Old Jul 19, 2013, 07:55 PM
capricorn is offline
Find More Posts by capricorn
Minnetonka Minnesota
Joined Aug 2007
Lizard, Just got back thanks. The stirring paddle is too fast it sort of froths the oil, you are like a mind reader. Hope I don't have to get another geared motor I think when it's hot it will not froth though, maybe program it to stir as the temp approaches the low limit, that would keep it off part of the time. Not sure I'll get it this weekend but hopefully next weekend or a weeknight I'll have it on a full test run. Cap
capricorn is offline Find More Posts by capricorn
Old Jul 20, 2013, 05:48 AM
bermylizard is offline
Find More Posts by bermylizard
Joined Sep 2009
Cap,
Stirring will help but is perhaps not necessary. You may find that a #4 or smaller deck screw with the head chopped will work like an Archimedes screw to move oil, but not froth. It has to run true with no out of balance. If a deck screw is too much try a piece of threaded rod (coarse). The idea is just to move the oil around to aid heat transfer to the copper.
Do you have a linear actuator or pump thingy? I seem to recall that you did, perhaps that could work just driving a plunger up and down. Another option would be make the prop smaller and place it just off the bottom.
Can you drive the motor with a PWM output to reduce velocity?
Best of luck.
bermylizard is offline Find More Posts by bermylizard
Old Aug 24, 2013, 01:48 PM
Joined Aug 2007
Fogger video
http://s326.photobucket.com/user/cai...ugust.mp4.html
After quite a delay I restarted the fogger. It has the new pump motor which is slow enough. It operates okay, but it still spits and pauses. I think the extended nossle is cool causing condensation. Have not determined how it will feed the funnels yet. I assumed a duct with a fan at the end blowing in air with the fogger nossle outlet into the duct of moving air. Cap
Discussion Full RC Arduino Control Dutchraptor Homebrew Hacks for Model Boats 181 Nov 11, 2014 02:02 AM
Build Log Rocket Launch Controller | Arduino | IBM ThinkPad| radtechtips Rocketry 0 Apr 08, 2013 07:16 PM
Sold Arduino - WM+ MultiWii controllers EnigmaSoar Aircraft - Electric - Multirotor (FS/W) 1 Feb 28, 2013 10:06 AM
Discussion Arduino-controlled transmitter Skystream Homebrew Hacks for Model Boats 3 Feb 22, 2013 03:43 PM
Discussion Arduino Uno Based Flight Controller? alexgator Multirotor Electronics 4 Feb 15, 2013 12:49 AM
