Old Nov 07, 2014, 03:32 PM
United States, CA, Auburn
Joined Jan 2009
Originally Posted by Supreme Balloon View Post
http://www.dji.com/product/naza-m-v2/download
Naza-M v2 Quick Start Manual v1.26
Read the section on the voltage monitor, it is pretty much the same for V1 and V2.
If your LIPOs are not charged up, you will have a problem.
If they are, then you need to configure the low voltage alerts or turn it off.
ok this board is being tested on the bench ..powering up w/ 5V at M1 ..and a usb connector to the Vsen pins .. there is a separate(besidesnaza assistant window that pops up w/ a low voltage warning ..and battery plugged into the bec is fully charged ..could it be software related problem or regulator out of wack..how do i cure..t this problem..i am afraid to use it ..i purchased this from a guy FPVlabbet ..said its all good ..should i use it ?
pinoydad is offline Find More Posts by pinoydad
Old Nov 07, 2014, 05:31 PM
Seattle, WA - USA
mark_q's Avatar
Joined Sep 2003
If the only power to Naza is through a BEC then you will always get a warning. Naza can only sense flight battery voltage through its own devices such as the VU (V1) or PMU (V2).
Most folks do not use the battery sense capability anyway because it is a bit too conservative for most. I have never used it and instead use a telemetry system. It is easy to disable in assistant.
Hope that helps
Mark
mark_q is online now Find More Posts by mark_q
Latest blog entry: Zeta FX-61 Phantom FPV Wing
Old Nov 07, 2014, 09:28 PM
Mowee's Avatar
United States, CA, Fullerton
Joined Oct 2013
the Naza V2 gets it's power on X3 from the PMU.
The center 5v lead from ESC that have a BEC in them should be removed so that it does not feed power into the NAZA motor servo connectors.
As mark_q said it reads the voltage in the PMU, so if you don't have a PMU or UV hooked up the NAZA will always think the voltage is low.
Mowee is offline Find More Posts by Mowee
Old Nov 07, 2014, 10:38 PM
Joined Jan 2009
aah i see ..thanks ..i put the project aside ..
Old Nov 08, 2014, 08:45 AM
It's gone...
_OZ_'s Avatar
Joined Aug 2004
Motors won't start and DJI assistant will not recognize controller
Gentlemen, as the title says the motors won't start and I can't connect to the assistant.
I flew it two times on fresh batteries and then installed a fresh 3rd battery. On the third time the motors would not start.
I rebound the Rx, checked all connections, used a different Rx and tried to connect to the DJI Assistant. I can't connect to the assistant and I also can't find any info on what these the LED flashes mean.
This is a Naza-m controller
Tried different cables and ports to connect to the assistant- no change
Tried all flight modes - no change
Tried new driver and different computer - no change
I tried a hard reset and nothing happened. No lights or beeps.
I unplugged the jumper and it does the same thing as what is in the video.
Naza nogo (1 min 24 sec)
_OZ_ is offline Find More Posts by _OZ_
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 05:32 AM
Discussion HoverFly Owners Thread: Pro, GPS, Sport, Gimbal and news Adidas4275 Multirotor Talk 195 Sep 06, 2012 05:45 PM
Found DJI NAZA GPS Upgrade Module for the DJI Naza Flight Controller skyhulk Aircraft - Electric - Multirotor (FS/W) 10 Jul 20, 2012 09:47 PM
Question Question for Spektrum DX8/HF GPS owners Wayno Complaino Hoverfly Technologies 13 Jan 01, 2012 02:18 PM
Discussion Gps owner videos jginsandiego Hoverfly Technologies 0 Oct 04, 2011 06:01 PM
