Old May 24, 2013, 04:13 AM
Joined Apr 2013
How to control Martinez v3 gimbal controller with transmitter?
Can someone maybe help me with this problem? I want to control my pitch on my brushless gimbal controller (Martinez v3), but i don't know how to wire it up. And do i need a separate transmitter and receiver to let it work?
Thanks.
muchacho92 is offline Find More Posts by muchacho92
Old Jun 06, 2013, 05:38 PM
megaPRO
megaPRO's Avatar
Joined Feb 2012
Thanks.
Connect A1 and Ground to transmitter channel for tilt and A0 for roll, (NO CONNECT 5V), only ground and signal
megaPRO is offline Find More Posts by megaPRO
Old Jul 05, 2013, 08:37 AM
Joined Apr 2013
Ok, thanks. I did wire it, but it's still not working. I use a Turnigy 9XR transmitter. Anyone knows how to use the pot control on that transmitter?
Old Jul 05, 2013, 08:53 AM
megaPRO
megaPRO's Avatar
Joined Feb 2012
click Absolute o Proportional in the GUI. Test
Old Jul 05, 2013, 09:47 AM
Joined Apr 2013
Thanks. But it's still not working. I tried both settings: absolute and propotional.
Old Jul 05, 2013, 10:18 AM
Joined Apr 2013
Anyone knows where the ground wire need to be?:
Old Jul 05, 2013, 07:22 PM
Flying R/C since 1964
kallend's Avatar
United States, IL, Chicago
Joined Sep 2004
I have a similar problem. My tilt control works (after a fashion) However, the assigned knob on the Tx doesn't control the tilt angle, it controls the rate of change of the tilt angle. Hence unless I can see the gimbal I have no idea in what direction it is facing. All I know is how fast it is moving.
kallend is offline Find More Posts by kallend
Latest blog entry: Using a DX9 to "strobe" LED...
Old Jul 06, 2013, 08:51 AM
megaPRO
megaPRO's Avatar
Joined Feb 2012
"-" negative
Old Jul 06, 2013, 08:54 AM
megaPRO
megaPRO's Avatar
Joined Feb 2012
firmware version of Martinez?
Old Jul 03, 2014, 09:07 AM
Dan Allen
Joined Jan 2013
Question: Can you control the Roll with analog (Potentiometer)?
I have no problem with the tilt control, however my controller often times doesn't level out roll properly. I'm forced to restart the controller and manually holding the IMU level to hopefully get it right.
I tried making a switch between the tilt and roll, so that the PWM signal can swap. But after I set my roll, the moment you switch out the roll resets to default. It's really frustrating since I don't have extra channels (8-channels)
danallen82 is offline Find More Posts by danallen82
Discussion Alexmos and Martinez Gimbal Controllers rumbey Multirotor Electronics 20 Sep 29, 2013 05:23 AM
Help! Martinez-Brushless Gimbal Controller!!! HELP PLEASE Fassett DIY Electronics 8 Jul 05, 2013 03:08 PM
For Sale Martinez Brushless Gimbal controller version V3 Cuba59 Aircraft - Electric - Multirotor (FS/W) 2 Jun 01, 2013 09:45 PM
Sold GoPro Brushless Gimbal with Martinez Controller unfaix Aircraft - Electric - Multirotor (FS/W) 2 May 13, 2013 01:50 PM
Help! Brushless Gimbal V3.0 Controller Module w/ Sensor (Martinez)setBru Fassett DIY Electronics 0 Apr 21, 2013 12:48 AM
