Old Sep 23, 2014, 12:41 PM
Exodus 4:13
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
7mm pinch on that efflux tube...wonder if anything can be optimized on that for some more push
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Sep 23, 2014, 12:56 PM
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Trenton
Joined Jan 2004
Wow and thanks. The efflux tube steps down from 30mm to 21mm (internally?) then opens to 27mm at the end of the fuselage or do I misunderstand? I ask because I'm thinking of using the internals/electronics /EDF for a scratch build.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Latest blog entry: Split elevator set up JR 9303
Old Sep 23, 2014, 01:08 PM
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
The 21/27mm measurements are the inside diameter and outside diameter, both measured at the very end of the exhaust tube.
pugsam is offline Find More Posts by pugsam
Last edited by pugsam; Sep 23, 2014 at 01:12 PM. Reason: Ben is really slow today..... :-)
Exodus 4:13
bhoov128's Avatar
Joined May 2012
28mm fan, 21mm outlet. The 27mm measurement is the outer diameter of the efflux tube, so the foam has a 3mm thickness.
Old Sep 23, 2014, 02:15 PM
Joined Jan 2004
Thank you to both of you for clarifying that. Exactly what I needed to know.
For Sale UMX BEAST 3D with AS3X with 3 batts tsecrist Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Sep 28, 2013 09:44 PM
As3x umx gee bee for a As3x umx beast 3d Tyler83 Non R/C Items (FS/W) 2 Jun 05, 2013 11:44 AM
Sold LOWERED PRICE UMX Sbach with custom as3x w/ 3 batts and charger Drewkc Aircraft - Electric - Airplanes (FS/W) 0 Mar 08, 2013 09:46 PM
For Sale UMX Sbach with custom as3x w/ 3 batts and charger Drewkc Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 06, 2013 10:32 PM
Sold E-Flite UMX Sbach 342 3D (AS3X) with spares kellymacdaddio Aircraft - Electric - Airplanes (FS/W) 2 Feb 26, 2013 10:36 PM
