Old Mar 08, 2015, 02:50 PM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Quick update...the process I explain in my above post only works on on mixes where the slave surface(s) move in the same direction. (example:an elevator with a single servo or separate halves)
Adjusting a 3 point curve works perfectly....however to make fine adjustments, you'd need to set the master value of the "side" that needs the most correction...and then adjust the curve on the other side for slightly less action.
It doesn't matter through because this doesn't work with a slave surface that with multiple servos where the surfaces move in opposite directions. (ie ailerons)
I think I'm going to try out the logical switches...just want to get this done. I'll have to write up an explanation for myself so I can re-remember it next time I have to do it.
djmoose is offline Find More Posts by djmoose
Old Mar 09, 2015, 01:13 PM
Sillyness is offline
Find More Posts by Sillyness
Sillyness's Avatar
Little Rock, AR
Joined Apr 2004
I got it working with ailerons. I still need to find the time to post screen shots.
Sillyness is offline Find More Posts by Sillyness
Old Mar 09, 2015, 01:48 PM
djmoose is offline
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
I got it working with the logical switches and I kind if like it.
Old Mar 09, 2015, 02:07 PM
Puttputtmaru is offline
Find More Posts by Puttputtmaru
Puttputtmaru's Avatar
Joined Aug 2012
Yes please post your findings for everyone to share.
Puttputtmaru is offline Find More Posts by Puttputtmaru
Old Mar 09, 2015, 06:46 PM
djmoose is offline
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
I should have said I got it working with wfield's explanation a few posts back.
Old Apr 11, 2015, 06:16 PM
Ola. is offline
Find More Posts by Ola.
Joined Feb 2011
Originally Posted by Ola. View Post
Well, ive been through this thread several times, and tried loads of different mix setups on my ds-16 to get this working on a plane with separate servo channels on elevators, and ailerons.
I cant get it to work, without using 4 mixes for aileron, and 4 for elevator. (Single direction mixes). Way to complicated when doing changes to the mix..
I got tired, and made my own 2 mixes for aileron (one for left rudd, one for right) and 2 for elevator, and enable the mixes with rudder stick switch at 4% on/off setting.
This seems to work perfectly, and i have made the mixes on both ele/ail so that positive number % is left rudder mix, and negative % is right rudder mix. Makes it easier to remember which is what, when you cant relabel the mix names.
As you see, i did the log switch back in 2013..
It works fine, but its still crap compared to how easy my JR dsx11 does it.
This, and the lack of a good manual for the Jeti, is the only negative side of the radio IMO.
Ola. is offline Find More Posts by Ola.
Old Apr 12, 2015, 06:03 AM
wfield0455 is offline
Find More Posts by wfield0455
United States, MA, Holliston
Joined Aug 2008
And why did you need 4 mixes for Ailerons and 4 more for Elevators?
wfield0455 is offline Find More Posts by wfield0455
Old Apr 12, 2015, 11:34 AM
Ola. is offline
Joined Feb 2011
4 total. 2 for ele, and 2 for ail.
Discussion Proposed Assymetric Quad Copter design... x3n0x Multirotor Talk 5 Jun 23, 2011 02:20 PM
Discussion symmetrical or assymetrical? Oladonk Hand Launch 3 Sep 03, 2010 09:36 PM
Discussion DIY Assymetric Tail Blade for Walkera 4G6/4G6S/V120D02 Timewerx Micro Helis 0 Aug 20, 2010 10:42 AM
Discussion Assymetric thrust on a float plane. CIWRD Waterplanes 1 Oct 01, 2006 08:33 PM
Anyone know this plane? German, WWII, assymetrical? Boba_Fett Scale Kit/Scratch Built 16 Mar 25, 2002 11:11 PM
