Espritmodel.com Heli Air
Old Jul 07, 2012, 11:03 PM
Joined Jan 2011
What do you think about a carbon tube over the coax to keep it straight? It shouldn't change anything significantly, right?
npre is offline Find More Posts by npre
Old Jul 07, 2012, 11:28 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
It should not.
Hugo
Hugeone is offline Find More Posts by Hugeone
Old Jul 08, 2012, 06:34 AM
USA Beautiful
LexusFPV's Avatar
Joined Feb 2011
Hugo.
I bought a 1.2 Windmill about 5 months ago, and used it on my Lawmate (1.280) 1.2ghz VidTx,
will this Windmill I have work on the new RMRC
"Now includes the original 1280MHz, along with the new 1258MHz frequencies! "
http://www.readymaderc.com/store/ind...roducts_id=914
I want to tryout the newer 1.258 freq.
thanks much
LexusFPV is offline Find More Posts by LexusFPV
Old Jul 08, 2012, 07:00 AM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Yes, it will work, on 1240 as well.
Hugo
Old Jul 15, 2012, 02:30 PM
België, Vlaams Gewest, Kapellen
Joined Jun 2010
i would like to make this antenna, the closest i found in my garage is welding wire from steel with copper clad but its 1.2mm and i would like to make an antenna for 2450mhz what would the dimensions be?
ISI_ is offline Find More Posts by ISI_
Old Jul 16, 2012, 09:46 AM
Micro FPV
Durango Colorado
Joined Sep 2001
All the information on making a windmill is over here. I made a 1280 one last month and it works great.
cactus is offline Find More Posts by cactus
Latest blog entry: FPV mQX
Old Jul 16, 2012, 01:33 PM
Joined Jun 2010
i cannot find the wire needed for this antenna, i have 0.8mm wire but its the wrong wire, you cant even make a straight line with it so i would like to know howmuch % i must change to the dimensions for the 2440mhz
Old Jul 16, 2012, 10:48 PM
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
with a linear antenna like a dipole or inverted v is a patch or biquad best to use for directional use?
i cannot figure out if a biquad is linear or CP? (i am ignorant with this )
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 20, 2012, 11:29 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
A biquad is linear, along with a Vee it make a good linear combo.
ISI, PMed you.
Hugo
Old Jul 20, 2012, 11:31 PM
Adidas4275's Avatar
Joined Mar 2011
Old Jul 21, 2012, 10:08 AM
USA Beautiful
LexusFPV's Avatar
Joined Feb 2011
Hugo,
for Ground use (Summit) will a "V" work ok on the truck (vidTx)?
or shall I use the original (stock) 1.2ghz Lawmate VidTx antenna that came with it?
am planning on using BiQuad on VidRx from RMRC.
Old Jul 21, 2012, 12:35 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Yes, the Vee will do great on the truck.
Hugo
Old Aug 06, 2012, 05:31 PM
Joined Jan 2011
I have a question about fastening the antenna to a surface. I use 910mhz fans on a flying wing, it is mounted slightly above the surface. I see two options here: leave it glued only at the coax, and the antenna to flop around, touching the laminate at one or two places; (even though it's stiff, the 100km/h wind makes it flop around no matter what) or, place dabs of hot glue at 3 to 5 outside lower corners to prevent it wobbling around. Which is better?
Old Aug 06, 2012, 05:52 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
You can use glue, on 900Mhz it have little effect. Tape it down couls be another more removable idea.
Hugo
Old Aug 06, 2012, 05:55 PM
Joined Jan 2011
Thank you very much! And thanks for the fast reply!
Discussion Lawmate 1.2ghz and CP antennas? Does it work. airbagit13 Video Piloting (FPV/RPV) 23 May 20, 2011 06:58 AM
Question upgrade from fp to cp kkfd Electric Heli Talk 2 Apr 08, 2011 07:28 PM
Sold 2 New - TrueRC 900mAh 11.1V 3S1P (Blade CP) SOLD simages Aircraft - Electric - Batteries & Chargers (FS/W) 3 Sep 17, 2008 02:16 PM
New 11.1V 15C 2200mAh packs from TrueRC supi7 Batteries and Chargers 17 Nov 30, 2005 04:55 AM
F/S New powerfull cells and packs from TrueRC supi7 Product Announcements 8 Oct 06, 2005 11:47 PM
