 01:26 AM
P_J_Glor is offline
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Agreed! Another masterpiece in the works!
P_J_Glor is offline Find More Posts by P_J_Glor
Old May 26, 2015, 01:31 AM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Very nice Ed. They look great.
norgale is offline Find More Posts by norgale
Old May 27, 2015, 02:10 PM
GPR is offline
GPR
Find More Posts by GPR
GPR
GPR's Avatar
Rochester, Michigan
Joined Jan 2009
Ed, I love the work you do with a lathe and mill. Very time consuming but the results are worth it for sure!
GPR is offline Find More Posts by GPR
Old May 27, 2015, 09:08 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Thank's for the comments I appreciate them.
Ed
Old Jun 26, 2015, 06:05 PM
Ed Crowell's Avatar
Southern Calif
Joined Dec 2005
Before the raised deck is installed I made a compartment for ballast. I also epoxied a board onto one of the frames with a slot in it to capture a plywood panel for the electronics to be mounted onto.
The raised deck is epoxied to the frames with West Systems epoxy and fared to the hull. I had to use some Bondo to fare the deck to the hull.
The last picture shows the plywood panel in place over the ballast compartment. It will be secured with a thumb screw.
The next step is to fiber glass the deck.
Old Jun 26, 2015, 06:15 PM
Tim B. is offline
Tim B.'s Avatar
Joined Aug 2009
Man that's the Cleanest interior I've ever seen ~
Help! Hanseat 51" luxury cruiser deck plan modelmaker46 Dock Talk 6 Feb 26, 2014 12:10 AM
Build Log '20s style raised deck cruiser moTthediesel Scale Boats 121 Dec 05, 2012 06:55 AM
Build Log Bridge Deck cabin cruiser crazy yank Scale Boats 19 Jun 14, 2010 02:16 PM
