Old Sep 16, 2014, 09:28 AM
32Ford's Avatar
Claremore, Oklahoma
Joined Nov 2005
Great Planes Escapade Sport GP/EP Choices
I recently purchased an Escapade sport a RimFire 46 800kv motor and plan on using a Eflite Pro 60A ESC and either TP 4S or 6S 45C 3300 battery. My confusion comes from the published data that Tower and the Escapade manual conflict somewhat. The manual suggests the Rimfire 46, 4S 3300 battery, their 60A ESC and swinging a 12X6 prop. The ElectriFly web page suggests a 60A ESC, 6S battery and 10X5 to 11X5 prop.
I'm looking for the performance my Pulse XT25 has with the Power 32 on a TP 4S 3300 swinging a 13X6.5 prop using 60A ESC. I get a solid 7 minute flight and generally put back in around 2100. I generally just cruise around a tad over half throttle but it has the power for near unlimited vertical performance which makes it fun to fly. What I don't like is it's light wing loading on windy days.
Data Logger stats for the Pulse are 44A, 640W, average speed of 90mph
My question is what do you guys suggest on battery configuration and prop size for the RimFire 46??
Thanks in advance!
Jim....
32Ford is online now Find More Posts by 32Ford
Old Sep 23, 2014, 01:52 AM
Hemet, California, United States
Joined Aug 2001
I fly mine on the stock Rimfire motor, ESC, 4S 4400 40C batteries, and the recommended APC prop. Performance is excellent and I set my timer for 5:30. I have a heavy thumb so better throttle management would get you some more time.
Good luck!
mickydee is online now Find More Posts by mickydee
Old Sep 23, 2014, 09:25 PM
Canada, MB, Steinbach
Joined Jul 2011
I intend to fly my escapade with the same 46 rimfire & ESC but I want to use 6S 3300 or 5S 4500 both of which I have. I hope this doesn't make the plane come apart due to speed. I notice that the plane doesn't have much aileron throw although it is almost full length aileron. I'm thinking I can dremel out a little more room on the control arm hole if need be..
zamjohn is offline Find More Posts by zamjohn
Old Sep 24, 2014, 02:41 PM
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
I have had this plane with the same 46 rimfire motor, I used both setups of 4 and 5.
4 cell 12x6 prop,60 amp esc setup is ok and fun to fly, but once you go 5cell you will not go back to the 4 cells, I don't recall the flight times but around 5/6 mns on mine.
not sure on the 6 cell setup or what prop to use but there is a flying buddy using the rimfire motor in a rv8 on 6 cells and I think with a 11x6 prop and its very fast.
I suggest a 5 cell setup and a 11x6 prop with the 60 amp esc.
scottc39 is offline Find More Posts by scottc39
Old Sep 24, 2014, 08:25 PM
Joined Jul 2011
I was kind of thinking that the 6S might be a bit fast for the escapade not knowing whether everything is glued, re-inforced good enough and whether the hinges would withstand the stress placed on them. I know its a bit overkill but I'm installing an 80Amp esc because I have a new one laying around. Also thanks for the info on which props I might need for the different batt. sizes.
New Product Great Planes Escapade MX ARF GP/EP lfd47 Sport Planes 315 Oct 02, 2014 07:35 PM
Review Great Planes Escapade Mx GP/EP ARF pda4you Sport Planes 15 Apr 12, 2014 04:46 PM
For Sale RC Plane Great Planes Escapade Sport GP/EP (Plug-N-Play) $175 Diverrcpilot Aircraft - Electric - Airplanes (FS/W) 0 Mar 24, 2012 02:50 PM
Sold NIB Great Planes Escapade Low Wing Sport GP/EP ARF 52.5" - $115 shipped nik112233 Aircraft - Electric - Airplanes (FS/W) 5 Aug 29, 2009 09:41 PM
Sold NIB Great Planes Escapade Low Wing Sport GP/EP ARF 52.5" - $115 shipped nik112233 Aircraft - Fuel - Airplanes (FS/W) 5 Aug 29, 2009 09:40 PM
