Old Apr 21, 2014, 04:30 PM
sherman89 is offline
Find More Posts by sherman89
Ocala Fl
Joined Jul 2006
H9 Carden 89" Extra electric?
Anyone out there do a H9 Carden 89" Extra with electric power, I am considering the Carden with a Rimfire 65CC motor on 12S through a CC160 esc, does anyonr know the length of the standoffs needed to match up to the cowl?
sherman89 is offline Find More Posts by sherman89
Old Apr 22, 2014, 11:54 AM
olezippi is offline
Find More Posts by olezippi
*It Ain't Lookin Good*
olezippi's Avatar
Evansville IN
Joined Aug 2004
I have the H9 Extra with an EME 60cc and the E-flite Power 360. Haven't made up may mind yet. I have everything for the gasser setup. If I go electric it would be 12S, CC 180HV ESC, 5000 Mah 6S Lipo (2). It would be a while before I had everything else for the electric setup. Either one will be a great setup.
olezippi is offline Find More Posts by olezippi
Old Apr 22, 2014, 04:31 PM
Ocala Fl
Joined Jul 2006
I did not know CC did a 180 amp speed control, what is the model name? I just ordered the Carden extra.
Old Apr 22, 2014, 05:47 PM
olezippi is offline
olezippi's Avatar
Evansville IN
Joined Aug 2004
Sorry about that. It's a 160 not 180.
Old Apr 22, 2014, 06:08 PM
Flying glass is online now
Find More Posts by Flying glass
obey gravity, it's the law
USA, IL, Rockford
Joined Nov 2005
I'm going to guess will need to measure the motor length to the prop base then mock up the cowl in place and measure the actual distance.
Just thinking this will give you the easiest solution for a perfect fit
John
Flying glass is online now Find More Posts by Flying glass
Old Apr 22, 2014, 06:51 PM
olezippi is offline
olezippi's Avatar
Evansville IN
Joined Aug 2004
Since the Extra is built around the DA 60 (same dimensions as my EME 60) the dimension from the engine box to the back of the spinner back plate would be 6.288". The ARF gives you 1" blocks that are sandwiched between the engine box and the engine so if you used the blocks it would be 1" less. Measure your motor and subtract that from the 6.288" and the rest is your stand-offs.
Ocala Fl
Joined Jul 2006
John
With out a firm measurement my intention is to exactly that.
Old Apr 24, 2014, 06:22 AM
Ocala Fl
Joined Jul 2006
The Carden extra is on it's way as is the 65cc rimfire motor so I will have a project by the middle of next week.
Old Apr 24, 2014, 11:50 AM
olezippi is offline
olezippi's Avatar
Evansville IN
Joined Aug 2004
Great. I think you'll like what you see in the box. Setting next to my 50cc YAK 55 the Extra 300 is a lot bigger. I have decided to use my EME 60cc gasser on this one since I already have everything to finish it. I'll save the E-flite Power 360 for a 50cc electric later this summer.
Old May 01, 2014, 06:25 AM
Ocala Fl
Joined Jul 2006
Here ia a pic of the business end of the rimfire 65cc motor on the extra, I will start out with a Xoar 23X10 prop.
Old May 04, 2014, 05:30 AM
Ocala Fl
Joined Jul 2006
Here is a pic with the cowl on.
Old May 06, 2014, 12:02 PM
Ocala Fl
Joined Jul 2006
I maidened the Carden today with a 23X10 prop and the plane flew well, my setup needs work but I am disappointed with the 65 rimfire performance on 12S so the prop is not right-----not sure to go to a 23X12 or a 24X10.
Old May 06, 2014, 02:11 PM
Hokieskins is offline
Find More Posts by Hokieskins
United States, VA, Manassas
Joined Aug 2012
I ran mine last year with the Rimfire 65cc with the (LXYCF7 DA 50Mount) with the CC 160 HV on Mejzlik 24x12, 12s 5000mah, Flew great, had some timing issues with CC ESC and Rimfire. This year went with the Power 360, CC 160 HV w/ Fan and same 24x12 prop and 5500mah, flys just as good with out timing issues.
Hokieskins is offline Find More Posts by Hokieskins
Old May 06, 2014, 03:02 PM
Ocala Fl
Joined Jul 2006
I am using the 160hv with fan as well running a Xoar 23X10 prop, temps after a 6minute flight are 100F with ambient air at 82F so battery power is not an issue, the 65 pulls it just not do what I think it will and i am comparing it to my rimfire 50cc motor that I have in a 30cc Spitfire----both aircraft weights are very close to being the same. I really think it needs more prop.
Old May 06, 2014, 08:56 PM
Joined Aug 2012
Prop up to the Xoar 24x12, the Rimfire 65 can handle it.
Sold The Hangar 9 Carden Edition 89 Extra 300 Mid-Wing ROD GARCIA Aircraft - Fuel - Airplanes (FS/W) 2 Apr 08, 2014 12:21 PM
Discussion Best engine match for a E flight Carden Edition 89" Extra 300 Mid-Wing highonthai Fuel Plane Talk 0 Mar 04, 2014 08:05 PM
Discussion Best engine match for a E flight Carden Edition 89" Extra 300 Mid-Wing highonthai Fuel Plane Talk 0 Mar 04, 2014 07:58 PM
Discussion New H9 Carden Extra 300- 89" HaventFlownSince2014 Atlanta Area RC 5 Feb 01, 2013 11:37 AM
Discussion H9 Carden 89" Yak 54 MCarlton Fuel Plane Talk 3 Jun 17, 2009 09:52 AM
