Old Nov 10, 2014, 09:19 PM
Joined Jul 2006
Build Log
arduPump, an arduino vacuum pump controller
My old aquarium pump wasn't entirely cutting it, and I've got some new wings to skin. I decided to hack together a simple digital controller using an Arduino to read a pressure sensor and turn on a cheap 12V pump.
Basic parts list; I sourced everything from Sparkfun & Jameco
Ardweeny, AT328 with a backpack board for crystal, interface; programs like an Uno
4 digit 7-segment display
RFP30N06LE logic level power MOSFET - pulls the 12V pump to ground
MPX5100D pressure sensor - 0.25 - 4.7 volt output, 0-100 kPa range
LM7805 for 5V power / reference
large 10K pot
switches / resistors / caps / jumpers
D2028 - inexpensive 12VDC pump, nominally 16" vacuum
Here's the breadboard version in action:
arduPump breadboard (1 min 4 sec)
c.walker is offline Find More Posts by c.walker
Old Nov 10, 2014, 09:48 PM
Joined Jul 2006
Boxing: way too many of my projects never make it past the breadboard stage. I have breadboard circuits in various piles built over the years that do...well, I'm not really sure what they do anymore, but they seemed like a good idea at the time. This time I'll actually mount everything in a self contained unit.
Old Nov 10, 2014, 11:11 PM
Australia, NSW, Hornsby
Joined Jul 2005
Wow. Nice project.
Very interested & watching closely.
Al
_AL_ is offline Find More Posts by _AL_
Old Nov 13, 2014, 05:53 AM
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Struth that looks complicated!
What is the estimated cost so far?
Jim.Thompson is online now Find More Posts by Jim.Thompson
Latest blog entry: Regulated vacuum system.
Old Nov 13, 2014, 07:00 AM
stop making sense
hallo's Avatar
Joined Feb 2014
I have the parts for one lying in a box somewhere, if I was to make it, it would take me quite some dedication to understand exactly how it should be put together. And then the programming that would take me a lot of time, perhaps a couple of years for me to get it right.
Will I be able to use your program in my unit though it is a completely different build but still Arduino based?
hallo is offline Find More Posts by hallo
Old Nov 13, 2014, 03:06 PM
Joined Aug 2008
My simple regulated vacuum supply cost me $2 and took a lazy few hours to assemble. It is mainly made from salvaged bits and pieces from the tip and has been in commission for 5 years now. Fully adjustable vacuum level and low deadband. It is silent, or very nearly so.
I'm a bit baffled by the perceived need to complicate things like this, when something electro-mechanical like my DIY set up works totally reliably.
Old Nov 13, 2014, 04:14 PM
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
That's an interesting project.
Personally for me I have invested in a continuous 25" pump. Just switch it on and come back when the resin has cured. Of course I don't bag foam...... :-)
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Nov 13, 2014, 04:29 PM
Joined Aug 2008
One of the benefits of hydro electricity - it is cheaper than ours!
My regulated system operates at > 1% duty cycle.
Old Nov 13, 2014, 04:35 PM
Joined Mar 2006
Well the running costs for 5 hours is ~ $1 NZD.
Affordable I'd say!
Old Nov 13, 2014, 08:18 PM
Joined Jul 2006
Unless your time is free, there's really no way this is cost effective compared to a vacuum switch and a standard pump. I'm doing this because I wanted something really small, I like hacking, and as an EE, I already have piles of circuit components. Also, having an arbitrarily small deadband and a digital readout is nice for dealing with low density foam.
Rough parts cost:
Ardweeny: $10
sensor: $15
box + board: $15
nice potentiometer: $15
pump: $15
other circuit bits: $10
all up: $80
Old Nov 13, 2014, 08:22 PM
Joined Jul 2006
That looks like an Uno, so my code will compile for your Arduino. The display is different, so you'll have to deal with that. It looks like you've got everything you need except for a logic level FET to drive the relay. Code will go up shortly.
Old Nov 13, 2014, 08:26 PM
Joined Jul 2006
It's finished. I wasn't as careful as I should have been gluing the display into the box, so some resin leaked out, but it's all together and functional.
Old Nov 13, 2014, 08:39 PM
Joined Jul 2006
Code is now up at the initial post.
Here's the completed unit being tested against a vacuum gauge:
arduPump calibration testing (2 min 3 sec)
Mini-HowTo Vacuum Bagging Made Easier - Aqua Vac, Foodsaver, Gast Pump & Tire Pump Geode Hand Launch 264 Nov 29, 2010 04:14 PM
Question Vacuum bagging using manual vacuum pumps Bosk The Builders Workshop 7 Apr 26, 2009 09:23 PM
Sold Vacuum Bagging Equipment - package deal, dual head vacuum pump rakm Aircraft - General - Miscellaneous (FS/W) 8 Jun 05, 2007 05:53 PM
For Sale Vacumaster Vacuum Pump For Vacuum Forming ROADTOAD Non R/C Items (FS/W) 0 Nov 02, 2006 07:03 AM
Is this Gast vacuum suitable for a vacuum pump ? adriaan Composites Fabrication 8 Jul 27, 2005 11:15 AM
