Old Nov 25, 2014, 05:05 PM
Marcm1 is offline
Find More Posts by Marcm1
United States, NC, Durham
Joined May 2012
Help!
Newbie .Need help setting up new motor
Ok so I just got this motor that i need help setting up.My parts on the right are what i have but I want my motor to be setup like the picture on the right. Any tutorial or help would be great.I don"t even know what the part on the right is called. Any help would be appreciated . Thanks in advance!!!
Marcm1 is offline Find More Posts by Marcm1
Old Nov 25, 2014, 05:33 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Forum: Electric Motor Design and Construction
Subtitle: Information about design, construction, and performance of custom-designed electric motors.
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Nov 25, 2014, 05:54 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Ron, I'm not sure that is clear enough
@Marcm1 : this is the wrong forum. Please post your question here:
http://www.rcgroups.com/power-systems-13/
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Nov 26, 2014, 07:05 PM
Mike Dubovsky is offline
Find More Posts by Mike Dubovsky
Condescending Pedant
Joined Aug 2013
In your first picture, the part on the right is called a motor. The part on the left is called a prop adapter. In your case it looks like what you need are 4 small bolts that will bolt the adapter to the motor. The end of,the motor should have threaded holse that match up to the adapter holes.If you got the adapter with the motor, the bolts should have been included. Otherwise you will have to find the correct bolts and maybe the motor does not have the holes to bolt the adapter to. Not all motors do.
If you do not have the holes then you will need a collet type adapter.
I just looked closer at your two pictures and it looks like you have photographed two different motors.
Mike Dubovsky is offline Find More Posts by Mike Dubovsky
Discussion Need help setting up dual batterys on Cyclops OSD Nova bw5493 FPV Talk 0 Sep 28, 2014 06:11 PM
Help! Need help with stick mount set up... for motor. 747 Electric Plane Talk 1 Jul 19, 2014 10:47 PM
Discussion Need help with my motor and ESC set up. green river rc Electric Plane Talk 10 Jul 19, 2014 07:49 AM
Help! need help with TWIN motor set up (AP03 & supermicro ESC) angelix Scratchbuilt Indoor and Micro Models 33 Jul 16, 2014 03:42 PM
Help! My Ecs jams my motor, I need help setting it up. Chino.Ve Power Systems 7 May 29, 2014 05:03 PM
