Old Jun 28, 2014, 02:17 AM
wareck's Avatar
France, Champagne-Ardenne, Francheville
Joined Aug 2009
How to use regenerative discharge with full power ?
Hi
I would like to use Hi discharge rate with regenrative discharge and my PL8
every time I try to use it, my charger says "swicthed to internal discharge"
I never succeed to have full discharge power
Olivier
wareck is offline Find More Posts by wareck
Old Jun 29, 2014, 12:01 AM
Seattle
Joined Sep 2007
The Powerlab will switch to internal discharge when the Pb batteries are full. To increase the discharge rate, you can add a load in parallel to the Pb battery such as a string of automotive lights. Or you can add a couple more Pb batteries to increase the capacity of the Pb bank.
You can also discharge the Pb battery to 50% before the regen is started to ensure there is sufficient capacity in the Pb battery. When done, be sure to top off your Pb battery as its better for the battery.
Gregor99 is online now Find More Posts by Gregor99
Latest blog entry: Dual Powerlab Case Project
Discussion PL6 regen discharge issue tsymonds Batteries and Chargers 3 Apr 12, 2014 07:01 AM
Discussion Anyone know how to get full servo use with flaps jcyr1 Hitec/Multiplex USA 4 Oct 27, 2013 01:47 PM
Discussion Poor Man’s $5 Regenerative Discharger mrforsyth Batteries and Chargers 67 Jun 07, 2013 07:31 PM
Discussion Powerlab 8 regenerative discharge question? Eddie500 FMA Direct 11 Nov 09, 2011 03:05 PM
Discussion Regenerative discharge Ohio AV8TOR Batteries and Chargers 4 Jul 25, 2011 07:20 AM
