Old Jan 06, 2015, 02:57 PM
United States, CO, Thornton
Joined Sep 2014
Question
APM 2.6 Power Module question
So I'm building my first hexacopter and I initially used a kk flight controller and I got it flying and it flew well, but then decided I wanted to have gps etc so I bought an APM 2.6 kit with gps, pwm etc. Question is I soldered up the pwm inputs to an xt60 connector and the outputs to my pdb and it won't fire up the fc. If I hook the fc up to my computer via usb it powers on, or if I plug my ubec into it that also works. The output coming off the power module when I measure the solder pads show .92 volts. So I should assume it's a bad power module?
Do I even need this power module or can I just as easily hook it up to my castle creations UBEC which supplies 5.1v?
Hex Flyer is offline Find More Posts by Hex Flyer
Old Jan 06, 2015, 03:32 PM
Joined Sep 2014
Here are some pictures of how I wired it.
Old Jan 06, 2015, 04:04 PM
Joined Sep 2014
If I hook the fc to the ubec, will it still be able to read the battery voltage for telemetry?
Old Jan 06, 2015, 06:19 PM
Joined Sep 2014
Hopefully somebody else has came across this same issue.
Wisconsin
United States, WI, Hayward
Joined Jan 2012
Your post is confusing.
You don't "solder up pwm inputs to an xt60 connector". The input to the power module comes from your battery. The power output of the Power Module goes to your distribution board. The small 6 pin connector goes to the Power Module connector on the FC. Nothing goes to PWM inputs, unless you are powering the fc by the input rails with a ubec. Those black wires have a specific order they go when connected to the FC PM connector. If it is a pre-made cable that came with the power module you are probably ok.
mike_kelly is offline Find More Posts by mike_kelly
Old Jan 06, 2015, 06:53 PM
Joined Sep 2014
I guess I didn't write that correctly, I soldered the xt60 to the input of the PWM, its the xt60 that the battery plugs into, then I soldered the output of the PWM to the dist board, and I am using the pre-made cable to goto the FC. So I think we are saying the same thing.
Old Jan 06, 2015, 11:48 PM
Wisconsin
Joined Jan 2012
OK gotcha. PWM means pulse width modulation. Use the abbreviation PM for power module. The output of the power module should be exactly the same as the input on the side that goes to the power distribution board. What powers the FC is the small 6 black wire cable. It has the voltage and current sense wires but it also has power and ground for the fc.
You can power your fc via one of the input connections used by the receiver inputs but you wont get the voltage or current readings if you don't use the power module.
If you use a ubec make sure the voltage is less than 5.4v.
CHeers
Old Jan 06, 2015, 11:56 PM
Joined Sep 2014
CHeers
Thanks Mike, that's what I was afraid of, I think the PM is bad then. Sorry about the wrong abbreviations I'm still learning this hobby. I get the correct voltage on the output of the PM going to the power distribution board, but not the 5v which should power the flight controller.
Old Jan 07, 2015, 05:47 AM
Brazil
Joined Jan 2014
From your pictures it can be seen that your "power module" is only a voltage / current sensor. It does not have an integrated BEC to power up your APM.
Check out the differences between these two:
Power module with BEC
Power module without BEC
You need an additional BEC or a new power module with BEC.
Regards
marbelo is online now Find More Posts by marbelo
Old Jan 07, 2015, 10:07 AM
Wisconsin
Joined Jan 2012
If you look closely that is a 3DR power module. They do not make one without a bec built-in.
PS> If you bought that PM from someplace other than 3DR then it could be a fake and not include the regulator as Marbelo points out. Even though it has "3DR" on the board if you don't buy it from 3DR then it probably is a fake. Also if you assembled it yourself it is easy to overheat those big power leads when soldering and destroy the regulator.
Old Jan 07, 2015, 01:11 PM
Joined Sep 2014
Thanks guys, that is the issue then, I will use the BEC to power it up and just use this for voltage / current sensing. @mike_kelly, I bought it off of rcgroups classifieds, I'm sure it wasn't from 3dr and yes it does say 3dr on it so it's probably a fake.
Old Jan 07, 2015, 01:32 PM
Joined Sep 2014
For reference in case somebody else has this issue and finds this thread, take a look at the back of the board, clearly missing some of the components that are pictured in the link to the power module with BEC.
Sold 2 APM 2.6 and power module JonnyJ Aircraft - Electric - Multirotor (FS/W) 6 Nov 27, 2014 02:32 PM
For Sale APM 2.6, Power Module, OSD and GPS Combos! punkindrublik Aircraft - Electric - Multirotor (FS/W) 9 Oct 05, 2014 05:19 PM
Sold REPOST: APM 2.6 w/GPS,Power Module,900&433 Telemetry pvtkarma Aircraft - Electric - Multirotor (FS/W) 4 Oct 05, 2014 01:28 PM
Sold APM 2.6 w/GPS,Power Module,900&433 Telemetry pvtkarma Aircraft - Electric - Multirotor (FS/W) 0 Sep 23, 2014 07:34 PM
Help! 3Drobotics APM 2.6 w/ APM Power Module not display current Jcovaltine Multirotor Electronics 0 Mar 18, 2014 10:45 PM
