Old Nov 21, 2013, 11:11 AM
chiloschista is online now
Find More Posts by chiloschista
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Build Log
CNC-Multitool hot wire cutting and milling machine build
Hi ensemble,
want to cut foam cores for wings : what to do ?
First some space clearing is needed to host the machine.
Best regards,
Ric
chiloschista is online now Find More Posts by chiloschista
Switzerland
Joined Feb 2008
After a great study and an intensive email exchange, some package is finally delivered
Old Nov 21, 2013, 11:12 AM
Switzerland
Joined Feb 2008
Unpacking
Old Nov 21, 2013, 11:13 AM
Switzerland
Joined Feb 2008
Build begins mounting the steel shafts and carriages
Switzerland
Joined Feb 2008
Threaded rods inserted and temporary mounted the milling brace
Old Nov 21, 2013, 11:17 AM
Switzerland
Joined Feb 2008
The machine set for hot wire cutting, almost completed
Old Nov 21, 2013, 05:10 PM
Switzerland
Joined Feb 2008
I've done now all the electric connections.
To control the machine I'm using an old PC (single core, 500MB ram), setup with Windows XP, which seems doing his job well.
Ric
Old Nov 21, 2013, 05:11 PM
Switzerland
Joined Feb 2008
It is now time to find a working solution for a strut.
Metal would be nice, but difficult to modify and I know I'm going to modify it a lot.
Wood will probably be less accurate, but more easy to align and easier to modify. On cost side it is at least 1/3 vs metal one, considering the offers I had.
So this is the solution I choose.
Old Nov 21, 2013, 05:14 PM
Switzerland
Joined Feb 2008
Finally : the machine mounted and aligned.
In the pictures are showed both configurations : milling and hot wire cutting.
Old Nov 21, 2013, 07:15 PM
Dauntless Stan is offline
Find More Posts by Dauntless Stan
United States, CA, Vacaville
Joined Sep 2013
Ric, what is the make/model of the machine, and how may active axes does it have for hotwire? Thanks, Stan
Dauntless Stan is offline Find More Posts by Dauntless Stan
Old Nov 22, 2013, 02:05 AM
timbuck is online now
Find More Posts by timbuck
Bigger is better
timbuck's Avatar
gold coast australia
Joined Aug 2008
Cool
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Old Nov 22, 2013, 06:21 AM
Switzerland
Joined Feb 2008
Hi Stan,
the machine is similar to this one, but it seems they removed the model #1000 and start now from model #1200 (quiet more expensive).
It is a 4 axis for hot wire cutting and 3 axis for milling.
Ric
Old Nov 22, 2013, 06:22 AM
Switzerland
Joined Feb 2008
Originally Posted by timbuck View Post
Cool
Thanks !
Ric
Old Nov 22, 2013, 08:43 AM
Joined Sep 2013
Very interesting, Ric...thanks! I already have a largish (8'x4'x2' (245cm x 122cm x 61cm) working volume) 3-axis CNC router and could probably add wire cutting capacity to it. I need to do some research with the manufacturer (Shopbot). Cheers, Stan
Old Nov 24, 2013, 06:29 AM
Switzerland
Joined Feb 2008
The machine is running
First test for milling alignment :
First alignment test (0 min 58 sec)
Discussion So we've heard of hot wire cutting, but what about tiny hot wire cutting? GreenAce92_v2 The Builders Workshop 43 Jul 27, 2012 03:56 PM
Discussion Using a Milling machine as a Hot wire njsnel CAD/CAM 5 Dec 25, 2011 07:22 PM
Discussion CNC Hot-wire Machine Build wyowindworks CAD/CAM 148 Nov 20, 2008 09:24 AM
Discussion hot wire cutting machin swiart2 Foamies (Scratchbuilt) 2 Oct 27, 2007 12:18 PM
For Sale Hot wire Foam cutting CNC machine tbarnea Aircraft - General - Miscellaneous (FS/W) 0 Jun 19, 2006 02:42 AM
