Old Yesterday, 08:32 AM
Scotland
rcminiman's Avatar
How do you line up your stills shots without a downlink to a screen? Any tips?
I have a 550 size hex running a Panasonic Lumix compact camera on a one axis controllable gimbal. I can have it pointing anything from straight ahead to straight down controlled by a knob on the tx.
Ive been pretty much guessing where its pointing, but Im tempted to paint a straw flourescent and stick it to the camera so I may see where its pointing.
Any other tips, tricks and ideas for me?
rcminiman is offline Find More Posts by rcminiman
Old Yesterday, 10:23 AM
Scotland
rcminiman's Avatar
The plane was easy, just use the wing and shoot out the side, but this is a bit more difficult. Heres a shot from this morning. Scotland in the early morning sun...
Old Yesterday, 11:43 AM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Calibrate the knob you use... A couple/three sticky's at the points where the camera is looking level, down some angle, and straight down.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Yesterday, 11:48 AM
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Does the gimbal has its own gyro and is self stabilizing? Or is its servo controlled directly by your transmitter?
Rather than a knob, use a three position switch instead. That way you only have to remember three points on your FPV monitor that corresponds to each switch position.
Hajile is online now Find More Posts by Hajile
Old Yesterday, 03:30 PM
benedict's Avatar
United States, HI, Waimea
Joined Feb 2013
I used a no-video system hanging from a kite for years. I used Sparky Paul's approach: I stuck pan on a stick, but stuck tilt on a knob. The knob had markers for level with the horizon, 33% down from the horizon (put the horizon on the 1/3 line of the frame), 45 degrees down, and straight down. It was relatively straightforward to set my tilt and line up the camera by eye from there.
For what it's worth your straw idea has merit, too. When I started doing kite aerial photography I used a 72MHz radio. I had the antenna wire wound around a wooden dowel that stuck out the back of the rig. I could use the stick to line up where I was side-to-side and the knob to line up where I was up and down. It worked remarkably well, even several hundred feet out.
Give the straw and knob ideas a try, and see what works out best for you. You may hit on something new that's better than both.
Tom
benedict is offline Find More Posts by benedict
Question How secure is all your computer on those " Back up on lines ? " cyclops2 Life, The Universe, and Politics 3 Nov 16, 2013 11:06 AM
Discussion dji downlink... how do you position your rx antenna? JebSmith Multirotor Talk 2 Oct 31, 2013 08:02 AM
Question How do you line up your winch with the winch line? satinet Multi Task F3X 8 May 16, 2013 04:41 PM
Discussion Tips for lining up shots with a downward-facing camera? Dan_K Aerial Photography 16 Jan 24, 2009 01:40 PM
CHEAP wireless camera for lining up still shots bsoder Aerial Photography 2 Aug 10, 2005 02:03 PM
