Old Aug 13, 2012, 07:58 AM
Marvos is offline
Find More Posts by Marvos
Joined Apr 2012
Change pin used for motor in MultiWii code
Hello everyone. I have a promini 328P board. The promini is supposed to be able to control 6 motors, for a hexacopter.
I have recently managed to fry (it would seem) pin nr.3, so it can no longer control an esc.
Since I am trying to run a quad, I hope I correctly assume that I am left with two usable pins on the board, which could be used as a replacement for pin nr.3.
The only thread I found on this subject is this one http://www.multiwii.com/forum/viewtopic.php?f=8&t=1382
I tried the advice from that thread, but it did not work.
How can I change the code to use pin nr. 5 or 6 (or perhaps A1 or A2??) instead of pin 3?
Marvos is offline Find More Posts by Marvos
Old Aug 21, 2012, 08:21 AM
Marvos is offline
Joined Apr 2012
Found the solution: http://www.multiwii.com/forum/viewto...p=21416#p21216
Careful! Warning! rabbit Flight Controller uses stolen code from MultiWii hamburger Multirotor Electronics 1107 Sep 15, 2012 08:00 PM
Discussion Changing CAMSTAB pin out on MWC mega Foam boy Multirotor Electronics 0 Aug 07, 2012 12:54 AM
Discussion Two changes to the tax code that would significantly change politics ... logan5 Life, The Universe, and Politics 23 Apr 12, 2012 02:57 PM
Discussion Calibrating ESC's using multiwii code mstanescu Multirotor Talk 0 Mar 11, 2011 02:37 AM
