Old Jan 10, 2015, 01:40 PM
Tug Hercules Fireman
Tug Hercules's Avatar
Canada, AB, Medicine Hat
Joined Mar 2008
Terminology - Bow Stem etc. ...
Greetings & Happy New Year to all.
Looking to get some clarity on terminology;
The terms; Bow Stem, Keel Stem, Stem Bar and Bow Iron; are they all the same thing?
I am referring to the vertical, flat piece on the front of the bow. See arrow in attached photo.
In my particular Tug of interest, this piece is very pronounced.
Any insights are appreciated.
Thank You.
Tug Hercules
Fireman Rick
Tug Hercules is offline Find More Posts by Tug Hercules
Old Jan 10, 2015, 03:42 PM
Joined Dec 2004
RICK- The part identified with the arrow is called the STEM POST. In the case of the tug, the stem post is rabbeted out to let in the hull planking leaving the stem post proud forward of the rabbet. The stem post is scarfed or spliced into the keel, usually after the turn of the stem as is made of the same material as the keel.
The term flat iron is used for the metal band of metal which is fastened to the front of the stem post for additional protection from floating debris striking the bow when under way. On pleasure craft and cruisers the term cutwater is used for the metal protection of the stem.
The same terminology can be used for the back of the hull on a double ended hull, i.e. STERN POST. On hulls with a flat or radius transom, the stern post is the center vertical post which is connected to the keel usually with a bolted knee into the framing.
The breast nook or piece is the part which is fastened to the stem post to accept and fasten the shears.
frankg is offline Find More Posts by frankg
Old Jan 10, 2015, 05:54 PM
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
But in this case, it's steel or iron, not wood, and there's no rabbeting. The stem post is a flat section, perhaps 1x6, of steel plate, a continuous extension of the keel. The garboard strake of plating at the keel, and the plate ends at the stem post, are formed parallel to the stem/keel into a three-layer sandwich, and are riveted through.
patmat2350 is offline Find More Posts by patmat2350
Old Jan 14, 2015, 10:05 AM
Vince Hoffmann's Avatar
Hayward, CA
Joined Jan 2009
If its a wood boat, then the wood part at the front of the bow is called a "cutwater". The cutwater is not necessarily a structural element and is attached to the front of the stem post which is an extension of the keel and a structural element of the boat. Not all wood boats are built this way, most have a single stem post which serves the same purpose.
Vince Hoffmann is offline Find More Posts by Vince Hoffmann
Question Newbie Threads Available? Ex: FAQ, Multicopter Terminology, Etc boba7523 Multirotor Talk 3 Apr 30, 2014 04:12 PM
Help! How to decipher current motor terminology, etc? KnifeEdge51 Power Systems 2 Jan 15, 2013 12:41 PM
Question Helicopter size terminology? (60, 90, vs 450, 500 etc) kaon Mini Helis 3 Sep 13, 2008 12:44 PM
Discussion Your Foam Bow, Table cutter, etc.. Let's see 'em.. Tram The Builders Workshop 1 May 07, 2007 01:03 PM
Question Terminology.? Washout, Reflex etc Mike_Y Fuel Plane Talk 4 May 25, 2002 03:10 AM
