Old Yesterday, 07:48 PM
United States, NC, Raleigh
Joined Oct 2011
Are you using the Rudder stick to Arm/Disarm?
That is where I saw the problem. The Throttle would not go low enough to allow alarming. I had to force the Taranis to travels greater than 100% if I used S.Bus. Everything worked fine at 1005 if I used the servo outputs from the X8R without S.Bus.
John
Originally Posted by mike105105 View Post
Taranis, not sure on the settings off the top of my head, forgot my gear at work today.
JohnRB is online now Find More Posts by JohnRB
Old Yesterday, 08:06 PM
Joined Jul 2009
I use sticks for arm/disarm. I don't think I adjusted the travels but that's no big deal, the option is there for you if you need it after all.
mike105105 is offline Find More Posts by mike105105
Old Today, 05:00 AM
Joined Oct 2011
Yes, you can make it work by forcing the travel above 100% with Taranis.
It just really bothered me that everything was setup and working fine when using normal PWM pulses for all channels.
When I switched to S.BUS things no longer worked as they did before and it concerned me. I discovered the problem and fixed it without having to make any changes on the Taranis.
I believe the current feeling on the MultiWii forum is to add the scaling and a define in config.h to enable it. The default state will be disabled. If you want the scaling you will have to overtly turn it on.
John
Discussion Witespy Pro2 & Pro3 Flight Controllers for MegaPirate Next Generation (MPNG) Greg Covey Multirotor Electronics 337 Jul 07, 2014 12:23 PM
For Sale MultiWii PRO 2.0 flight controller w/gps. mando608 Aircraft - Electric - Multirotor (FS/W) 3 Feb 27, 2014 09:48 AM
Discussion sk-450 + MultiWii PRO 2.0 Flight Controller wont get off ground any ideas ? smz Multirotor Talk 17 Jan 16, 2014 05:21 AM
Sold MultiWii PRO 2.0 Flight Controller w/ GPS Option xhover Aircraft - Electric - Multirotor (FS/W) 1 Jan 21, 2013 03:24 PM
Discussion Witespy MWC Pro v2.0 HeliCopCR1 Multirotor Electronics 11 Jan 06, 2013 05:09 PM
