Old Jun 28, 2012, 11:55 AM
NighthawkF-117 is offline
Find More Posts by NighthawkF-117
Registered DLG addict
NighthawkF-117's Avatar
Minnesota
Joined Jan 2009
Different Lipos in Parallel and Series
Hey guys, I have a quick question...
Can I wire 2 different 3s lipos in a Parallel or series circuits and fly with them?
Would the only problem be the packs not discharging equaly? I have a 2200mah and a 1600mah pack.
Thanks guys,
Nighthawk
NighthawkF-117 is offline Find More Posts by NighthawkF-117
Old Jun 28, 2012, 12:26 PM
typeRA is offline
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
The parallel arrangement should work; the series arrangement needs cells to be of similar capacities. In a series circuit, the current through each cell is equal, therefore each cell would lose capacity at the same rate, the 1600mAh cells being empty first.
typeRA is offline Find More Posts by typeRA
Old Jun 28, 2012, 03:23 PM
AZcrashpro is online now
Find More Posts by AZcrashpro
AZcrashpro's Avatar
Mesa Falcon Fld, Arizona, United States
Joined May 2004
Personally I would not do it.
Parallel the ESC would see the highest voltage and use that as a cutoff. That would make it VERY easy to over discharge the 1600 pack.
Series the 1600 pack would work harder that the 2200 and maybe over heat. You might get away with this because the cutoff voltage would be based on a 6s battery. The smaller battery would reach cutoff quicker but since the bigger pack would be well above cutoff you still might overdischarge the little pack.
AZcrashpro is online now Find More Posts by AZcrashpro
Old Jun 28, 2012, 03:25 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
+1 this sounds right to me. I wouldn't do it because as he says in either configuration I think you risk over discharge of the 1600.
grimbeaver is offline Find More Posts by grimbeaver
Old Jun 28, 2012, 03:52 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
you definately can use them in parallel as long as they are the same cell count, one pack will not empty before the other if wired in parallel, it doesnt work that way, if you wanted to use a 5000 milliamp 3 cell battery and a 100 milliamp 3 cell battery in parallel, it would work fine, you cannot use them in series however because they have to be the same capacity.
keithy4129 is offline Find More Posts by keithy4129
Old Jun 28, 2012, 04:09 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Wrong. In parallel they're at the same voltage, as per the laws of physics. This makes it impossible to overdischarge the smaller pack. This is also why it is perfectly safe to charge lipolys of the same cell count in parallel, regardless of relative capacity.
They may be used in series as long as the discharge current and capacity is kept within the limits of the least capable pack. Discharging all the way to LVC would most assuredly destroy the lower capacity pack so one must time discharges if mixing packs in series.
keithy4129 is absolutely correct.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jun 28, 2012, 05:53 PM
AZcrashpro's Avatar
Joined May 2004
Mark
That is true voltage remains the same in parallel but consider this. If you assume like you say that you can not overdischarge the 1600 and fly to the 80% most people say is safe of the 3700mah pack you create in parallel and use 2960mah per flight. All things being equal that is 1480 per pack. You have now over flown the 80% rule of the 1600 pack and gone to 92.5%.
Assuming you only fly to the capability of the 1600 pack you would be fine. I never assume anyone will not make a mistake and overfly the 1600 pack. I also don't believe in giving advice that set people up to have problems which is what this will do. WAY to easy to overfly the 1600 pack.
Can you do it yes, would I suggest doing it no.
Old Jun 28, 2012, 05:57 PM
So. Cal.
That is true voltage remains the same in parallel but consider this. If you assume like you say that you can not overdischarge the 1600 and fly to the 80% most people say is safe of the 2100 pack you will use 1680mah per flight.
So where is the extra 80 mah coming from for the 1600 battery?
It is coming from the 2100mAh pack.
A 1600mAh pack and a 2100mAh pack in parallel becomes a single 3700mAh pack and should be treated as such. Similarly, a 100mAh pack in parallel with a 3600mAh pack also becomes a 3700mAh pack.
In series, yes. In parallel, both packs will be at the same voltage so it will be absolutely impossible to overdischarge the smaller pack without also overdischarging the larger pack.
Mark
Old Jun 28, 2012, 06:06 PM
AZcrashpro's Avatar
Joined May 2004
Mark
Please see my edited post, we crossed.
Old Jun 28, 2012, 07:43 PM
So. Cal.
Ok, read your post again and my point remains - it is physically impossible to overdischarge one battery that is part of a parallel set without also overdischarging the second battery. The total pack capacity is the sum of the packs in parallel, NOT a doubling of the lowest capacity pack, as is frequently incorrectly theorized.
The following thread deals with parallel charging but the same concepts apply to packs that are discharged in parallel: http://www.rcgroups.com/forums/showthread.php?t=932319. Carefully read through the first post a few times and it will make sense.
Cheers,
Mark
Old Jun 28, 2012, 08:29 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
When wired in parallel, you can't possibly over discharge 1 pack.
They are in parallel and almost by definition the voltage is the same in each pack no matter what.
it is not a weak link thing like in series, they are ONE with the universe.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jun 29, 2012, 03:07 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
The critical factor in paralleling packs of different sizes is that they will automatically share the total current not EQUALLY as some people imagine but in proportion to their capacity (it's a bit more complicated but that's roughly how it works).
So if you run a 2000mAh and a 1000mAh pack in parallel and draw 30A total then 20A will come from the larger pack and 10A from the smaller....so they empty at the same time .
Neat isn't it ?
Steve
slipstick is offline Find More Posts by slipstick
Old Jun 29, 2012, 09:22 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
[QUOTE=slipstick;22027696]The critical factor in paralleling packs of different sizes is that they will automatically share the total current not EQUALLY as some people imagine but in proportion to their capacity (it's a bit more complicated but that's roughly how it works).
Neat isn't it ?
Not to take this off topic but a quick question ,what charge rate would you use if parallel charging 2s-850mah-900mah-1320mah @1C =3.1A????
The Tug is offline Find More Posts by The Tug
Old Jun 29, 2012, 09:31 AM
So. Cal.
Yes. See link in post #10 above for more information.
Mark
Old Jun 29, 2012, 11:09 AM
The Tug is offline
Barbados
Joined Jan 2011
Thanks Mark is was P charging the same packs and doing another cycle for the others,now i see it's quite ok to charge packs of disimilar mah but the same cell count obviously.But i have a question for you e.g if paracharging 2c1000-2s 2000@ 1c=3amps charge how does the charger know to deliver the correct amount to each pack and not deliver 1500mah to each at it sees a single 2s 3000 pack?
Help! Different Capacity LiPos in Parallel acetech09 Batteries and Chargers 5 Apr 22, 2012 10:39 PM
Discussion Mixing lipo packs of different capacities in series ge0ff Batteries and Chargers 7 Apr 09, 2012 09:14 PM
Discussion 1 x Parallel and 2 x Series all run in Parallel Battery Question.. topgearuk Batteries and Chargers 2 Apr 04, 2012 01:48 PM
Discussion Lipo Series and Parallel Required Reading Doug Bateman Electric Ducted Fan Jet Talk 5 Mar 19, 2012 07:18 PM
Discussion can i charge different mah 1 cell lipos in series? Dr.JJ Batteries and Chargers 5 Feb 25, 2012 07:10 PM
