Old Aug 29, 2014, 04:17 PM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
No. Use the pull-pull location and you'll be fine.
Lardog is online now Find More Posts by Lardog
Old Sep 04, 2014, 03:53 PM
Joined Mar 2013
Cool!
Andrew Schear is online now Find More Posts by Andrew Schear
Old Sep 09, 2014, 03:05 PM
Eganwp's Avatar
Canada, BC, Victoria
Joined Feb 2008
Sent you a PM Bryan. Thanks!
Eganwp is offline Find More Posts by Eganwp
Old Sep 09, 2014, 03:25 PM
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Replied
bryansifsof44 is offline Find More Posts by bryansifsof44
Latest blog entry: Weights for planes
Old Sep 09, 2014, 03:56 PM
Eganwp's Avatar
Joined Feb 2008
Thank you for the info Bryan!
Guys couple of questions for you. I bought my slick in Nov this past winter but just getting around to building it now. It's the newer style hybrid elec/gas 71" version. Just have a few questions as the build manual is still from the old 70" version so I'm not sure what the latest build info is for the newest version. I'll be running my 12s 3300mah setup on the 4330 @ 216kv from Ken, similar to Bryan's setup as I mentioned a few months back. Just been to busy to assemble it all!
1. Just wondering pull-pull or push-pull for the rudder servo? I'm unsure what will balance out best with the 12s / 216kv setup.
2. How did you guys center the included electric motor box assembly on the firewall? There's no marking holes or templates as to how to attach it on the firewall. I may just manually have to measure it out which isnt a big deal, just wondering what you guys did.
Sorry for all the questions, its just hard to know without spending the time because the manual is for the old 70".
Travis
Old Sep 09, 2014, 05:25 PM
United States, CA, Rocklin
Joined Sep 2003
I just finished mine and maddened last Saturday
I put the rudder servo in the tail I using a motrofly 4330 on 6s but im also running a separate Rx battery no BEC mine balances with the battery right in the middle of the battery tray or maybe a little AFT of the middle of the tray RX battery is on the motor box
looking at the front of the plane the motor box goes all the way over to the right the DLE 30 templet they give you with the slick is really close as a guide
rcpilot_971 is offline Find More Posts by rcpilot_971
Old Sep 15, 2014, 05:38 PM
Joined Mar 2013
A lil sunset hover with the 71"
Old Sep 15, 2014, 10:01 PM
United States, LA, Lafayette
Joined Jul 2010
Travis
My buddy just finished his 71 with the 4330-216 running 2x3300 Eco Power batts that weigh 570g each. Ran the rudder in pull/pull and balanced perfectly with flight packs right up against the spar. He does have a separate 3.5oz rec batt mounted right behind the spar.
See pic
Hope this helps
huvaljohn is offline Find More Posts by huvaljohn
Old Sep 15, 2014, 10:52 PM
Joined Sep 2003
anyone put a DA-35 on the 71 slick ?
Old Sep 16, 2014, 12:24 AM
Joined Oct 2011
See pic
Hope this helps
Did he get a weight of the newer kit with the 3300s? If it came in as light as my buddies 74 edge, the 3300s would be a option for me.
Old Sep 16, 2014, 10:13 AM
plane crasher extrordinaire
microairman1's Avatar
United States, IL, Waukegan
Joined Sep 2012
so instead of going up in battery cells I am gonna try a new prop again. using a 20x8 prop now on 6s pulling like 60amps WOT. could I move to a 22x10 on 6s? or would that be to much?
microairman1 is offline Find More Posts by microairman1
Old Sep 16, 2014, 10:34 AM
Joined Mar 2013
I'm pulling just shy of 90 amps wot on my 6s setup. Power is great!
Old Sep 16, 2014, 02:36 PM
Joined Jul 2010
11 lbs 3oz
His 3300s are 60C and not the lightest so you could get it down to 11.0 with lighter batts and sub 11 without the rec pack and extra wire loom, etc
Old Sep 16, 2014, 02:39 PM
Joined Sep 2012
what motor?
Old Sep 16, 2014, 03:52 PM
Joined Oct 2011
11 lbs 3oz
Arg... I like my slick under 10.5lbs (preferably10.3lbs), so I guess I'll stick to my kit and 12s 2600. I just don't care for the negative low and slow with the slick at anything heavier. Thanks for checking.
Poll 3D hobby shop 51" slick or 55" SHP? appleflyer 3D Flying 24 Mar 24, 2009 06:29 PM
Video 3D Hobby Shop's AJ Slick Clark Warfel Electric Plane Talk 3 May 08, 2008 07:31 AM
