Jan 06, 2012, 11:37 AM
Oakland township, Michigan
Joined Jun 2005
John,
In general, the watts per pound rule is a good starting point, but you also need to consider a few other things as Sam mentioned.
One of them, is keeping the current within reasonable levels. Although I have two 60 amp planes, most of my fleet is proped for about 40 amps, give or take. The reason for doing this is simply to keep pack size manageable as well as the amount of heat generated.
Something else to consider is propeller diameter. For the Mini-Plane, I am planning on using at least a 13" prop, preferably a 14" prop. The reason for wanting to do this is thrust (a large prop can generate a lot of thrust without having the plane be Mach 2 capable, ie. think of a helicopter). Being a biplane, the Mini will be draggy and I would like to use a bigger prop to offset the drag. In order to get the pitch speed I want (about 60 mph in this case) I will probably use a prop with a 10" or 12" pitch. To do this, I will need about 600 watts or so, so a 5S pack at 35 amps will do the trick. To accomplish this, I will use a geared motor with an effective Kv of about 425.
For this plane, I might use a Mega 1625/3 geared 4/1 (600 watt system) or a Mega 2220/3 geared 4/1 (900 watt system). I have not decided yet.
You plane is looking good. As soon as I get a chance, I will post some of mine.
Teo
