Joined Jun 2008
Need some help with first fan replacement
Ok, I am trying to do my first fan upgrade and need a little help....I have a J-Power 50mm F-86 Sabre which is my first EDF (I have many electric prop airplanes). A couple of weeks ago the fan blades shredded during take off so I ordered a new one from Hobbyking that someone had pointed to as a nice upgrade....http://www.hobbyking.com/hobbyking/s...dProduct=21966
Well, I got it in but I do have a couple of questions about it. 1. The lip of the shroud is much bigger on the new one. Not exactly sure how to make it fit. 2. I noticed that the lip is on the opposite side than the stock shroud. As it stands, I might be able to cut into the foam on the plane, opposite to where the original shroud lip was located. Is that how I should try to install it? I have enclosed one pic of the plane and fans.... Thanks from a first timer! |
| Thread Tools | |
| Discussion Need help with Motor Replacement | edwar64896 | Electric Sailplanes | 0 | Apr 28, 2013 01:18 AM |
| Discussion Need some help with a 3d maneuver | stssa | 3D Flying | 10 | Apr 17, 2013 12:01 PM |
| Help! Need some help with bixler 2 setup | dell30rb | Video Piloting (FPV/RPV) | 0 | Apr 12, 2013 08:47 PM |
| Help! begginer needs some help with FPV gear | FedeVI | Video Piloting (FPV/RPV) | 9 | Apr 01, 2013 08:43 AM |
| Help! First build, need some help with ESC/KK2 board | viskelaer | Multirotor Electronics | 11 | Mar 06, 2013 05:23 PM |
