Old Apr 16, 2015, 05:42 AM
dk31 is online now
Find More Posts by dk31
dk31's Avatar
Athens
Joined Oct 2009
Has anyone give a try to make the reflector using aluminium? Like the kind of nice,~4mm thick material used in the helicals found in FPV stores (see picture).
I wonder what kind of aluminium it is (definitely not common alu,not fortal either) and how one could solder the RG316 shield on it .
I am sure it doesn't make any difference in performance over copper, but I really like the looks of it.
dk31 is online now Find More Posts by dk31
Old Apr 16, 2015, 06:01 AM
sjb_rc is offline
Find More Posts by sjb_rc
Joined Mar 2012
The connector is bolted on the reflector.
So no need to solder on aluminium.
sjb_rc is offline Find More Posts by sjb_rc
Old Apr 16, 2015, 07:08 AM
dk31 is online now
dk31's Avatar
Athens
Joined Oct 2009
I think you are right. Using a bolt sounds like a good idea.
Old Apr 17, 2015, 03:31 AM
RBirdie001 is offline
Find More Posts by RBirdie001
Prague, Czech_Republic
Joined Aug 2010
If needed, soldering fluids for aluminium also exists and can be bought at shops with electronic components. But bolting it's definitely a good idea.
Roman
RBirdie001 is offline Find More Posts by RBirdie001
Old Apr 17, 2015, 06:06 AM
dk31 is online now
dk31's Avatar
Athens
Joined Oct 2009
I 've seen some videos on youtube on how to solder aluminium, by using high temperatures (and a torch instead of iron). But this would damage the frigile RG316.
So, anyone knows what particular type of aluminium is this? Probably just for academic knowledge - chances are it will be too expensive to get and to work with it.
Old Apr 17, 2015, 08:30 AM
Joined Aug 2010
I have in my drawer special solder fluid for aluminium, but my drawer is probably too far from you .
It's kind of chemical, which applied to aluminimu covers it chemically with thin layer of zinc and zinc surface then can be soldered with normal solder at 300C.
But again - bolted connector will probably be the best...
Roman
Old Apr 17, 2015, 09:07 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
You can use the High Temperature process (or the zink chemical plate) process to 'tin' the hole, and then use 'normal' soldering techniques.
Aluminium comes in many grades, from soft through to Very hard, depending on how it is produced ( including heat treatments) .
The platters of Old 5 inch Hard Drives used to be made of tempered aluminium, and the modern ones may well be, I havn't stripped on in years
empeabee is offline Find More Posts by empeabee
Old Apr 18, 2015, 01:53 AM
dk31 is online now
dk31's Avatar
Athens
Joined Oct 2009
Thank you Mike. I will search for an old hard drive to see what I can get of it.
Old Apr 23, 2015, 12:38 PM
kumar123 is offline
Find More Posts by kumar123
Singapore
Joined Mar 2013
7 turn helical . waiting for copper strip to make impedance matching.
thanks to IB CRAZY.
kumar123 is offline Find More Posts by kumar123
Discussion Circular-polarized Patch Antenna for 5,8 GHz Lonestar78 FPV Talk 25 Feb 22, 2015 08:01 PM
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
For Sale 2.4 gh 8 dbi patch antenna $10 norberto83 FPV Equipment (FS/W) 1 Dec 03, 2010 07:44 PM
Question 30 dBi Grid Antenna matyou FPV Talk 7 Nov 14, 2010 10:32 PM
Discussion Anyone tried building a helical antenna for FPV? Bill Sanford FPV Talk 20 Nov 04, 2010 06:48 PM
