Old Dec 03, 2004, 11:08 PM
LIFE IS GOOD !!!!
marietta pa
Joined Jan 2004
what motor to use on hornet 2 for great 3d
need to know what motor to use for great 3d with budget in mind,and what upgrades will it need.
falcon41176 is offline Find More Posts by falcon41176
Old Dec 03, 2004, 11:32 PM
tabbytabb's Avatar
Seattle, Washington, United States
Joined Mar 2003
Axi 2208/20 with 25, 26 or 27T pinion does fantastic on the H2 for 3D. Pinion size should depend on the current your batts can supply and your flying style. I use the 25 and 26T
Tabb
tabbytabb is offline Find More Posts by tabbytabb
Site Sponsor
Old Dec 03, 2004, 11:44 PM
LIFE IS GOOD !!!!
marietta pa
Joined Jan 2004
are tp 1320 g2 3 cell good choice
Old Dec 04, 2004, 12:11 AM
Melbourne Australia
Joined May 2003
and where do you get the 20+ size pinions from. MS only make them up to 13 don't they ?
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Dec 04, 2004, 12:29 AM
LIFE IS GOOD !!!!
marietta pa
Joined Jan 2004
what if i used a himaxx 2025-4200 with a cc 25 amp speedo with a 1320 g2 3 cell pack. what pinion would do you think i should use.
Old Dec 04, 2004, 12:42 AM
dennis4987
dennis@deetee's Avatar
Junction City, Oregon
Joined May 2003
The MS Twister motor (by MS Composit) is proving to have brute force power on a Apogee 1050 or a thunder Power 1200. The MS Twister (Part #MS-011) comes with its own pinion gear and all mounting hardware. You do have to modify your frame work to get the larger pinion to fit in the frame. But, its not all that hard to do, and well worth the effort.
........Dennis
dennis@deetee is offline Find More Posts by dennis@deetee
Old Dec 04, 2004, 03:41 AM
tabbytabb's Avatar
Joined Mar 2003
Falcon, I tested the 2025 and it is an amp hog and also doesnt have near the power of the axi or twister.
Ozzie, I am using robinson racing products pinions made for RC cars. They are 1/8 shaft and 64 pitch just like the H2 gear. The larger pinions run ultra smooth on the H2
Tabb
Site Sponsor
Old Dec 04, 2004, 12:21 PM
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
you guys run a 100% throttle thrughout the pitch curve setting for 3D on the Twister ? whats your max pitch ?
it seems to droop head speed when i hit max pitch
meatbomber is offline Find More Posts by meatbomber
Old Dec 04, 2004, 12:29 PM
dennis4987
Joined May 2003
Decrease your top end pitch meatbomber. Do the same for bottom end pitch for inverted. You should be OK doing that.
........Dennis
Old Dec 04, 2004, 03:05 PM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
Currently my pitch range is all the way down and up on the 2 steel pins... now i have a Futaba FX-18 and currently run 40% for collective pitch and 60% for nick and roll in the swash plate programm HR3 all without binding...
would you now recommend just making the pitch values smaller on the pitch curve or reduce the pitch percentage in the swash mixer ? (do you know what i mean?)
Old Dec 04, 2004, 03:10 PM
Melbourne Australia
Joined May 2003
my pitch range does not use the full length of those two pins and i still get -10 - +10degs.
As for your question...that's a good one, i would like to know the same. I use the full pitch curve and lower the percentage in the mixing option...I'm curious if that's the best way. As I run governor mode, it probably doesn't make much difference.
Old Dec 04, 2004, 03:23 PM
dennis4987
Joined May 2003
Yeah meatbomber. Just reduce your overall pitch range (ATV's) until it no no longer bogs down at the extremes of pitch either upright or inverted. No need to change pitch curve. In fact run your pitch curve totally linear as below:
0 - 25 - 50 - 75 - 100
Adjust head speed with your throttle curve. Not your pitch curve. That way you will get a much smoother transition of collective pitch changes while flying.
........Dennis
Old Dec 04, 2004, 05:11 PM
LIFE IS GOOD !!!!
marietta pa
Joined Jan 2004
would a throtle curve of 95-85-80-85-95 be good for 3d with a -10 +10 pitch and a mister twister, and a tp 1320 g2 3 cell pack, but if you guys think i can get away with a himaxx 2025-4200 cause i have one laying around. if not i will get the mister twister
Old Dec 04, 2004, 07:03 PM
tabbytabb's Avatar
Joined Mar 2003
Falcon, here is a video of my H2 with the 2025 4200 and a 850 Tanic 3 cell battery pack. It can do 3d but has no where near the pop of my axi powered H2.
Hope this helps
Tabb
Hornet Video 2025-4200
Site Sponsor
Old Dec 04, 2004, 07:48 PM
LIFE IS GOOD !!!!
marietta pa
Joined Jan 2004
thank you tabb. that is best info you could have gave me. nice video, got any more. the himaxx should be fine for what i want to do. but i will get the mr twist later. x-mas shopping combined with the hobby is killing the wallet.
but what pinion should i run with the himaxx on the hornet. please post some more videos. that was great
Question What motor to use on a Zen 30 JustFly Power Systems 10 Jun 15, 2006 05:21 AM
what should head speed and throtle curves for normal and 3d be on hornet 2 falcon41176 Micro Helis 8 Dec 20, 2004 02:48 PM
What motor to use for single motor twin blade P-38? cstroud Power Systems 47 Jul 15, 2004 07:57 AM
Another Cdrom motor conversion, what plane to use it on? Steve H. Power Systems 3 Jan 25, 2004 03:22 PM
Shorten leads on GY401 for use on Hornet 2 Xnaron Micro Helis 8 Dec 21, 2003 10:21 PM
