Old Apr 23, 2013, 01:14 PM
jcansdale's Avatar
United Kingdom, Gunnerton
Joined Dec 2010
Mini-HowTo
OrangeRX RX3S Flight Stabilizer on Crack Yak and other foamies
I've recently been playing with the OrangeRX RX3S Flight Stabilizer on my Crack Yak. You can pick up the RX3S for $24.99 from Hobbyking. I have a couple more on order to try on other planes.
http://www.hobbyking.com/hobbyking/s..._Receiver.html
I only have the stabilization enabled in low rates mode when practicing precision aerobatics. When flying 3D in high rates mode, I have it disabled completely.
Here's a quick video showing it in action. I was making very little headway flying full throttle into the wind!
(Watch in full screen so you can see the plane)
Full throttle into the wind! (1 min 8 sec)
I'll post my set up and links in the following posts.
jcansdale is online now Find More Posts by jcansdale
jcansdale's Avatar
Joined Dec 2010
Reserved for hardware set up info
The unit weighs 15g with case. If you remove the case it comes down to 6.48g (or 6.71g with mounting pad).
I'm using these mounting pads:
http://www.hobbyking.com/hobbyking/s...0pcs_bag_.html
I cut up a mounting pad and stuck small pieces to any bare parts of the board. With these pads there is just enough clearance for the surface mount capacitors under the board. Add a L-shaped piece in the corner under the servo connectors. You'll be pressing down here when you connect the servos and don't want the opposite corner to lift up.
The servo connectors need to be closest to the tail, but the unit can be mounted upside down if you reverse elevator and rudder. On the dip switches I have ELE and RUD servos reversed and AUX1 set to toggle the gyros (switches in the up position).
After attaching the board, I added a small dab of glue to the end of each antenna and stuck it to the foam. This should stop them flapping around and keep them at a nice 90 degree angle.
My pitch and yaw gains are set to about half way and my roll gain is a bit less than half way. Try doing a fast roll and if it pauses as it turns, back off the gain a little. I find these settings work well for flying in lots of wind.
Old Apr 23, 2013, 01:15 PM
jcansdale's Avatar
Joined Dec 2010
Reserved for radio set up info
I have 3 aims with my radio set up:
1) To change DR, expo and stabilization on a single switch. Stabilization will be on for precision aerobatics (low rates) and off for 3D (high rates).
2) To fly with stabilization on but still be able to do a snap roll without flipping switches. If you do a snap roll with stabilization on, it tends to fight it.
3) To have a master switch that can disable stabilization. Stabilization will be off in its default position. This will help remind me that I'm using it!
I'm using a Spektrum DX8. I've attached my model configuration file below (see 09CRACKY.spm). Here's what I did:
First I'm going to select my switches. I'm going to use the F Mode switch for both D/R, expo and stabilization. This needs to be mapped to Aux1 which enables and disables stabilization. I'm going to use Gear as a master override for when I want to fly without stabilization. I'm mapping this to Aux2 so I can use it in a custom mix.
I want stabilization to be always on in F Mode 0, mostly on in F Mode 1 and never on in F Mode 2. To do this I need to reverse the Aux1 channel. This will make it so that stabilization is active in F Mode 0 and 1. The F Mode switch can also be used for DR and expo.
When I'm in F Mode 1 and do a snap roll, I want stabilization to be momentarily disabled. To do this I'm going to create custom ELE > AX1 and RUD > AX1 mixes. I want it so that when I input elevator or rudder, the AX1 value is increased until eventually stabilization is disabled. To do this I'm setting the mix rates to -50% and 50% for both mixes (AX1 the value will increase when the stick is pushed in either direction). I'm only enabling these mixes in FM1.
I now want to make it so that stabilization will be disables when the Gear switch is in the down position. This means I will have to explicitly flick a switch if I want the option of using stabilization. I never want to forget that I'm using it! To do this I'm going to create a AX2 >
AX1 mix. I have mix rates set to -125% and 0%. Unfortunately there isn't enough reach to ensure that stabilization is disabled in F Mode 0, so set up a 4th mix that is exactly the same as mix 3. (this feels like a hack, can anyone think of a better way)
Okay, we're done. Time to flick Gear into the up position and fly! Let me know what you think.
Maybe someone could share a DX6i model configuration?
Old Apr 23, 2013, 03:16 PM
pounditracing's Avatar
Joined Jan 2013
Follow
pounditracing is offline Find More Posts by pounditracing
Old Apr 24, 2013, 12:37 PM
jcansdale's Avatar
Joined Dec 2010
OrangeRX RX3S naked weight
I finally got around to weighing the OrangeRX RX3S without its case. The naked board weighs 6.48g and the case 8.16g. When you include some gyro mounting pad, the total weight is 6.71g.
For comparison the 4 channel OrangeRx R410 weighs 2.64g (I'm guessing most people will be using this). This means the flight stabilization functionality will cost you 6.71g - 2.64g = 4.07g. Not too bad.
I use these mounting pads:
Old Apr 24, 2013, 02:49 PM
jcansdale's Avatar
Joined Dec 2010
Reserved for links
OrangeRX RX3S links
OrangeRX RX3S 3-Axis Flight Stabilizer w/DSM2 Compatible 6CH 2.4Ghz Receiver
OrangeRX RX3S User Guide
http://www.hobbyking.com/hobbyking/s...X520622X49.pdf
OrangeRX 3-Axis Flight Stabilizer
http://www.rcgroups.com/forums/showthread.php?t=1702672
You can re-flash the OrangeRX RX3S with alternative firmware. The firmware includes features such as in-flight adjustable gain and heading hold mode. I haven't done this yes. See this thread:
Open Flight Stabilizer
http://www.rcgroups.com/forums/showthread.php?t=1794672
Spektrum AR635 links
AR635 Product Page
http://www.spektrumrc.com/Products/D...rodID=SPMAR635
AR635 Manual
http://www.spektrumrc.com/ProdInfo/F...-Manual_EN.pdf
AR635 First Stand Alone Spektrum RX with AS3X
http://www.rcgroups.com/forums/showthread.php?t=1798807
Eagletree Guardian links
Eagletree Guardian Manual
http://www.eagletreesystems.com/supp...an%202D-3D.pdf
Using Gyros on an RC airplane
http://www.rcgroups.com/forums/showthread.php?t=1035605
Information for how to install and set up a gyro onto your fixed wing aircraft
http://www.mycoolrc.com/gyro/indexnew.html
List of reviewed gyros (including dedicated 3 axis airplane gyro systems)
http://www.mycoolrc.com/gyro/gyroLINKS.html
Are there any useful links I've missed?
Old Apr 25, 2013, 04:56 AM
jcansdale's Avatar
Joined Dec 2010
I've updated the "Radio set up" post with my DX8 model configuration. Maybe someone with a DX6i or other radio could share how they're using it?
Old Apr 25, 2013, 07:58 AM
3flyguy3's Avatar
United States, IL
Joined Apr 2012
Sub'd
3flyguy3 is offline Find More Posts by 3flyguy3
Old Apr 25, 2013, 09:10 AM
Intergalctic Coffee Enthusiast
MaddSkillz's Avatar
United States, OK, Tulsa
Joined Jun 2011
I think this will be great for foamies on those windy days and you just want to fly!
MaddSkillz is offline Find More Posts by MaddSkillz
Old Apr 25, 2013, 09:38 AM
United States, FL, Keystone Heights
Joined Dec 2012
nice...
ive been interested in these for a while but couldnt see it working on a 3D plane... you can certainly tell the difference in the way it was flying with it on/off.
as an outdoor flyer only, and someone who doesnt like to wait for those perfectly calm days to fly, this is intriguing.
swampflyer is online now Find More Posts by swampflyer
Old Apr 25, 2013, 09:44 AM
scotland uk
Joined Jan 2005
Subbed lol
wishawhunk is online now Find More Posts by wishawhunk
Old Apr 25, 2013, 10:04 AM
Joined Mar 2013
interesting, just orderd up a few units, Im trying to get some friends over do 3d planes, this might be a way to temp them, also they complain about flying in wind a lot.
anderspa is offline Find More Posts by anderspa
Old Apr 25, 2013, 10:06 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I have one mounted on the Flash by RC Factory. It's on the bottom just behind the wing, held on with Velcro and a Velcro strap aroud it to steady it. I'm not much of a switch flipper as I can't remember which one does what.
The ammount of control is a balance between you and the gyro. When I found it was slow doing the snaprolls etc. I backed off on the gain to give me more control. The gyros still work great to stabilize it when the sticks are at neutral. I also have one in a scratchbuilt VTO Pogo. which works well on the vertical landings. This is excellent for 3D planes where you very high throws on the surfaces, yet locks in on the neutral settings in the wind. That's where it really shines.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Apr 25, 2013, 11:43 AM
jcansdale's Avatar
Joined Dec 2010
I think it's always going to interpret the autorotation of a snap roll as un-commanded movement and try to counter it. You might like to try my transmitter set up from post 3. I've made it so when pulling lots of elevator and runner it will disable the gyros for a moment. This lets you do nice round loops and snappy snap rolls.
Old Apr 25, 2013, 01:19 PM
MartinT's Avatar
Joined Mar 2006
@jcansdale:
Nice, thanks for the very informative "how to" set up! (your post #3)
And as for the same mix twice, I had to do the exact same thing on my DX18QQ for a Throttle cutoff function of the rotary knob. A single mix just doesn't give you enough throw in some circumstances.
As fot the snaproll on the AR635 (with a Visionaire surrounding it ;-)): you are quiteright, it looks much better (more heading change in respect to flightpath) with the rx in low gains (general mode) iso 3D mode...
Cheers!
MartinT is offline Find More Posts by MartinT
Discussion Red brick esc on my mini crack yak wishawhunk 3D Foamies 3 May 05, 2013 10:38 AM
Help! Electrifly Yak 54 foamy cracked wing t0ny-p40 3D Flying 1 Sep 30, 2009 01:25 AM
