Old May 19, 2015, 01:22 AM
Rocketman1092 is online now
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Build Log
1/12 Scale F-35B STOVL Design & Build
Hey guys,
Apologies for the cross-post. I've started up this build thread down in the VTOLs section, but I figured people here would find it interesting. I'm working on a scale F-35B with full STOVL capability, and have finally made enough progress to justify posting the project. The power system is already complete and the hover test rig is flying. I'm doing the design work in CAD and used 3D printing for the swivel nozzle assembly, roll ducting, and various other parts. Here are the power system specs:
- Twin ChangeSun 90mm fans with 1600kV outrunners
- Turnigy Plush 100A ESCs
- 2 GForce 6S 3300mAh 40C packs in parallel
- KK2.1 flight controller with OpenAeroVTOL 1.1
I'm currently working on a foamie airframe for transition testing. It'll have a wingspan around 36" and a length around 50". I'll have some renders of that design shortly. Once I use that to do some experimenting with transition, I'll start design work on the scale airframe. It'll be mostly balsa and ply with a fiberglass skin, and perhaps foam core wings. The hollow-molded composite method I used on my X-47B was nice, but requires much more tooling and setup work than I'd like.
Let me know what you think! I'm not sure how best to balance between this thread and the one down in VTOLs. Perhaps I'll document most of the build here while posting more general updates there.
Latest hover test flight:
R/C F-35B Hover Testing (0 min 53 sec)
Swivel duct operation (before wiring and electronics were cleaned up):
R/C F-35B Swivel Nozzle Operation (0 min 15 sec)
Link to the post in VTOLs: http://www.rcgroups.com/forums/showt...9#post31660570
Rocketman1092 is online now Find More Posts by Rocketman1092
Old May 19, 2015, 02:30 AM
icicles is online now
Find More Posts by icicles
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
Truly impressive. Thanks for posting. I look forward to following your progress. And wish you success.
Looking forward to seeing the finished result/video
Chris
icicles is online now Find More Posts by icicles
Old May 19, 2015, 04:51 AM
lrb75 is online now
Find More Posts by lrb75
United States, VA, Springfield
How are you doing roll and yawn control? The side ducts look fixed.
lrb75 is online now Find More Posts by lrb75
Old May 19, 2015, 06:40 AM
bidule is online now
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
Neat
bidule is online now Find More Posts by bidule
Old May 19, 2015, 07:04 AM
metalfred is offline
Find More Posts by metalfred
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
Awesome, keep it up!
metalfred is offline Find More Posts by metalfred
Old May 19, 2015, 09:28 AM
Purdue Engineering
Joined Jan 2005
The roll ducts are fixed, but the flow through them is variable via servo-controlled scoops in the main duct. Yaw is controlled by rotating the rear nozzle left or right.
Old May 19, 2015, 01:58 PM
lrb75 is online now
. How much does the rig weigh so far? How much reserve lift do you have ? Nice job so far looks like you have gotten farther than any other vtol F 35 that I have seen.
Old May 19, 2015, 03:28 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Here is one commercially available
http://easytigermodels.com/index.php...t8ivim914dh1g7
Chris True is offline Find More Posts by Chris True
Old May 19, 2015, 05:46 PM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Really cool attempt at trying to mke this work..If you can get by the weight issues with powering 2 fans you will be well on your way to making this work.......................Chris
Hover or die is offline Find More Posts by Hover or die
Old May 19, 2015, 06:31 PM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Brilliant, real art work, hope it will work in practical terms. Be quick to patent it before someone copies it!
jofro is offline Find More Posts by jofro
Old May 19, 2015, 07:09 PM
Purdue Engineering
Joined Jan 2005
Well, there's no original ideas here. Plenty of aerospace companies already own patents for the swivel module. I just made it smaller!
Not sure how much the rig weighs as I don't have a proper scale. It requires a bit over half power to hover, and total static thrust should be around 12lb peak minus the ducting losses.
Old May 19, 2015, 07:18 PM
jumo004 is offline
Find More Posts by jumo004
jumo004's Avatar
Joined Apr 2010
Wow !! Very Cool !!!
jumo004 is offline Find More Posts by jumo004
Old May 19, 2015, 10:42 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
The new HV Lipo packs coming from Hyperion could increase your power for the same weight too.
Nice work on all levels!
AceMigKiller is online now Find More Posts by AceMigKiller
Old May 19, 2015, 11:49 PM
Purdue Engineering
Joined Jan 2005
I've thrown together most of the design for the foamie flight test airframe over the past couple of days. I might actually keep this around for a while before moving to the scale airframe - it looks kinda cool.
Old May 21, 2015, 11:45 AM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Really cool project!! I really hope you succeed and we can see it fly .
Castel101 is offline Find More Posts by Castel101
Build Log 1/12 Scale F-35B STOVL Design & Build Rocketman1092 VTOLs 28 Jun 10, 2015 08:45 AM
Help! F-35b stovl louisjunior VTOLs 11 Aug 08, 2014 08:29 PM
Build Log F-35B Lightning II VTOL –Scale Composite Build <Updated: Aug 15> pg.4 Mustang5 Electric Ducted Fan Jet Talk 102 Jun 21, 2014 02:56 PM
Build Log F-35B Lightning II VTOL - Scale composite build!!! G-force237 VTOLs 221 Sep 09, 2013 06:00 AM
Interesting X-35B STOVL test video Thomas B Electric Ducted Fan Jet Talk 6 Apr 21, 2001 04:54 PM
