Old Aug 28, 2014, 03:45 AM
ChuckTseeker is online now
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
New Product
Spektrum Ultra Micro FPV System with Goggles
KEY FEATURES
All-in-one convenience
Perfect for ultra micro aircraft
Spektrum VA1100 Ultra Micro FPV camera
Fat Shark Teleporter V4 FPV headset with digital head tracking
Spironet RHCP antenna
760mAh 7.4V LiPo headset battery with charger
Y-harness camera power connector and lens cloth
Will not interfere with 2.4GHz RC transmitters
No FCC license required when VA1100 camera is used
PRODUCT SPECIFICATIONS
# of Channels:7Modulation:Analog NTSCBand:5.8GHzReceiver:Fat Shark compatible gogglesCharger:2S LI-Po Wall ChargerExperience Level:Beginner
OVERVIEW
Used to be, if you wanted to experience FPV (First Person View) flight, you had to piece together a system yourself. Once you did, you then had to figure out how to make everything work together. The Spektrum™ VS1100 Ultra Micro FPV System eliminates all the guesswork by giving you everything you need in one box. Camera, headset, batteries, charger - it’s all there, all compatible and can be ready to go in minutes.
Spektrum VA1100 Ultra Micro FPV Camera
This amazing bit of Spektrum technology combines an FPV camera, transmitter and antenna in a single unit no bigger than a thimble. Installation is easy and can be done in seconds. No soldering or special skills are required. You simply attach it to your model and plug in a 1S battery (sold separately). A Y-harness connector is included if you want to eliminate the weight of a separate battery and power the camera with the same 1S flight battery that powers the aircraft.
- Signal range suitable for ultra micro aircraft
- Compatible with 5.8GHz Fat Shark headsets
- Requires 1S LiPo battery, sold separately
- Powered separately or by aircraft battery
- No 2.4GHz RC interference
- No FCC license required
- Installs in seconds
Fat Shark Teleporter V4 FPV Headset
Developed exclusively for Horizon Hobby by Fat Shark, the Teleporter V4 headset is easily one of the best values in FPV fun. It’s compatible with all Spektrum and Fat Shark 5.8GHz FPV cameras and features:
- QVGA 320 x 240 LCD displays
- 5.8GHz wireless receiver
- Spironet RHCP antenna
- Digital head tracking for Spektrum FPV cameras
- Trainer link head tracking for gimbal controlled cameras
- 760mAh 7.4V LiPo battery with charger
- Lens cloth
Digital Head Tracking - A Horizon Hobby Exclusive
One of the coolest features of the Teleporter V4 headset is digital head tracking. Digital head tracking lets you look around the environment your model is flying through without the extra weight and complexity of a mechanical camera gimbal. Special sensors and software in the headset allow you to pan and tilt your field of view using the fixed-position VA1100 camera that’s included. It’s just one more way this Spektrum FPV system lets you have more fun with fewer hassles.
# of Channels:7Modulation:Analog NTSCBand:5.8GHzExperience Level:Beginner
OVERVIEW
This amazing bit of Spektrum™ technology is perfect for ultra micro aircraft. It combines an FPV camera, transmitter and antenna into a single unit no bigger than a thimble. It’s compatible with Fat Shark and other popular FPV headsets equipped with analog 5.8GHz receivers.
Digital Head Tracking Available
Even though the VA1100 is a fixed-position camera, you can pan and tilt your field of view when you use it with a compatible FPV headset that features digital head tracking technology. Special sensors and software in these headsets allow you to look around the environment your model is flying through without the need for a gimbal camera mount. It’s just one more way Spektrum FPV technology lets you have more fun with fewer hassles.
Teleporter V4 Video Goggles with Head Tracking
KEY FEATURES
Lens cloth
OVERVIEW
Developed exclusively for Horizon Hobby by Fat Shark, the Teleporter V4 headset is easily one of the best values in FPV fun. It’s compatible with all Spektrum and Fat Shark 5.8GHz FPV cameras.
One of the coolest features of the Teleporter V4 headset is digital head tracking. Digital head tracking lets you look around the environment your model is flying through without the extra weight and complexity of a mechanical camera gimbal. Special sensors and software in the headset allow you to pan and tilt your field of view using the fixed-position VA1100 camera. It’s just one more way this Spektrum FPV system lets you have more fun with fewer hassles.
Links#
http://www.spektrumrc.com/Search/Def...SearchTerm=FPV
ChuckTseeker is online now Find More Posts by ChuckTseeker
Old Aug 28, 2014, 04:55 AM
EpicRC is offline
Find More Posts by EpicRC
There's no age limit on FPV
EpicRC's Avatar
Australia, WA, York
Joined May 2012
Wow sweet. The Ultra Micro FPV Camera and VTX looks pretty lightweight. Shame about the low resolution on the goggles though...
EpicRC is offline Find More Posts by EpicRC
Latest blog entry: 450 pics
Old Aug 28, 2014, 05:19 AM
eurny666 is offline
Find More Posts by eurny666
eurny666's Avatar
France, PACA, Marseille
Joined Nov 2013
VTX+Camera only for $100, that's damn expensive compared to a TX5805 with lens D and a homemade cloverleaf antenna!
eurny666 is offline Find More Posts by eurny666
Old Aug 28, 2014, 07:11 AM
EpicRC is offline
EpicRC's Avatar
Australia, WA, York
Joined May 2012
Yeah it is. But aren't all Horizon products expensive..?
Old Aug 28, 2014, 09:16 AM
T.A. is offline
Find More Posts by T.A.
T.A.'s Avatar
United States, CA, Lincoln
Joined Jun 2014
No this system is 249 with head tracking!!!!!!!! Hobbyking teleporter v3 without headtracking was $199. This is going to be the best starter FPV package.
edited:
Actually the goggles stand alone with head tracking are $249. Seems they will be $150 more than the complete Teleporter v3 but it does not have head tracking.
T.A. is offline Find More Posts by T.A.
Old Aug 28, 2014, 09:17 AM
T.A. is offline
T.A.'s Avatar
Joined Jun 2014
ChuckTSeeker always on his game thank you for the thread just placed my preorder
Latest blog entry: Unavailable
Old Aug 28, 2014, 12:09 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
Spektrum RC Gear Is Here! (1 min 27 sec)
Put Yourself In The Pilot's Seat (1 min 31 sec)
I sure hope you guys enjoy these little cameras as much as I have. FPV at this scale is a special kind of magic
aaronredbaron is offline Find More Posts by aaronredbaron
Old Aug 28, 2014, 12:31 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Very cool
Questions for you horizon boys
What size is fpv transmitter?
Does it have channel selection?
How is range?
Price for just can/vtx combo?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Aug 28, 2014, 01:03 PM
simontan is offline
Find More Posts by simontan
simontan's Avatar
United States, TX, Plano
Joined Dec 2006
"Digital Head Tracking Available
Even though the VA1100 is a fixed-position camera, you can pan and tilt your field of view when you use it with a compatible FPV headset that features digital head tracking technology. Special sensors and software in these headsets allow you to look around the environment your model is flying through without the need for a gimbal camera mount."
What does this mean? This thing allows head tracking without a pan/tilt mount? So FOV is altered by software rather than servos?
simontan is offline Find More Posts by simontan
Old Aug 28, 2014, 02:00 PM
Spektrum Dev Team
Joined Apr 2002
Originally Posted by Razors edge 29 View Post
Very cool
How is range?
the transmitter is very low power, it does not require a HAM license. It has 7 channels on the standard Fatshark 5.8GHz frequency set. The range is perfectly suitable for Ultra Micro airplanes, it gets 150-300 feet or better with matched RHCP antennas (included), and the SPMVA1100 is the camera only for $99.99
You got it right! This headset (Teleporter V4) is able to offer the sensation of head tracking without moving the camera, and it also offers conventional trainer link based head tracking as well.
Old Aug 28, 2014, 02:17 PM
RCCombatGuy is offline
Find More Posts by RCCombatGuy
Minneapolis, Minnesota
Joined Jul 2004
Wow! What a great toy!
I can't wait to start indoor combat this winter!
RCCombatGuy is offline Find More Posts by RCCombatGuy
Old Aug 28, 2014, 02:35 PM
Abzauris is offline
Find More Posts by Abzauris
Mad Scientist Matt
Abzauris's Avatar
United States, FL, Melbourne
Joined Jun 2008
Could i use the head tracker from my Fat Shark Attitude SD v2's on this setup (I beleive its the Trinity head tracker)? Or only the ones that come with the package (Teleporter v4)?
-Matt
Abzauris is offline Find More Posts by Abzauris
Old Aug 28, 2014, 03:03 PM
Spektrum Dev Team
Joined Apr 2002
-Matt
The SPMVA1100 works great with the Attitude, but the digital head tracking is only available on the Teleporter V4. It actually is a concept that only works well on the low resolution headset. If we tried to do it with a higher resolution headset like your Attitude we would be cutting the resolution to make it happen.
Old Aug 28, 2014, 03:05 PM
Abzauris is offline
Mad Scientist Matt
Abzauris's Avatar
Joined Jun 2008
Gotcha, makes perfect sense...
Old Aug 28, 2014, 03:24 PM
creekj721 is offline
Find More Posts by creekj721
creekj721's Avatar
United States, ND, West Fargo
Joined Apr 2003
So what is the resolution and field of view from the SPMVA1100?
How will the SPMVA1100 work with other goggles like Predator V2s?
My concerns center on this head tracking, and weather we will see the full picture with other goggles and display systems.
I am guessing that the camera and transmitter are sending out a full VGA video and the head tracking in the new goggles is panning the full image around rather than compressing it to display the full image in the lower resolution that they provide.
creekj721 is offline Find More Posts by creekj721
Sold For Sale Spektrum AR6400T DSM2 6CH Ultra Micro Rx with Twin ESC wkener2 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Apr 03, 2014 07:30 PM
Sold NIB 2 Spektrum AS2000 ultra micro servos needacheaphobby Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 27, 2013 08:19 PM
New Product Walkera FPV Video Goggle Glasses Headtracking system velyter FPV Equipment 0 Oct 07, 2013 07:10 PM
Sold Complete starter Fpv system. Plane/Osd/Goggles/Video/Spektrum Johnnymeg FPV Equipment (FS/W) 8 Mar 11, 2013 11:24 PM
Sold Complete FPV System with OSD and Goggles CHEAP! stealth7777777 FPV Equipment (FS/W) 27 Feb 09, 2011 01:32 PM
