Old Jan 21, 2015, 12:00 AM
Joined Oct 2007
EPF New Alloy EDF Unit for popular motor
EPF HOBBY New Alloy EDF Unit for popular motor
Apollo Series 90mm
Motor size: 42mm max.
Motor Shaft size 5 or 6mm
Inside Diameter 90mm
Outside Diameter 99mm
Rotor: 12 blade (89mm) dynamically balanced
Material: Aluminum
Weight: 221g
EPF HOBBY is offline Find More Posts by EPF HOBBY
Old Jan 21, 2015, 07:54 AM
Callington South Australia
Joined Mar 2006
When will these be available and what is the cost ?
Loco1 is offline Find More Posts by Loco1
Old Jan 21, 2015, 08:14 AM
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Very interesting!
4stripes is offline Find More Posts by 4stripes
Old Jan 21, 2015, 09:00 AM
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
Looks high tech.
juanjulian is offline Find More Posts by juanjulian
Old Jan 21, 2015, 02:00 PM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Any performance numbers?
Bob
bruff is online now Find More Posts by bruff
Old Jan 21, 2015, 03:09 PM
4stripes's Avatar
Joined Jan 2009
You would need a motor in it first!
Their other 90mm 8S Mercury alloy fan with its own proprietary Outrunner is a very good setup.
Old Jan 21, 2015, 08:11 PM
Joined Oct 2007
It is available now.
http://www.epf.com.tw/goods.php?id=180
Old Jan 21, 2015, 08:17 PM
Joined Oct 2007
There is 2 bearing in the front and back side of blade.
The blade has good support.
The motor can be got good cooling in front of the EDF unit.
EPF HOBBY Apollo EDF unit Part I (0 min 16 sec)
Old Jan 26, 2015, 11:02 AM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Pretty neat...pusher type fan I see. I have the Stumax 110 which is a pusher and I like that the motor wiring is toward the nose of the plane. Would like to see some numbers on the fan if anyone gives it a try. Like to try the HET 2100 on 6s on this setup.
EPF Hobby are you saying there are 4 bearings...two in front and two in back?
Madmax1965 is online now Find More Posts by Madmax1965
Old Jan 26, 2015, 03:44 PM
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
All the extraneous weight and the motor up front is going to make the aircraft difficult to CG.
Many fully ducted jets, that have the ducts (if there's 2 of them) converge just a head of the EDF. This will be difficult with the motor there.
I suppose a foamy with no ducts, and can be modded to move the fan aft, would work.
What purpose does the tail cone serve?
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jan 26, 2015, 04:03 PM
4stripes's Avatar
Joined Jan 2009
Good point raised Efflux.
The motor out front may not suit all ducting but for typical foam jets it would be better than their complete motor/fans as the mouth doesn't have that fluted shape.
I think the tail one is just a leftover from the complete unit which has been changed to allow user choice motors.
For the price, I would just get their complete motor/fans. The two I have are great. Nothing comes close in price or workmanship.
Old Jan 26, 2015, 04:10 PM
nerv's Avatar
United States, CA, San Jose
Joined Jan 2007
I don't think it will affect CG much, the heavy part is the motor, not the fan. Yea, u have to move the fan aft alittle to clear the intake, if u have split intakes (not every jets have that config, f16 etc), but don't forget the heavy motor is in front of the fan, not at the back.
nerv is offline Find More Posts by nerv
Old Jan 26, 2015, 06:57 PM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
I am flying the Stumax 110-52 in my Fox Hawk....no problem what so-ever with CG and the Stumax is a pusher with full ducting. I flew my first pusher fan with a Byron F-86(Byron Fan) and had no problem with the CG.......Personally I like the pusher.
For Sale All Alloy Mach 70mm EDF unit + Mega 16/35/1 motor + CC 100ESC by Efflux Gary Shanya Aircraft - Electric - Jets (FS/W) 6 Dec 20, 2014 04:25 AM
For Sale All Alloy Mach 70mm EDF unit + Mega 16/35/1 motor + CC 100ESC by Efflux Gary Shanya Aircraft - Electric - Jets (FS/W) 0 Dec 10, 2014 01:39 AM
For Sale All Alloy Mach 70mm EDF unit + Mega 16/35/1 motor + CC 100ESC by Efflux Gary Shanya Aircraft - Electric - Jets (FS/W) 3 Nov 27, 2014 05:48 AM
Sold 90mm mercury alloy 12 blade edf unit new in box dr.edf Aircraft - Electric - Jets (FS/W) 1 Jan 04, 2014 01:30 AM
for sell Alloy DPS Series 68mm EDF unit with 3580kv Motor - 1000watt jets462 Aircraft - Electric - Power Systems (FS/W) 1 Aug 07, 2013 07:13 PM
