Old Dec 30, 2014, 10:46 PM
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Help!
700 size Main, Blade Grip dimensions
I need information on main grips. What is the the total length, width, grip size, pivot hole size and bolt size. I see some have a 12mm grip with a 6mm thru bolt.
p901P901 is offline Find More Posts by p901P901
Old Dec 30, 2014, 11:25 PM
الآن كنت تتحدث لغتي
Flying Pitcher's Avatar
Greenland, Qaasuitsup
Joined Apr 2013
they're all different which model are you interested in?
Flying Pitcher is offline Find More Posts by Flying Pitcher
Old Dec 31, 2014, 12:30 AM
p901P901's Avatar
Joined Jan 2009
Thanks for the response.
This is for a custom collective pitch application. Just need a general idea of what is out there. I am doing a comparison between images but do not have an idea of the bores that are available. This is the shaft size between the head block and blade grips. Some bearings are 8x16x5mm so it looks to be a 16mm bore on a 8mm shaft.
For Sale Microheli Aluminum Main Blade Grips for Blade 130x Blakez Aircraft - Electric - Helis (FS/W) 0 Dec 30, 2014 12:12 PM
For Sale Microheli Aluminum Main Blade Grips for Blade 130x Blakez Aircraft - Electric - Helis (FS/W) 2 Dec 27, 2014 11:17 PM
Wanted Trex 450 pro main blade grip and hitec 5065 servo richord Aircraft - Electric - Helis (FS/W) 0 Sep 22, 2014 11:48 AM
Sold Compy 300/HBCP CNC head,washout,Main blade grips,tail blade grips,main gear Lonelasso Aircraft - Electric - Helis (FS/W) 1 Feb 05, 2008 06:53 PM
Off Site Compy 300 CP parts--CNC head,washout,Main blade grips,tail blade grips,main gear Lonelasso Aircraft - General - Miscellaneous (FS/W) 0 Feb 02, 2008 03:21 PM
